    [Plugin] Front Face - 1.2
    57 Posts 29 Posters 88.9k Views 29 Watching
      @fletch said:
      TIG, does it also make all groups and components have the default material? (in case one or two got accidentally painted somehow?)
      No, it fixes back_materials inside them, but not materials applied to them - to do that you need this line...
      Sketchup.active_model.definitions.each{|d|d.instances.each{|i|i.material=nil}}
      πŸ€“
        Royvas
        gosh thank you so much for this πŸ˜„ works great
        • alvisA
          alvis
          Tomasz
          • Z
            Zacchia
            Hi Tomasz
            I have found now this plugin!! This is fantastic. Thanks a lot!
            • Z
              Zacchia
              Thomasz
              It seams that when material is on normal face and i use this plugin then material will be default SU material when turned the faces. Why is it like this? I think it should keep material and just turn faces.
                Jrudd
                Hi all,
                Proud to announce that there is finally a solution to the face flipping problem. You can now reverse faces and preserve UV coordinates! I tested it and the results are accurate!
                The UV Toolkit makes it possible. You also need to download the TT_Lib and put it in your plugins folder.
                To reverse a face, first select what you want reversed, then go to Plugins > UV Toolkit > Frontface material to Backface (or the opposite).
                Hope it helps,
                Jeremy
                  simoni
                  I find it works 50% of the time, sometimes textures are mapped wrongly, maybe I am doing something wrong?
                  • N
                    Need2SeeAttachments
                    LOOK AT MY USER NAME, ENOUGH SAID. Need2SeeAttachments.
                    I WANT TO DOWNLOAD, NOW BYE FOREVER SKETCHUCATION.
                    Meant no offence, k thx bai.
                      Bye bye.
                        desunvn
                        Thank you for plugin this
                        • danchoD
                          dancho
                          Hi Tomasz,
                          I was installed Fredo Additional Plugin folder plugin http://sketchucation.com/forums/viewtopic.php?p=345150#p345150
                          and have a problem with finding icons if I use your plugin in another dir.
                          Its only work with Sketchup 2013/Plugins place. Can you look at this?
                          Regards,
                          Daniel
                            @dancho said:
                            Hi Tomasz,
                            Regards,
                            Daniel
                            This is an old script...
                            You are unlikely to get it chnaged now...
                            BUT you can adjust the tool's code yourself.
                            It is quite easy...
                            Open the file frontface.rb using Notepad, or another plain text editor like Notepad++ - BUT NEVER USE a word-processor!
                            Near the beginning there are three lines that setup the button icons [#36/40/44]
                            The first line reads:
                            cursor_path = Sketchup.find_support_file("FrontFaceCursor.png", "Plugins/FrontFace_files")
                            You must rewrite it to read:
                            cursor_path = File.join(File.dirname(__FILE__), "FrontFace_files", "FrontFaceCursor.png")
                            so it now looks in a folder named FrontFace_files that is in the folder with the .rb file [wherever that is located], rather than always the main Plugins folder as the original code sets.
                            The other two entries for cursor_path = need to be similarly recast, using: FrontFaceCursorOff and FrontFace_OnDef for the .png respectively...
                            • danchoD
                              dancho
                              Hi TIG,
                              thanks for help, I do it like you wrote
                              class FrontFaceTool
                              def initialize
                              @ip = Sketchup::InputPoint.new
                              cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFaceCursor.png"
                              if cursor_path
                              	@cursor_on = UI.create_cursor(cursor_path, 12, 12)
                              cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFaceCursorOff.png"
                              if cursor_path
                              	@cursor_off = UI.create_cursor(cursor_path, 12, 12)
                              cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFace_OnDef.png"
                              if cursor_path
                              	@cursor_on_def= UI.create_cursor(cursor_path, 12, 12)
                              and receive this error message, have you any idea?
                              THX
                              Dancho
                                You have mistyped.
                                It should be:
                                cursor_path = File.join(File.dirname(__FILE__), "FrontFace_files", "FrontFaceCursor.png"**)**
                                The error message tells you the error...
                                Add the final ) to the three lines and it will work OK...
                                  samothrace41
                                  A great THANK YOU Tomasz !!!
                                    A Former User
                                    Is the current FaceFront ruby current with SU 2015 version? I downloaded it and installed it in my Plug in file but it doesn't show up. Any thoughts
                                      Hi Tom,
                                      Small world. πŸ˜‰
                                      So did you try installing it with the SCF PluginStore plugin? Or did you download the file as .rbz from here?
                                      • 3 / 3
