    1.3k Posts 299 Posters 2.5m Views 297 Watching
      Daniel S
      The idea was a result like this for that model:
      Is better to make the loft in parts and not all togheter in a lot of cases.
      For example, I´m making a shape where two contours share edges.
      it is better to make a loft between 1-2-3, then explode and after that make the loft 4-5 for better results:
      I attach the skp to show that if you make a loft of 1-2-3-4-5 the results are not good in this case.
      Daniel S
      shape.skp
      • fredo6F Offline
        [attachment=6:fuxjwvvf]<!-- ia6 -->pencil.JPG<!-- ia6 -->[/attachment:fuxjwvvf]Daniel S
        For the pencil, use the regular Bezier method (first method) instead of Cubic Bezier (default method).
        [attachment=0:fuxjwvvf]<!-- ia0 -->Pencil Loft Daniel S.png<!-- ia0 -->[/attachment:fuxjwvvf]
        PS: for the other shape, there are still some issues when curves are partially overlapping. But it is a good example I can work from.
          I've yet to try out this plugin for myself - but is there a linear option as well? Or is it just beziers? It seems to be that the pencil would require a linear morphing to get the shape of the tip.
          • fredo6F Offline
            The Linear option will be available in the next release (along with other spline methods). I came to that conclusion too.
            • Bob JamesB Offline
              Bob James
              Just came across this wonderful and amazing new tool.
              I'm pretty much speechless: incredible 🎉
              This opens up soooo many possibilities. Thank you for this great tool
                KarinaGM
                I haven't even had time to use it and I am already in love with this plugin.
                Thanks Fredo
                **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                -Benjamín Franklin.**
                  A little use of it 😉
                  Grow by Tig
                  Curviloft by Fredo6
                  FredoScale by Fredo6
                  http://forums.polyloop.net/picture.php?albumid=23&pictureid=803
                  http://forums.polyloop.net/picture.php?albumid=23&pictureid=804
                  • charly2008C Offline
                    charly2008
                    I tried with Curviloft the to make the ornaments in this historic door . But it does not look good. I have to try other shapes. In the rendered image it looks like a Crab.
                    • N Offline
                      notareal
                      [attachment=0:12mbvobp]<!-- ia0 -->Pencil for Loft - Daniel S - linear.gif<!-- ia0 -->[/attachment:12mbvobp]
                      You cannot stop amaze! This already is a true gem. Wonder to what it will grow...
                        Daniel S
                        I just see:
                        http://forums.sketchucation.com/viewtopic.php?f=18&t=29374#p256698
                        And made me wonder... would be possible something like this?
                        Daniel S
                          charly2008
                          I have further experimented with Curivloft. But for those stone sculptures, it seems to be less suitable. The current forms I have generated by the standard tools, the Freehand tool, Push Pull and Subdivide and Smooth.
                            Notice that the numbers for each profile alternates throughout your pre-selecting.
                              I would think Fredo's tool superior to my EEbyLoft... BUT mine works with some componentizing and exploding etc !
                              Fredo, please borrow whatever ideas work in my tool for yours !
                              Capture.PNGcurviloft5.skp
                              • massimoM Offline
                                massimo Moderator
                                Charly, try like this:
                                -Select, lets say, four profiles. Explode them and press the loft button;
                                -Select the two profiles on the ends of two stumps and press loft. Do that for all the stumps;
                                -Delete the unwanted original profiles.
                                curviloft5-2_street.skp
                                  charly2008
                                  In this design I get some errors. The idea was to create a road profile. I have selected the faces one by one. Maybe Fredo can find the error. Even in a straight line this error will appear.
                                  Charly
                                  curviloft5.skp
                                  • mitcorbM Offline
                                    mitcorb
                                    In Fredo6's discussion in the first post, I saw something that suggested to leave open a tiny segment in the profile to be lofted. Perhaps to prevent the twisting?
                                      charly2008
                                      Dear TIG and Massimo,
                                      thank you for your advices. The background for my experiments with a winding road is the representation of the curve slope.
                                      With EEbyLoft I have also tried. TIG, your EEbyL is also a great tool. I would not belittle your merits. But in this case it is difficult to find the correct level for the protractor because the Edges. With Curviloft i can use faces and I can change the faces more simple(made by Perpendiculare Faces) gradually at an specified angle and can construct the slope. And this worked in my first attempt (see pictures below).
                                      You may have seen my posts with winding Roads in the forum. The disadvantage of these Roads was, that the road profile was shown only horizontal in the curves.
                                      Charly
                                      • fredo6F Offline
                                        NEW BETA RELEASE
                                        Curviloft 1.0b – LibFredo6 3.5b – 11 Jul 10: Second beta version, dedicated to Loft by Spline and Skinning (Loft Along Path is still not fully functional). Main changes are:
                                        • Skinning should better accept preselection of contours and make its way to create the mesh
                                        • Added some spline methods (Linear, Ortho-elliptic and ortho-spline)
                                        • For Skinning and Loft Along Path, you can over-sample the rails
                                        • For Skinning, you can swap the direction between contours and rails
                                        • Preview Mesh is normally black in SU7
                                        • Floating palette remembers its position across SU sessions
                                        • Spanish translation by Defisto
                                          On top of potential bugs and geometry issues (including bugsplats), there are some limitations and unfinished work
                                        • VCB is not active
                                        • No interactive edition in the floating palette
                                        • B-Spline and F-Spline do not close nicely in loop mode
                                        • No later reedition of shape generated (this will come)
                                        • all texts and labels are not reviewed yet
                                        see main post for download:http://forums.sketchucation.com/viewtopic.php?f=323&t=28586#p248195
                                        • fredo6F Offline
                                          Charly,
                                          Thanks very much for your deep testing of Curviloft. It helps me find and hopefully fix the many bugs and imprecisions remaining in the script. This is why I judged that I had to go through a long beta phase with the users.
                                          For the long and winding roads, I have found the issues and they should be adressed in the next release 1.0b.
                                            dylan
                                            Thanks Fredo 👍
                                            http://dmdarchitecture.co.uk/
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 65
                                            • 66
                                            • 36 / 66
