    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      I see the same issue that thiloo describes.
        Hehe - even the Googlers play around with this: http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html
        http://3.bp.blogspot.com/_mDRU50FpD-E/TAALyG_ckXI/AAAAAAAAAMI/geNk8IzxF7Y/s400/WithFur.png
          bryan_gibson79
          As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
          BG
            autarchos
            Didier's Hide Faces/Edges plug-in is one method:
            http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/hide_faces_edges.rb
            BG
            • marleusM Offline
              marleus
              Really cool plugin
              thanks a lot 👍 👍
              Markus Sillander
              Vantaa, Finland
              I'm on FormFonts now
              http://www.formfonts.com
              • N Offline
                notareal
                It still amaze me what this plugin can do
                Perhaps later styling with hair guides? Like in Max or Blender. Not that it have to be so extensive, but in a spirit of those.
                  paulower
                  @autarchos said:
                  Dear Mr. Paulo Wer: That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                  Besten Grüßen,
                  Drazen Petrovic
                  Yes, sure I can explain:
                  1 - I created a normal plane in SketchUp and used the Sandbox tool SketchUp to create the topography of the land;
                  2 - I used two maps (two textures) of different grass. A grass that is normal, and the other is like a bush (do not know how to say it in English).
                  • Do not forget to apply the texture on both sides, ie, in the back and front face.
                  **3 -**Create a component for each texture (one for the grass normal and other to grass bush);
                  **4 -**In the Settings Window FUR, I made the adjustments and settings required, such as:
                  • TopJitter (%): 1
                  • Direction (X): 0mm
                  • Direction (Y): 0mm
                  • Direction (Z): 500m or 5000m (not mm. That in my example)
                  • In the menu drop down "Make by Component", choose the component that you created;
                  5 - Click on Make Fur;
                  **6 -**I did the render in V-Ray for SketchUp. In V-Ray only applied the map Alpha in Diffuse;
                  I still do not know for sure the function of all commands, but recommend you do the tests in Make FUR. If you want the maps are on the links below:
                  File - Map Alpha Mask
                  File - Map Grass
                  _______________________________
                  My Blog
                  Baú SketchUp
                  Baú SketchUp
                  Visite nosso blog.. Visit our blog Baú SketchUp
                    paulower: that's a nice setup. Thanks for sharing.
                      @tak2hata said:
                      Sorry ,Now I examines the method to remember dialog position.
                      That demands the javascript knowledge from me.
                      I will update few day later.
                      No need for javasscript to remember the window's position. SU does this for you if you specify a preference key.
                      Error 404 (Not Found)!!1
                      (code.google.com)
                      pref_key
                      The registry entry where the location and size of the dialog will be saved. If preferences_key is not included, the location and size will not be stored.
                        jaceguay
                        Nothing happend when i click make fur, the ruby console show this:
                        Error: #<TypeError: no implicit conversion to float from nil>
                        C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
                        C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
                        Does anyone know what can be done to adress this error?
                          jeabdc
                          ThankY ขอบคุณมากครับ
                          • Didier BurD Offline
                            Didier Bur
                            After taking a look at the code, line 541 has something to do with "Direction (X)" Y and Z factors.
                            Yours are undefined (nil), so check your values in the dialog box and try to change them with something else than zero and see if it works. Check your decimal "," or "." too.
                            Hope this helps,
                            DB
                              jaceguay
                              Thanks for the fast response, changing the values return another error:
                              C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in new'
                              C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in show_webdialog' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:792:in call'
                                jonorman
                                same problem here. after installing last version..
                                C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
                                C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
                                buuuuhuuuuu... miss my fur/grass plugin 😢
                                  tak2hata
                                  I uploaded version1.4.
                                  Change is...
                                  Remember webdialog position.(Thanks thomthom 😄 )
                                  Add new mode "Crowd".(Multi Instance scattering.)
                                  In this version ,I changed convert string to length method little.
                                  When that error is happened , I want look your dialog parameter.
                                  I think problem is around "s_to_l" method.
                                  @thiloo said:
                                  thanks tak2hata for the quick explanation,
                                  wow, that´s also an powerful feature.
                                  sadly it´s not working if I choose "make by component - yes"!
                                  also, with component activated, the reaction to the force settings are quite unexpected?
                                  [attachment=0:367xbin3]<!-- ia0 -->fur_force.jpg<!-- ia0 -->[/attachment:367xbin3]
                                  I need the components for instancing -> rendering.
                                  again, Thank You for your time and effort
                                  "make by component -- yes" was added after making this plugin.
                                  This plugin originaly use for "make by component -- no".
                                  I do not have good way to componentinstance direction control.
                                  When I find good way,I will change it.
                                  Thanks.
                                  by TAK2HATA
                                    sloof
                                    how to use this ?
                                    somebody help me please ?
                                      jonorman
                                      screen dump of SU trying to use fur.
                                        tak2hata
                                        Hi,jonorman.
                                        I updated version 1.4a.
                                        Sorry,I forgat changing "s_to_l".
                                        now it changed.
                                        It may be work.
                                        by TAK2HATA
                                          tak2hata
                                          @sloof said:
                                          how to use this ?
                                          Hi,sloof.
                                          http://forums.sketchucation.com/viewtopic.php?f=323&t=28092
                                          [url=http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html:1j014hsy]http://sketchupdate.blogspot.com/[/url:1j014hsy]
                                          It may help.
                                          Thanks.
                                          by TAK2HATA
                                            jonorman
                                            JIPPIIIIII ! ! ! ! Back in bizzniz 😍 👍 ☀
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 32
                                            • 33
                                            • 14 / 33
