    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • T
      tak2hata
      Hi,all.
      I update to verison1.3m.
      It changes LengthPrecision temporary.
      So using units "m" has no problem , now.(perhaps).
      Thanks.
      by TAK2HATA
      • GaieusG
        Yes, this is working, thank tak2hata!
        I can make fur again
        (now just exploring all the settings...)
        • JClementsJ
          JClements
          Gaieus: That's Shaga-delic.
            saturne45
            Hello, very great job... make fur is very nice. thank you.
            • T
              tald311
              Thank you. This is great.
              • C
                Click Draw
                Been playin'....this is very cool! I hope PETA doesn't get wind of this 🤣
                Thanks very much for this!!!
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                  realist
                  Hi, I'm new to Sketchup and about to climb the learning curve.
                  I saw the Fur plugin and thought it would be a cool additon to Sketchup. I clicked on the link to download it but all that does is refresh the page. It doesn't download anything. Am I missing something here? Thanks.Gary
                    JollyFather
                    Thanks a lot!!!
                    Best regards,
                    JF
                    • P
                      paulower
                      Hello Tak2hata.
                      I have spoken these days about the plugin, which is one of the best I've seen so far for our dear SketchUp.
                      Is there a way the dialog can remember it's position on the screen? I always expect it to reopen where I put it the previous time. 😄
                      Any chance this feature soon?
                      Hi,all.
                      I updated this plugin to version1.3i.
                        Webdialog sees easier.(Thanks Diego.)
                        Parameter name translates by langage text file.
                      Thanks.
                      If you wish, I can provide the translation from Portuguese languaje from Make Fur
                      http://i910.photobucket.com/albums/ac301/bausketchup/MakeFUR1.jpg
                      http://i910.photobucket.com/albums/ac301/bausketchup/makefur2.jpg
                      _______________________________
                      My Blog
                      Baú SketchUp
                      Baú SketchUp
                      Visite nosso blog.. Visit our blog Baú SketchUp
                      • T
                        thiloo
                        thank you so much, I already love this Plugin!
                        some question:
                        • what´s the "Valid Distance" for?
                          if I choose "make by Component: no"
                          and enter something different than 0,000m it´s not working.
                          if I choose "make by Component: yes"
                          it´s working, but seems to have no effect.
                        • Also, if I select "make by Component: yes" the results are looking quite different from when I select no". for example: the force values seem to have stronger impact on component:yes.
                        • T
                          tak2hata
                          Hi, thiloo.
                          @thiloo said:
                          some question:
                          The Valid Distance is validate fur about distance from camera.
                          So This value is large.like 20m.
                          But 0 make all valid.it do not omits fur.
                          Example.Use valid distance = 8000mm.
                          About Fur_Valid Distance1
                          About Fur_Valid Distance2
                          About Fur_Valid Distance3
                          Hi,paulower.
                          Sorry ,Now I examines the method to remember dialog position.
                          That demands the javascript knowledge from me.
                          I will update few day later.
                          Thanks.
                          by TAK2HATA
                            autarchos
                            Dear Mr. Paulo Wer:
                            That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                            Besten Grüßen,
                            Drazen Petrovic
                            • T
                              thiloo
                              thanks tak2hata for the quick explanation,
                              wow, that´s also an powerful feature.
                              sadly it´s not working if I choose "make by component - yes"!
                              also, with component activated, the reaction to the force settings are quite unexpected?
                              I need the components for instancing -> rendering.
                              again, Thank You for your time and effort
                                I see the same issue that thiloo describes.
                                  Hehe - even the Googlers play around with this: http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html
                                  http://3.bp.blogspot.com/_mDRU50FpD-E/TAALyG_ckXI/AAAAAAAAAMI/geNk8IzxF7Y/s400/WithFur.png
                                  • B
                                    bryan_gibson79
                                    As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
                                    BG
                                      autarchos
                                      Didier's Hide Faces/Edges plug-in is one method:
                                      http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/hide_faces_edges.rb
                                      BG
                                      • marleusM
                                        marleus
                                        Really cool plugin
                                        thanks a lot 👍 👍
                                        Markus Sillander
                                        Vantaa, Finland
                                        I'm on FormFonts now
                                        http://www.formfonts.com
                                        • N
                                          notareal
                                          It still amaze me what this plugin can do
                                          Perhaps later styling with hair guides? Like in Max or Blender. Not that it have to be so extensive, but in a spirit of those.
                                          • P
                                            paulower
                                            @autarchos said:
                                            Dear Mr. Paulo Wer: That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                                            Besten Grüßen,
                                            Drazen Petrovic
                                            Yes, sure I can explain:
                                            1 - I created a normal plane in SketchUp and used the Sandbox tool SketchUp to create the topography of the land;
                                            2 - I used two maps (two textures) of different grass. A grass that is normal, and the other is like a bush (do not know how to say it in English).
                                            • Do not forget to apply the texture on both sides, ie, in the back and front face.
                                            **3 -**Create a component for each texture (one for the grass normal and other to grass bush);
                                            **4 -**In the Settings Window FUR, I made the adjustments and settings required, such as:
                                            • TopJitter (%): 1
                                            • Direction (X): 0mm
                                            • Direction (Y): 0mm
                                            • Direction (Z): 500m or 5000m (not mm. That in my example)
                                            • In the menu drop down "Make by Component", choose the component that you created;
                                            5 - Click on Make Fur;
                                            **6 -**I did the render in V-Ray for SketchUp. In V-Ray only applied the map Alpha in Diffuse;
                                            I still do not know for sure the function of all commands, but recommend you do the tests in Make FUR. If you want the maps are on the links below:
                                            File - Map Alpha Mask
                                            File - Map Grass
                                            My Blog
                                            Baú SketchUp
                                            Baú SketchUp
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 32
                                            • 33
                                            • 14 / 33
