    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      JollyFather
      Thanks a lot!!!
      Best regards,
      JF
        paulower
        Hello Tak2hata.
        I have spoken these days about the plugin, which is one of the best I've seen so far for our dear SketchUp.
        Is there a way the dialog can remember it's position on the screen? I always expect it to reopen where I put it the previous time. 😄
        Any chance this feature soon?
        Hi,all.
        I updated this plugin to version1.3i.
          Webdialog sees easier.(Thanks Diego.)
          Parameter name translates by langage text file.
        Thanks.
        If you wish, I can provide the translation from Portuguese languaje from Make Fur
        http://i910.photobucket.com/albums/ac301/bausketchup/MakeFUR1.jpg
        http://i910.photobucket.com/albums/ac301/bausketchup/makefur2.jpg
        _______________________________
        My Blog
        Baú SketchUp
        Baú SketchUp
        Visite nosso blog.. Visit our blog Baú SketchUp
          thiloo
          thank you so much, I already love this Plugin!
          some question:
          • what´s the "Valid Distance" for?
            if I choose "make by Component: no"
            and enter something different than 0,000m it´s not working.
            if I choose "make by Component: yes"
            it´s working, but seems to have no effect.
          • Also, if I select "make by Component: yes" the results are looking quite different from when I select no". for example: the force values seem to have stronger impact on component:yes.
            tak2hata
            Hi, thiloo.
            @thiloo said:
            some question:
            The Valid Distance is validate fur about distance from camera.
            So This value is large.like 20m.
            But 0 make all valid.it do not omits fur.
            Example.Use valid distance = 8000mm.
            About Fur_Valid Distance1
            About Fur_Valid Distance2
            About Fur_Valid Distance3
            Hi,paulower.
            Sorry ,Now I examines the method to remember dialog position.
            That demands the javascript knowledge from me.
            I will update few day later.
            Thanks.
            by TAK2HATA
              autarchos
              Dear Mr. Paulo Wer:
              That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
              Besten Grüßen,
              Drazen Petrovic
                thiloo
                thanks tak2hata for the quick explanation,
                wow, that´s also an powerful feature.
                sadly it´s not working if I choose "make by component - yes"!
                also, with component activated, the reaction to the force settings are quite unexpected?
                I need the components for instancing -> rendering.
                again, Thank You for your time and effort
                  I see the same issue that thiloo describes.
                    Hehe - even the Googlers play around with this: http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html
                    http://3.bp.blogspot.com/_mDRU50FpD-E/TAALyG_ckXI/AAAAAAAAAMI/geNk8IzxF7Y/s400/WithFur.png
                      bryan_gibson79
                      As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
                      BG
                        autarchos
                        Didier's Hide Faces/Edges plug-in is one method:
                        http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/hide_faces_edges.rb
                        BG
                        • marleusM Offline
                          marleus
                          Really cool plugin
                          thanks a lot 👍 👍
                          Markus Sillander
                          Vantaa, Finland
                          I'm on FormFonts now
                          http://www.formfonts.com
                          • N Offline
                            notareal
                            It still amaze me what this plugin can do
                            Perhaps later styling with hair guides? Like in Max or Blender. Not that it have to be so extensive, but in a spirit of those.
                              paulower
                              @autarchos said:
                              Dear Mr. Paulo Wer: That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                              Besten Grüßen,
                              Drazen Petrovic
                              Yes, sure I can explain:
                              1 - I created a normal plane in SketchUp and used the Sandbox tool SketchUp to create the topography of the land;
                              2 - I used two maps (two textures) of different grass. A grass that is normal, and the other is like a bush (do not know how to say it in English).
                              • Do not forget to apply the texture on both sides, ie, in the back and front face.
                              **3 -**Create a component for each texture (one for the grass normal and other to grass bush);
                              **4 -**In the Settings Window FUR, I made the adjustments and settings required, such as:
                              • TopJitter (%): 1
                              • Direction (X): 0mm
                              • Direction (Y): 0mm
                              • Direction (Z): 500m or 5000m (not mm. That in my example)
                              • In the menu drop down "Make by Component", choose the component that you created;
                              5 - Click on Make Fur;
                              **6 -**I did the render in V-Ray for SketchUp. In V-Ray only applied the map Alpha in Diffuse;
                              I still do not know for sure the function of all commands, but recommend you do the tests in Make FUR. If you want the maps are on the links below:
                              File - Map Alpha Mask
                              File - Map Grass
                              My Blog
                              Baú SketchUp
                              Baú SketchUp
                                paulower: that's a nice setup. Thanks for sharing.
                                  No need for javasscript to remember the window's position. SU does this for you if you specify a preference key.
                                  http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#new
                                  pref_key
                                  The registry entry where the location and size of the dialog will be saved. If preferences_key is not included, the location and size will not be stored.
                                    jaceguay
                                    Nothing happend when i click make fur, the ruby console show this:
                                    Error: #<TypeError: no implicit conversion to float from nil>
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
                                    Does anyone know what can be done to adress this error?
                                      jeabdc
                                      ThankY ขอบคุณมากครับ
                                      • Didier BurD Offline
                                        Didier Bur
                                        After taking a look at the code, line 541 has something to do with "Direction (X)" Y and Z factors.
                                        Yours are undefined (nil), so check your values in the dialog box and try to change them with something else than zero and see if it works. Check your decimal "," or "." too.
                                        Hope this helps,
                                        DB
                                          jaceguay
                                          Thanks for the fast response, changing the values return another error:
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in new'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in show_webdialog' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:792:in call'
                                            jonorman
                                            same problem here. after installing last version..
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
                                            C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
                                            buuuuhuuuuu... miss my fur/grass plugin 😢
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 32
                                            • 33
                                            • 14 / 33
