    Tgi3D plugins -
    76 Posts 31 Posters 17.6k Views 31 Watching
    • KrisidiousK Offline
      Krisidious
      Hi Kristoff,
      Do you have all the TGI-Folders and Files in your plugin folder? And did you activate the TGi3D toolbar?
      Charly
      yes I have all of that... and the imain.rbs is in the folder.
      By: Kristoff Rand
        It installed on my PC v7 and v8 with no issues?
          d12dozr
          I also have it installed in SU7 and SU8 (PC) with no problems.
          http://goo.gl/f7ooYh
            Krisidious
            are any of you using a external or extra harddrive for SU?
            By: Kristoff Rand
              d12dozr
              Nope
                Me neither.
                • CadFatherC Offline
                  CadFather
                  there is a plugin conflict somewhere - remove all and leave only tgi3d - that way it will work and you can try it
                    JuanV.Soler
                    Diego Rodriguez,
                    it is so embarrassing to read you in this Plugin´s Creators forum...
                    Edit : %(#000080)[Sorry Diego for my last words, I thought you were taking advantage.
                    Lo siento. Salud]
                    • sadyoS Offline
                      sadyo
                      @krisidious said:
                      I get an error when I open that says "No such file to load -- tgi3d/imain" the file is there.
                      there is an extension in the list and it is check marked... but there is no menu options or plugins in the list nor are there any toolbars.
                      I have experienced exactly the same problem with you when trying to use "Tgi3D SU Amorph Training Edition v1.14"...
                      I think they fixed that problem now, because they just released a new versions of Tgi3D SU plug-ins (v1.15).
                      I already try that new version and error message "No such file to load -- tgi3d/imain" is Gone now...
                        Krisidious
                        thanks I'll try again...
                        By: Kristoff Rand
                        • unclebimU Offline
                          unclebim
                          Here is the message from the Tgi3D support about the error message "no such file to load -- tgi3d/imain":
                          Thank you for contacting Tgi3D Support.
                          We have just released a new versions of Tgi3D SU plug-ins on our website. Although we have not been able re-create the "exact problem with the same conditions" you encountered, we believe that the new version should address the issue.
                          We would appreciate it if you could download the new version of Tgi3D SU Amorph Training Edition (v1.15t) and re-install it on your computer. After re-install, we would further appreciate your feedback on the result via the Support page on our website.
                          Regards,
                          Tgi3D Support Team
                          I have run the new version and it has installed fine with SU 8 now.
                            Krisidious
                            yes the new installer fixed my issue... no errors on 7 or 8
                            By: Kristoff Rand
                            • 4 / 4
