    1.3k Posts 300 Posters 3.2m Views 298 Watching
    • halroachH
      halroach
      As all of your wonderful plugins!
      Very nice fredo!
      FlexTools - Super Quick Windows, Doors, Slats...
        dolphus
        Fredo I am a big fan of your work, i hang my head in shame and confess that i cannot get the Curvilot to work when i start uo SU i get the following message " Module Curviloft requires LibFredo6 version greater than 35. Current version is 34" but i do have Version 35 in the plugin dir as well as 34 if i remove the 34 many of my other Fredo plugins work is it possible for anyone to diagnose my problem?
        Thanks in anticipation
        • fredo6F
          @grim said:
          fredo and charly
          this tool is fantastic, however after reviewing the examples posted by charly i was eager to try them out for myself but when it came time to try step 3 if found that the curviloft menue did not display the same information nor did the black backround profile menu appear i have sinced removed all rubies and reloaded only the latest from you posting to see if i had installed it incorrectly however i get the same responce
          can you enlighten me as to the problem or is there somthing i am over looking
          thanks
          Maybe you just need to click on a junction to get the floating palette appear, if it is your problem.
          • fredo6F
            Check out if you have a subfolder named LIBFREDO6_Dir_35 in the Plugins directory. Normally, the script automatically select the latest version of LibFredo6
            • G
              grim
              fredo
              thanks for the pointers, they work... there seems to be a lot more to using this tool than i realise, i am getting the hang of it slowly
                dolphus
                Thank you for the quick reply, I thought i had put the folder in i have now and it works
                Thank you very much
                • fredo6F
                  @daniel s said:
                  Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
                  Daniel S
                  I missed this one.
                  Here is the result, with Loft by Spline
                  Pencil for loft.skp
                  • G
                    grim
                    danial
                    tried you shape file and came up with very different results see attached file
                    can you enlighten me as to where i am going wrong as i followed your instructions as well as trying one of my own
                    regards
                    david
                    grimshape.skp
                      Daniel S
                      You can select all the contours to make the loft:
                      You will see that there is a problem with the default method.. try to change it with the toolbar for different results:
                      Or you can make it in two parts (for this model I wanted this result):
                      Daniel S
                        Daniel S
                        The idea was a result like this for that model:
                        Is better to make the loft in parts and not all togheter in a lot of cases.
                        For example, I´m making a shape where two contours share edges.
                        it is better to make a loft between 1-2-3, then explode and after that make the loft 4-5 for better results:
                        I attach the skp to show that if you make a loft of 1-2-3-4-5 the results are not good in this case.
                        Daniel S
                        shape.skp
                        • fredo6F
                          [attachment=6:fuxjwvvf]<!-- ia6 -->pencil.JPG<!-- ia6 -->[/attachment:fuxjwvvf]Daniel S
                          For the pencil, use the regular Bezier method (first method) instead of Cubic Bezier (default method).
                          [attachment=0:fuxjwvvf]<!-- ia0 -->Pencil Loft Daniel S.png<!-- ia0 -->[/attachment:fuxjwvvf]
                          PS: for the other shape, there are still some issues when curves are partially overlapping. But it is a good example I can work from.
                            I've yet to try out this plugin for myself - but is there a linear option as well? Or is it just beziers? It seems to be that the pencil would require a linear morphing to get the shape of the tip.
                            • fredo6F
                              The Linear option will be available in the next release (along with other spline methods). I came to that conclusion too.
                              • Bob JamesB
                                Bob James
                                Just came across this wonderful and amazing new tool.
                                I'm pretty much speechless: incredible 🎉
                                This opens up soooo many possibilities. Thank you for this great tool
                                • K
                                  KarinaGM
                                  I haven't even had time to use it and I am already in love with this plugin.
                                  Thanks Fredo
                                  **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                                  -Benjamín Franklin.**
                                    A little use of it 😉
                                    Grow by Tig
                                    Curviloft by Fredo6
                                    FredoScale by Fredo6
                                    http://forums.polyloop.net/picture.php?albumid=23&pictureid=803
                                    http://forums.polyloop.net/picture.php?albumid=23&pictureid=804
                                    • charly2008C
                                      charly2008
                                      I tried with Curviloft the to make the ornaments in this historic door . But it does not look good. I have to try other shapes. In the rendered image it looks like a Crab.
                                      • N
                                        notareal
                                        [attachment=0:12mbvobp]<!-- ia0 -->Pencil for Loft - Daniel S - linear.gif<!-- ia0 -->[/attachment:12mbvobp]
                                        You cannot stop amaze! This already is a true gem. Wonder to what it will grow...
                                          Daniel S
                                          I just see:
                                          404 Not Found
                                          (forums.sketchucation.com)
                                          And made me wonder... would be possible something like this?
                                          Daniel S
                                          • charly2008C
                                            charly2008
                                            I have further experimented with Curivloft. But for those stone sculptures, it seems to be less suitable. The current forms I have generated by the standard tools, the Freehand tool, Push Pull and Subdivide and Smooth.
                                            • 11
                                            • 12
                                            • 65
                                            • 66
                                            • 10 / 66
