    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • marleusM Offline
      marleus
      Really cool plugin
      thanks a lot 👍 👍
      Markus Sillander
      Vantaa, Finland
      I'm on FormFonts now
      http://www.formfonts.com
      • N Offline
        notareal
        It still amaze me what this plugin can do
        Perhaps later styling with hair guides? Like in Max or Blender. Not that it have to be so extensive, but in a spirit of those.
          paulower
          @autarchos said:
          Dear Mr. Paulo Wer: That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
          Besten Grüßen,
          Drazen Petrovic
          Yes, sure I can explain:
          1 - I created a normal plane in SketchUp and used the Sandbox tool SketchUp to create the topography of the land;
          2 - I used two maps (two textures) of different grass. A grass that is normal, and the other is like a bush (do not know how to say it in English).
          • Do not forget to apply the texture on both sides, ie, in the back and front face.
          **3 -**Create a component for each texture (one for the grass normal and other to grass bush);
          **4 -**In the Settings Window FUR, I made the adjustments and settings required, such as:
          • TopJitter (%): 1
          • Direction (X): 0mm
          • Direction (Y): 0mm
          • Direction (Z): 500m or 5000m (not mm. That in my example)
          • In the menu drop down "Make by Component", choose the component that you created;
          5 - Click on Make Fur;
          **6 -**I did the render in V-Ray for SketchUp. In V-Ray only applied the map Alpha in Diffuse;
          I still do not know for sure the function of all commands, but recommend you do the tests in Make FUR. If you want the maps are on the links below:
          File - Map Alpha Mask
          File - Map Grass
          _______________________________
          My Blog
          Baú SketchUp
          Baú SketchUp
          Visite nosso blog.. Visit our blog Baú SketchUp
            paulower: that's a nice setup. Thanks for sharing.
              @tak2hata said:
              Sorry ,Now I examines the method to remember dialog position.
              That demands the javascript knowledge from me.
              I will update few day later.
              No need for javasscript to remember the window's position. SU does this for you if you specify a preference key.
              Error 404 (Not Found)!!1
              (code.google.com)
              pref_key
              The registry entry where the location and size of the dialog will be saved. If preferences_key is not included, the location and size will not be stored.
                jaceguay
                Nothing happend when i click make fur, the ruby console show this:
                Error: #<TypeError: no implicit conversion to float from nil>
                C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
                C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
                Does anyone know what can be done to adress this error?
                  jeabdc
                  ThankY ขอบคุณมากครับ
                  • Didier BurD Offline
                    Didier Bur
                    After taking a look at the code, line 541 has something to do with "Direction (X)" Y and Z factors.
                    Yours are undefined (nil), so check your values in the dialog box and try to change them with something else than zero and see if it works. Check your decimal "," or "." too.
                    Hope this helps,
                    DB
                      jaceguay
                      Thanks for the fast response, changing the values return another error:
                      C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in new'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in show_webdialog' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:792:in call'
                        jonorman
                        same problem here. after installing last version..
                        C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
                        C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
                        buuuuhuuuuu... miss my fur/grass plugin 😢
                          tak2hata
                          I uploaded version1.4.
                          Change is...
                          Remember webdialog position.(Thanks thomthom 😄 )
                          Add new mode "Crowd".(Multi Instance scattering.)
                          In this version ,I changed convert string to length method little.
                          When that error is happened , I want look your dialog parameter.
                          I think problem is around "s_to_l" method.
                          @thiloo said:
                          thanks tak2hata for the quick explanation,
                          wow, that´s also an powerful feature.
                          sadly it´s not working if I choose "make by component - yes"!
                          also, with component activated, the reaction to the force settings are quite unexpected?
                          [attachment=0:367xbin3]<!-- ia0 -->fur_force.jpg<!-- ia0 -->[/attachment:367xbin3]
                          I need the components for instancing -> rendering.
                          again, Thank You for your time and effort
                          "make by component -- yes" was added after making this plugin.
                          This plugin originaly use for "make by component -- no".
                          I do not have good way to componentinstance direction control.
                          When I find good way,I will change it.
                          Thanks.
                          by TAK2HATA
                            sloof
                            how to use this ?
                            somebody help me please ?
                              jonorman
                              screen dump of SU trying to use fur.
                                tak2hata
                                Hi,jonorman.
                                I updated version 1.4a.
                                Sorry,I forgat changing "s_to_l".
                                now it changed.
                                It may be work.
                                by TAK2HATA
                                  tak2hata
                                  @sloof said:
                                  how to use this ?
                                  Hi,sloof.
                                  http://forums.sketchucation.com/viewtopic.php?f=323&t=28092
                                  [url=http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html:1j014hsy]http://sketchupdate.blogspot.com/[/url:1j014hsy]
                                  It may help.
                                  Thanks.
                                  by TAK2HATA
                                    jonorman
                                    JIPPIIIIII ! ! ! ! Back in bizzniz 😍 👍 ☀
                                      tomot
                                      WOW! .....another great Plugin,
                                      This pampas grass looks better that the real stuff in my planter 😄
                                      Thanks! tak2hata
                                      my plugins
                                      tomot
                                        Didier Bur
                                        Got this error when using "make crowd" without having a "fur_instance" component in my model:
                                        Error: #<TypeError: wrong argument type (expected Sketchup::ComponentDefinition)>
                                        C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1272:in `add_instance'
                                        I guess the script does not check wether the relevant component is in the model or not ? 💭
                                        It works OK if a "fur_instance" component is present.
                                        After deleting the fur instance component, hit "CheckOnAll", and it is still there, and the makecrowd doesn't work anymore if I let its checkbox ticked.
                                        DB
                                          Stu
                                          Ive been using fur for a while ...with good results, and just loving it!! 👍
                                          However I've struck a problem as in the attached....it seems to be the cut off angle that is upsetting the geometry.....if I try a square or rectangular plane it behaves normally.
                                          http://www.landesign.com.au
                                            tak2hata
                                            @paulower said:
                                            This is the translation of Make Fur to languaje Portuguese-BR (Brazil) by me.
                                            Tak2hata would be possible in the next version, you increase the size of the buttons "Assign Material to" and "Get Stuff From." Is that in Portuguese, we have more characters in the translation and some letters may not appear on the icon (button).
                                            You can see who is running smoothly letters with accents and numerical symbols.
                                            Thanks paulowr.
                                            I add language list on first thread.
                                            I will increase the size of Buttons in next version.
                                            Hi , Stu.
                                            That happens in small value of "MaxNumber(/Face)" for the faces.
                                            You should increase "MaxNumber(/Face)" enough.
                                            Thanks.
                                            by TAK2HATA
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 32
                                            • 33
                                            • 14 / 33
