    Tgi3D plugins -
    76 Posts 31 Posters 17.6k Views 31 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Expensive in comparison to SU Pro, yes. However if the plugin pays is way in time saved quickly, it would make sense to purchase. After all time = money 😉
      • KrisidiousK Offline
        Krisidious
        high prices to me tend to insinuate that companies will be making the purchase and not individuals like us. thus Autocad's 3k price tag. 1000 is extremely high for me... I could use these tools but that's out of my price range for architecture.
        By: Kristoff Rand
        • X Offline
          xrok1
          point taken 😳
            Mike Lucey
            Kris, I can understand where you are coming from when you say the the $999 price is aimed at companies, I imagine it is. I can see even small companies buying a copy and having one person specialise using it. He then becomes the 'Photoscan Expert' with the company, makes sense!
            Its a bit more difficult to justify the purchase of a $1k app for occasional use for the sole operator UNLESS they can manage to use it for sub-contract work! Its always an option.
            • jeff hammondJ Offline
              dunno., i'm still a skeptic
              from the video, it's not seeming all it's cracked up to be as far as 3D scanner goes..
              you need at least 15 photos etc.. even textured non-shiny objects..then you have to patch the whole thing together which looks like quite a bit of work for that shape in the video.. not to mention the inaccuracies that are bound to occur + missing camera angles (bird's eye)etc..
              it's hobbyist work, not professional, yet it carries a pro price tag..
              i can't try it out for myself but someone please wow me with a 3D scanning experience
              • jason_marantoJ Offline
                jason_maranto
                It's a free tool -- take it and be grateful just like you would any other plugin... if you feel that you need/want the more advanced features then you can pay for them. They have the right to charge whatever they think the market will bear -- if they are wrong then the market will speak and they will change their policy.
                Griping about their pricing policy is pretty pointless.
                Best,
                Jason.
                  ha. ok.
                    Krisidious
                    how is it a free tool? there's a training version but does it allow you to save it? and use the model? I don't think it's pointless.... in fact I bet their reading it... and I also bet they had these same arguments.
                    By: Kristoff Rand
                      jason_maranto
                      Yes and yes... maybe you should use it before you comment.
                        Krisidious
                        I've tried... it doesn't work and I've had no response to my bug report.
                        By: Kristoff Rand
                          Krisidious
                          it had a really kool installer though... found all my installations on all my drives and installed to each simultaneously. and if you look at their website these guys love to code... lots of nooks and crannies, very tight.
                          By: Kristoff Rand
                          • EarthMoverE Offline
                            EarthMover
                            Not sure if this is the issue, but when you install the set of Free training tools, you will at first get a menu of grayed out icons. You have to click on the last one and enter your name to register the toolbar, then restart Sketchup. After that the tools work fine, although they are limited by the number of verticies they will process. For example the Upsample tool (right click menu) won't work on anything complicated, but will work only on small areas with only a few dozen verts. For me, the Select and Cross Section tools alone make the plugin worth checking out. I just wish they would allow you select loops as well as manipulate them. It seems if you can find loops to be manipulated, it would easy enough to also add a feature to select edge loops as well.
                            Content Creator at Skapeup
                              Krisidious
                              I get an error when I open that says "No such file to load -- tgi3d/imain" the file is there.
                              there is an extension in the list and it is check marked... but there is no menu options or plugins in the list nor are there any toolbars.
                              By: Kristoff Rand
                              • charly2008C Offline
                                charly2008
                                Hi Kristoff,
                                Do you have all the TGI-Folders and Files in your plugin folder? And did you activate the TGi3D toolbar?
                                Charly
                                  EarthMover
                                  Installer is not working for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8. Probably a file mix up on their part.
                                  • unclebimU Offline
                                    unclebim
                                    @earthmover said:
                                    Installer is broken for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8.
                                    I got the same error on 8 but not on 7.
                                      Krisidious
                                      Hi Kristoff,
                                      Charly
                                      yes I have all of that... and the imain.rbs is in the folder.
                                      By: Kristoff Rand
                                        It installed on my PC v7 and v8 with no issues?
                                          d12dozr
                                          I also have it installed in SU7 and SU8 (PC) with no problems.
                                          http://goo.gl/f7ooYh
                                            Krisidious
                                            are any of you using a external or extra harddrive for SU?
                                            By: Kristoff Rand
                                            • 3 / 4
