    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • EarthMoverE
      EarthMover
      Holy crap!!! Is that speed realtime? Looks amazing! Do the number of segments in the rails matter? Could this possibly be used to replace the standard from contours in the sandbox tools to create graded terrains?
      Content Creator at Skapeup
      • X
        xrok1
        WOW! i love how you ruby greats are dragging SU kicking and screaming into the realm of a "real" 3d modeling program! 😍
        screw you google. if you won't give us proper tools someone will. πŸ‘Ώ
        thanks Fredo, and everyone; TIG, ThomThom, Chris, Jim, Dedier, Whaat... just to name a few. you guys ARE the real SU team. all we really need from google is poly support. you guys cover the rest.
        http://twilightrender.com/phpBB3/images/smilies/Respect.gif
        • V
          vidy
          BRAVO FREDO πŸŽ‰
          still so much to learn..
          • P
            Panga
            Really big thanks for investing so much time to give us so niceeeee plugins !! I'll try to post a file to test it on terrain modelling, which is my main occupation in SU.
              Looking very nice. Can one edit the control splines afterwards?
              1:24 - Float Pal window: is that done using view.draw* method?
                The Fredo return! 😎
                What a teaser! πŸ€“
                What about make a thickness to a surface?
                • fredo6F
                  The Fredo return! 😎
                  What a teaser! πŸ€“
                  I guess this is a job for JPP. Curviloft only generates the thin surface.
                  • fredo6F
                    Tom,
                    Yes the button palettes are all based on view.draw methods. And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
                      As ever, a "tour de force".
                      Can't wait to try your new tools...
                      Very impressive interface and speed.
                      πŸŽ‰
                      • CadFatherC
                        CadFather
                        sugar.. everytime Fredo starts these things, it's like another copernican revolution! πŸ˜†
                          [attachment=0:3bpbsi8t]<!-- ia0 -->Float palette.gif<!-- ia0 -->[/attachment:3bpbsi8t]
                          Is that adjustments one makes before you end the tool? Or can you take a shape you created earlier and readjust it? On other words, is it parametric?
                          • fredo6F
                            [attachment=0:x5clniez]<!-- ia0 -->Float palette.gif<!-- ia0 -->[/attachment:x5clniez]
                            It's difficult to make things parametric in Sketchup, because all you have at the end is faces and edges.
                            My plan to help a little bit would be to attach some information to the Component created so that you can reedit later on.
                            also, and already working is the possibility to generate the juctions as curves so that when you move the profiles, then the shape deforms accordingly (something that is shown in Kirill's scripts).
                              Yea - it was something like that I was wondering if it would do. Very promising!
                              Once I get Vertex Edit out of the way I want to make Bezier Path modelling tools. The control points stored as attributes for later edit-ability. Of course, if the user was to edit the geometry with other tools that would be ignored.
                              If the observers behave better in the next SU I want to make modifiers that one can apply to groups/components. Stack them up and apply the modifications after the user edit the base shape.
                              • N
                                notareal
                                Stunning! What a return.
                                • Mike LuceyM
                                  Mike Lucey
                                  I think I've figured out how Fredo is doing all this fantastic work ...... if you listen carefully to the video you will hear a lot of squeeking going on in the background ....... well these can only be Creative Gremlins! πŸ‘
                                  • olisheaO
                                    olishea
                                    wow 😲
                                    oli
                                      JPP : the "Jean Pierre Papin des surfaces" πŸ˜‰
                                      ( a famous French footballer πŸ˜‰
                                      [flash=480,385:2ce7u8sg]http://www.youtube.com/v/OgTMXQ2mtfA&hl[/flash:2ce7u8sg]
                                      • jim smithJ
                                        jim smith
                                        Big thanks in advance for creating this plugin. 😍 Frank Gehry will probably be switching to GSU pretty soon if Fredo keep this up πŸ˜’
                                        "Out of clutter find simplicity,
                                        from discord find harmony,
                                        In the middle of difficulty lies opportunity"
                                        Albert Einstein
                                        • shuraS
                                          shura
                                          Omg, we are drowning in pleasant anticipation!
                                            Rainie
                                            Hi all,
                                            where we can download this very helpful plugin!!! Thanks!!!
                                            • 65
                                            • 66
                                            • 1 / 66
