    1.3k Posts 299 Posters 3.0m Views 297 Watching
      grim
      fredo
      thanks for the pointers, they work... there seems to be a lot more to using this tool than i realise, i am getting the hang of it slowly
        dolphus
        Thank you for the quick reply, I thought i had put the folder in i have now and it works
        Thank you very much
        • fredo6F Offline
          @daniel s said:
          Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
          Daniel S
          I missed this one.
          Here is the result, with Loft by Spline
          Pencil for loft.skp
            grim
            danial
            tried you shape file and came up with very different results see attached file
            can you enlighten me as to where i am going wrong as i followed your instructions as well as trying one of my own
            regards
            david
            grimshape.skp
              Daniel S
              You can select all the contours to make the loft:
              You will see that there is a problem with the default method.. try to change it with the toolbar for different results:
              Or you can make it in two parts (for this model I wanted this result):
              Daniel S
                Daniel S
                The idea was a result like this for that model:
                Is better to make the loft in parts and not all togheter in a lot of cases.
                For example, I´m making a shape where two contours share edges.
                it is better to make a loft between 1-2-3, then explode and after that make the loft 4-5 for better results:
                I attach the skp to show that if you make a loft of 1-2-3-4-5 the results are not good in this case.
                Daniel S
                shape.skp
                • fredo6F Offline
                  [attachment=6:fuxjwvvf]<!-- ia6 -->pencil.JPG<!-- ia6 -->[/attachment:fuxjwvvf]Daniel S
                  For the pencil, use the regular Bezier method (first method) instead of Cubic Bezier (default method).
                  [attachment=0:fuxjwvvf]<!-- ia0 -->Pencil Loft Daniel S.png<!-- ia0 -->[/attachment:fuxjwvvf]
                  PS: for the other shape, there are still some issues when curves are partially overlapping. But it is a good example I can work from.
                    I've yet to try out this plugin for myself - but is there a linear option as well? Or is it just beziers? It seems to be that the pencil would require a linear morphing to get the shape of the tip.
                    • fredo6F Offline
                      The Linear option will be available in the next release (along with other spline methods). I came to that conclusion too.
                      • Bob JamesB Offline
                        Bob James
                        Just came across this wonderful and amazing new tool.
                        I'm pretty much speechless: incredible 🎉
                        This opens up soooo many possibilities. Thank you for this great tool
                          KarinaGM
                          I haven't even had time to use it and I am already in love with this plugin.
                          Thanks Fredo
                          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                          -Benjamín Franklin.**
                            A little use of it 😉
                            Grow by Tig
                            Curviloft by Fredo6
                            FredoScale by Fredo6
                            http://forums.polyloop.net/picture.php?albumid=23&pictureid=803
                            http://forums.polyloop.net/picture.php?albumid=23&pictureid=804
                            • charly2008C Offline
                              charly2008
                              I tried with Curviloft the to make the ornaments in this historic door . But it does not look good. I have to try other shapes. In the rendered image it looks like a Crab.
                              • N Offline
                                notareal
                                [attachment=0:12mbvobp]<!-- ia0 -->Pencil for Loft - Daniel S - linear.gif<!-- ia0 -->[/attachment:12mbvobp]
                                You cannot stop amaze! This already is a true gem. Wonder to what it will grow...
                                  Daniel S
                                  I just see:
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  And made me wonder... would be possible something like this?
                                  Daniel S
                                    charly2008
                                    I have further experimented with Curivloft. But for those stone sculptures, it seems to be less suitable. The current forms I have generated by the standard tools, the Freehand tool, Push Pull and Subdivide and Smooth.
                                      Notice that the numbers for each profile alternates throughout your pre-selecting.
                                        I would think Fredo's tool superior to my EEbyLoft... BUT mine works with some componentizing and exploding etc !
                                        Fredo, please borrow whatever ideas work in my tool for yours !
                                        Capture.PNGcurviloft5.skp
                                        • massimoM Offline
                                          massimo Moderator
                                          Charly, try like this:
                                          -Select, lets say, four profiles. Explode them and press the loft button;
                                          -Select the two profiles on the ends of two stumps and press loft. Do that for all the stumps;
                                          -Delete the unwanted original profiles.
                                          curviloft5-2_street.skp
                                            charly2008
                                            In this design I get some errors. The idea was to create a road profile. I have selected the faces one by one. Maybe Fredo can find the error. Even in a straight line this error will appear.
                                            Charly
                                            curviloft5.skp
                                            • 11
                                            • 12
                                            • 65
                                            • 66
                                            • 10 / 66
