    [Plugin] Front Face - 1.2
    57 Posts 29 Posters 88.9k Views 29 Watching
    • T
      tomasz
      Any progress on changing the cursor Tomasz?
      I am using it today and was just curious. Handy tool BTW.
      Checked the API. It looks easy...
      • GaieusG
        Guys, I am amazed at the helpfulness of all of you.
        Once I win this combpetition, I hope you will all come and enjoy the party.
        (BTW I am planning a difficult plugin - you will hate me...)
          In the meanwhile, before it gets written into something better - to make ALL rear faces in the model [and faces inside definitions too] have the default material on their backs, just copy and paste this line of code into the Ruby Console - I compressed it into one line for ease of pasting...
          m=Sketchup.active_model;es=m.entities;es.each{|e|e.back_material=nil if e.class==Sketchup;;Face};ds=m.definitions;ds.each{|d|d.entities.each{|e|e.back_material=nil if e.class==Sketchup;;Face}};return nil
          • T
            tomasz
            Ok. I said I was busy, but I had to refresh my memory, how to write a Tool in SU, so played with FrontFace and here we go:
            Version 1.2 is ready.
            Greetings
            Tomasz
            • boofredlayB
              boofredlay
              Beautiful. Thank you. 👍
              • E
                Ecuadorian
                TIG, this is probably one of the most useful pieces of code ever. Thank you very much. 👍
                -Miguel Lescano
                • FletchF
                  Fletch
                  TIG, does it also make all groups and components have the default material? (in case one or two got accidentally painted somehow?)
                  Fletch
                  • E
                    Ecuadorian
                    Fletch, Matthieu Noblet wrote a plugin for that:
                    http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                    -Miguel Lescano
                      No, it fixes back_materials inside them, but not materials applied to them - to do that you need this line...
                      Sketchup.active_model.definitions.each{|d|d.instances.each{|i|i.material=nil}}
                        Royvas
                        gosh thank you so much for this 😄 works great
                        • alvisA
                          alvis
                          Tomasz
                          • Z
                            Zacchia
                            Hi Tomasz
                            I have found now this plugin!! This is fantastic. Thanks a lot!
                            • Z
                              Zacchia
                              Thomasz
                              It seams that when material is on normal face and i use this plugin then material will be default SU material when turned the faces. Why is it like this? I think it should keep material and just turn faces.
                                Jrudd
                                Hi all,
                                Proud to announce that there is finally a solution to the face flipping problem. You can now reverse faces and preserve UV coordinates! I tested it and the results are accurate!
                                The UV Toolkit makes it possible. You also need to download the TT_Lib and put it in your plugins folder.
                                To reverse a face, first select what you want reversed, then go to Plugins > UV Toolkit > Frontface material to Backface (or the opposite).
                                Hope it helps,
                                Jeremy
                                  simoni
                                  I find it works 50% of the time, sometimes textures are mapped wrongly, maybe I am doing something wrong?
                                  • N
                                    Need2SeeAttachments
                                    LOOK AT MY USER NAME, ENOUGH SAID. Need2SeeAttachments.
                                    I WANT TO DOWNLOAD, NOW BYE FOREVER SKETCHUCATION.
                                    Meant no offence, k thx bai.
                                      Bye bye.
                                        desunvn
                                        Thank you for plugin this
                                        • danchoD
                                          dancho
                                          Hi Tomasz,
                                          I was installed Fredo Additional Plugin folder plugin http://sketchucation.com/forums/viewtopic.php?p=345150#p345150
                                          and have a problem with finding icons if I use your plugin in another dir.
                                          Its only work with Sketchup 2013/Plugins place. Can you look at this?
                                          Regards,
                                          Daniel
                                            @dancho said:
                                            Hi Tomasz,
                                            Regards,
                                            Daniel
                                            This is an old script...
                                            You are unlikely to get it chnaged now...
                                            BUT you can adjust the tool's code yourself.
                                            It is quite easy...
                                            Open the file frontface.rb using Notepad, or another plain text editor like Notepad++ - BUT NEVER USE a word-processor!
                                            Near the beginning there are three lines that setup the button icons [#36/40/44]
                                            The first line reads:
                                            cursor_path = Sketchup.find_support_file("FrontFaceCursor.png", "Plugins/FrontFace_files")
                                            You must rewrite it to read:
                                            cursor_path = File.join(File.dirname(__FILE__), "FrontFace_files", "FrontFaceCursor.png")
                                            so it now looks in a folder named FrontFace_files that is in the folder with the .rb file [wherever that is located], rather than always the main Plugins folder as the original code sets.
                                            The other two entries for cursor_path = need to be similarly recast, using: FrontFaceCursorOff and FrontFace_OnDef for the .png respectively...
                                            • 3 / 3
