    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • TIGT Online
      So... Chris's tools fall over because one of them hasn't already loaded 'some other menu' when it thinks it has...
      Here's a [possible] simple fix... put it into the correct sub-folder...
      clf_shape_bender.rb
      Chris can sort it 'properly' later... πŸ˜’
      • charly2008C Offline
        charly2008
        Many thanks TIG. I tried the Shape Bender plugin in SketchUp 8 there it works fine. and now with your update it works again in Sketchup 7.
        Charly
        • Chris FullmerC Offline
          Hey TIG, thanks for looking into it. I am without a computer at home for now, so I'm mostly useless. But what was the problem you found? I was able to load shape bender just fine without having any of my other plugins loaded. Did I mess something up in my overly complicated menu system?
          • TIGT Online
            Wait till you get a proper link in to check what's up... I think it's the way that some of your scripts check if a Plugin is loaded already... I moved the confirmations in that file so each of them is immediately after its the first-run check and its seems to work OK then...
            You have over-complicated your menu checking somewhat.... but - hey 😎 -join-the-club πŸ˜„
            It seems to depend on which of your scripts a user has loading... and of course it shouldn't πŸ˜’
            It's probably an easy fix BUT it probably affects several of your scripts 😞
            • mariochaM Offline
              mariocha
              Huh ....
              The shape in the attached file makes Shape Bender crash SU.
              I tried it several times.
              (The line I want to use is hard to see, on the red axis)
              branch-o.skp
              %(#008000)[Mario C.
                Bug Splat for me, too. Even after I moved the straight line so it lies on the red axis. It works with a simple long, skinny box. Perhaps there's too much geometry in the branch?
                • jeff hammondJ Offline
                  (mac)
                  works in SU7.. crashes with 8
                    d12dozr
                    Worked fine for me, the only thing I did was move the branch up a few inches so I could see the horizontal line. I didn't get the green preview wires like I usually do though.
                    File is attached.
                    branch-o.skp
                    http://goo.gl/f7ooYh
                    • mariochaM Offline
                      mariocha
                      Great ! Good idea.
                      I will try it in v7.
                      thx a lot.
                      I guess a small update of the plugin will be needed. πŸ˜„
                      %(#008000)[Mario C.
                      • jim smithJ Offline
                        jim smith
                        I haven't run through all the thread since 8 came on the scene, but it doen't work on my laptop with 8. V7.1, it works just fine. Attached is a screen shot of a simple bend, it seems to start and then stalls at 5%. On my V7.1, it bends in a few seconds. I don't get any error message box on startup or when I start the shape bender.
                        "Out of clutter find simplicity,
                        from discord find harmony,
                        In the middle of difficulty lies opportunity"
                        Albert Einstein
                          Looks like I need to poke aroud in this plugin again to get it v8 compatible. I'll see what I can do.
                          • gullfoG Offline
                            gullfo
                            it's working OK for me on SU8 (on fairly complex shapes), but previously on SU7 i had a similar problem and i cleaned things up and removed a number of older plugins and then everything worked OK. i suggest checking to see if you can identify a plugin which may be problematic.
                            Glenn
                            http://www.runnel.com
                            • mariochaM Offline
                              mariocha
                              Hum... I will check.
                              In fact yes, on other shapes it worked ok in 8.
                              Won't be easy to find a non-constant problem.
                              %(#008000)[Mario C.
                                cheriyan
                                Thanks for this plugins
                                • gullfoG Offline
                                  gullfo
                                  @jasper.middelberg said:
                                  yet I discovered that bending will stretch the boards...
                                  does anybody know how this can be solved digitally?
                                  i usually pre-calculate the length of the target shape. e.g. if i have a 4' length and need to bend it in a arc, i figure out the length of the arc so the bent object is the correct length.
                                  it might be simpler to use extrude tools to make the outline of the shape and extrude it. or maybe vertex tools could manipulate the grid correctly...
                                  Glenn
                                    πŸ‘ +1 Measure the line you are bending to first, and make you straight line the exact same length. (this is all funcionality I have planned to add to the next version of this tool if I ever get around to making it). Then make your board the exactly same length also. Then there should be no stretching.
                                      jasper.middelberg
                                      Hello,
                                      perhaps a shot in the dark, hopefully a suggestion or otherwise a cue for anybody that can point me in a good direction to work with this:
                                      An experiment, using standard plywood boards, bolted together.
                                      the idea is that if bending plywood, the structural capacity of the plywood becomes higher,
                                      thus, being able to make a light weight skin roof that can support itself.
                                      Now, my quest is how to bolt a bunch of plywood boards together to form a sort of
                                      conics tipi roof.
                                      I hoped Shapebender would get me there,
                                      draw up a grid of plywood boards and being able to bend them in a desired shape,
                                      in order to find out:
                                      • optimum plywood pattern
                                      • where to make the bolt holes
                                      • where the cutlines would be for top and bottom of the roof
                                      possible workflow:
                                      • to bend the plywood boards around a surface,
                                      • then to be able to make markings on the different boards,
                                      • then to unbend
                                      • and have straight boards again for scaled drawings for:
                                        cut patterns and bolting positions
                                      yet I discovered that Shapebender will stretch the boards...
                                      does anybody know how this can be solved?
                                      the idea of bending plywood I found at
                                      http://conicshelter.com/
                                      thank you,
                                      Jasper
                                      below image
                                      left back: started testing bending boards,
                                      front: a preferred conic shape:
                                        jasper.middelberg
                                        Thank you Chris and Gullfo,
                                        yet, starting point is the standard size of the plywood
                                        and not having to make cuts before hand.
                                        Making use of standard sized plywood,
                                        bend it onto a desired shape,
                                        with an overlap, to be able to determine the boltpositions
                                        and finally know the cutpatterns for top & bottom
                                        I really don't know how this can be modeled in a way it is easy to experiment.
                                        in Sketchup or any 3d software.
                                        yet I guess this workflow might be a bit too much to ask from your plugin,
                                        anyway, I really appreciate your work,
                                        thanks again,
                                        Jasper
                                          Jasper, I've been having a think about how to draw a curve of known length to make the path for Shape Bender. It occurred to me that one could draw a straight line of known length and then use the Radial Bend function of Fredo's FredoScale extension to bend it as desired. You can make irregular curves with it, too. If the line you are bending is a copy of one that you leave straight, you then end up with both of the lines required for Shape Bender.
                                          Of course you could also use Radial Bend to bend the 'plywood' panel. In some cases, though, it might be easier to work on a single line and get it bent as desired and use shape Bender to do the final bend.
                                          • O Offline
                                            oscarfalcon
                                            Hello, I'm new to this forum. I've been using SU for over two years now and really like how it works, specially with all the plug-ins and scripts there are for making things awesome with it.
                                            I have one problem though, I downloaded the shape bender script and the progressbar.rb file but SU7 doesn't seem to recognize them, any help here would be great. I'm using a mac as of today, I placed the files in the plug-ins folder and can't seem to find them in sketch up.
                                            Cheers, wonderful SU community.
                                            OFL
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 63
                                            • 64
                                            • 52 / 64
