    Tgi3D plugins -
    76 Posts 31 Posters 19.9k Views 31 Watching
    • EarthMoverE
      EarthMover
      Not sure if this is the issue, but when you install the set of Free training tools, you will at first get a menu of grayed out icons. You have to click on the last one and enter your name to register the toolbar, then restart Sketchup. After that the tools work fine, although they are limited by the number of verticies they will process. For example the Upsample tool (right click menu) won't work on anything complicated, but will work only on small areas with only a few dozen verts. For me, the Select and Cross Section tools alone make the plugin worth checking out. I just wish they would allow you select loops as well as manipulate them. It seems if you can find loops to be manipulated, it would easy enough to also add a feature to select edge loops as well.
      Content Creator at Skapeup
      • KrisidiousK
        Krisidious
        I get an error when I open that says "No such file to load -- tgi3d/imain" the file is there.
        there is an extension in the list and it is check marked... but there is no menu options or plugins in the list nor are there any toolbars.
        By: Kristoff Rand
        • charly2008C
          charly2008
          Hi Kristoff,
          Do you have all the TGI-Folders and Files in your plugin folder? And did you activate the TGi3D toolbar?
          Charly
          • EarthMoverE
            EarthMover
            Installer is not working for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8. Probably a file mix up on their part.
            • unclebimU
              unclebim
              @earthmover said:
              Installer is broken for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8.
              I got the same error on 8 but not on 7.
              • KrisidiousK
                Krisidious
                Hi Kristoff,
                Charly
                yes I have all of that... and the imain.rbs is in the folder.
                By: Kristoff Rand
                  It installed on my PC v7 and v8 with no issues?
                    d12dozr
                    I also have it installed in SU7 and SU8 (PC) with no problems.
                    http://goo.gl/f7ooYh
                    • KrisidiousK
                      Krisidious
                      are any of you using a external or extra harddrive for SU?
                      By: Kristoff Rand
                        d12dozr
                        Nope
                          Me neither.
                          • CadFatherC
                            CadFather
                            there is a plugin conflict somewhere - remove all and leave only tgi3d - that way it will work and you can try it
                              JuanV.Soler
                              Diego Rodriguez,
                              it is so embarrassing to read you in this Plugin´s Creators forum...
                              Edit : %(#000080)[Sorry Diego for my last words, I thought you were taking advantage.
                              Lo siento. Salud]
                              • sadyoS
                                sadyo
                                I have experienced exactly the same problem with you when trying to use "Tgi3D SU Amorph Training Edition v1.14"...
                                I think they fixed that problem now, because they just released a new versions of Tgi3D SU plug-ins (v1.15).
                                I already try that new version and error message "No such file to load -- tgi3d/imain" is Gone now...
                                • KrisidiousK
                                  Krisidious
                                  thanks I'll try again...
                                  By: Kristoff Rand
                                  • unclebimU
                                    unclebim
                                    Here is the message from the Tgi3D support about the error message "no such file to load -- tgi3d/imain":
                                    Thank you for contacting Tgi3D Support.
                                    We have just released a new versions of Tgi3D SU plug-ins on our website. Although we have not been able re-create the "exact problem with the same conditions" you encountered, we believe that the new version should address the issue.
                                    We would appreciate it if you could download the new version of Tgi3D SU Amorph Training Edition (v1.15t) and re-install it on your computer. After re-install, we would further appreciate your feedback on the result via the Support page on our website.
                                    Regards,
                                    Tgi3D Support Team
                                    I have run the new version and it has installed fine with SU 8 now.
                                    • KrisidiousK
                                      Krisidious
                                      yes the new installer fixed my issue... no errors on 7 or 8
                                      By: Kristoff Rand
                                      • 4 / 4
