    Tgi3D plugins -
    76 Posts 31 Posters 16.0k Views 31 Watching
    • jason_marantoJ Offline
      jason_maranto
      It's a free tool -- take it and be grateful just like you would any other plugin... if you feel that you need/want the more advanced features then you can pay for them. They have the right to charge whatever they think the market will bear -- if they are wrong then the market will speak and they will change their policy.
      Griping about their pricing policy is pretty pointless.
      Best,
      Jason.
      • jeff hammondJ Offline
        ha. ok.
        • KrisidiousK Offline
          Krisidious
          how is it a free tool? there's a training version but does it allow you to save it? and use the model? I don't think it's pointless.... in fact I bet their reading it... and I also bet they had these same arguments.
          By: Kristoff Rand
            jason_maranto
            Yes and yes... maybe you should use it before you comment.
              Krisidious
              I've tried... it doesn't work and I've had no response to my bug report.
              By: Kristoff Rand
                Krisidious
                it had a really kool installer though... found all my installations on all my drives and installed to each simultaneously. and if you look at their website these guys love to code... lots of nooks and crannies, very tight.
                By: Kristoff Rand
                • EarthMoverE Offline
                  EarthMover
                  Not sure if this is the issue, but when you install the set of Free training tools, you will at first get a menu of grayed out icons. You have to click on the last one and enter your name to register the toolbar, then restart Sketchup. After that the tools work fine, although they are limited by the number of verticies they will process. For example the Upsample tool (right click menu) won't work on anything complicated, but will work only on small areas with only a few dozen verts. For me, the Select and Cross Section tools alone make the plugin worth checking out. I just wish they would allow you select loops as well as manipulate them. It seems if you can find loops to be manipulated, it would easy enough to also add a feature to select edge loops as well.
                  Content Creator at Skapeup
                    Krisidious
                    I get an error when I open that says "No such file to load -- tgi3d/imain" the file is there.
                    there is an extension in the list and it is check marked... but there is no menu options or plugins in the list nor are there any toolbars.
                    By: Kristoff Rand
                    • charly2008C Offline
                      charly2008
                      Hi Kristoff,
                      Do you have all the TGI-Folders and Files in your plugin folder? And did you activate the TGi3D toolbar?
                      Charly
                        EarthMover
                        Installer is not working for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8. Probably a file mix up on their part.
                        • unclebimU Offline
                          unclebim
                          @earthmover said:
                          Installer is broken for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8.
                          I got the same error on 8 but not on 7.
                            Krisidious
                            Hi Kristoff,
                            Charly
                            yes I have all of that... and the imain.rbs is in the folder.
                            By: Kristoff Rand
                              It installed on my PC v7 and v8 with no issues?
                                d12dozr
                                I also have it installed in SU7 and SU8 (PC) with no problems.
                                http://goo.gl/f7ooYh
                                  Krisidious
                                  are any of you using a external or extra harddrive for SU?
                                  By: Kristoff Rand
                                    d12dozr
                                    Nope
                                      Me neither.
                                      • CadFatherC Offline
                                        CadFather
                                        there is a plugin conflict somewhere - remove all and leave only tgi3d - that way it will work and you can try it
                                          JuanV.Soler
                                          Diego Rodriguez,
                                          it is so embarrassing to read you in this Plugin´s Creators forum...
                                          Edit : %(#000080)[Sorry Diego for my last words, I thought you were taking advantage.
                                          Lo siento. Salud]
                                          • sadyoS Offline
                                            sadyo
                                            I have experienced exactly the same problem with you when trying to use "Tgi3D SU Amorph Training Edition v1.14"...
                                            I think they fixed that problem now, because they just released a new versions of Tgi3D SU plug-ins (v1.15).
                                            I already try that new version and error message "No such file to load -- tgi3d/imain" is Gone now...
                                            • 4 / 4
