    1.3k Posts 300 Posters 3.3m Views 298 Watching
      Looking very nice. Can one edit the control splines afterwards?
      1:24 - Float Pal window: is that done using view.draw* method?
        The Fredo return! 😎
        What a teaser! πŸ€“
        What about make a thickness to a surface?
        • fredo6F
          The Fredo return! 😎
          What a teaser! πŸ€“
          I guess this is a job for JPP. Curviloft only generates the thin surface.
          • fredo6F
            Tom,
            Yes the button palettes are all based on view.draw methods. And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
              As ever, a "tour de force".
              Can't wait to try your new tools...
              Very impressive interface and speed.
              πŸŽ‰
              • CadFatherC
                CadFather
                sugar.. everytime Fredo starts these things, it's like another copernican revolution! πŸ˜†
                  [attachment=0:3bpbsi8t]<!-- ia0 -->Float palette.gif<!-- ia0 -->[/attachment:3bpbsi8t]
                  Is that adjustments one makes before you end the tool? Or can you take a shape you created earlier and readjust it? On other words, is it parametric?
                  • fredo6F
                    [attachment=0:x5clniez]<!-- ia0 -->Float palette.gif<!-- ia0 -->[/attachment:x5clniez]
                    It's difficult to make things parametric in Sketchup, because all you have at the end is faces and edges.
                    My plan to help a little bit would be to attach some information to the Component created so that you can reedit later on.
                    also, and already working is the possibility to generate the juctions as curves so that when you move the profiles, then the shape deforms accordingly (something that is shown in Kirill's scripts).
                      Yea - it was something like that I was wondering if it would do. Very promising!
                      Once I get Vertex Edit out of the way I want to make Bezier Path modelling tools. The control points stored as attributes for later edit-ability. Of course, if the user was to edit the geometry with other tools that would be ignored.
                      If the observers behave better in the next SU I want to make modifiers that one can apply to groups/components. Stack them up and apply the modifications after the user edit the base shape.
                      • N
                        notareal
                        Stunning! What a return.
                        • Mike LuceyM
                          Mike Lucey
                          I think I've figured out how Fredo is doing all this fantastic work ...... if you listen carefully to the video you will hear a lot of squeeking going on in the background ....... well these can only be Creative Gremlins! πŸ‘
                          • olisheaO
                            olishea
                            wow 😲
                            oli
                              JPP : the "Jean Pierre Papin des surfaces" πŸ˜‰
                              ( a famous French footballer πŸ˜‰
                              [flash=480,385:2ce7u8sg]http://www.youtube.com/v/OgTMXQ2mtfA&hl[/flash:2ce7u8sg]
                              • jim smithJ
                                jim smith
                                Big thanks in advance for creating this plugin. 😍 Frank Gehry will probably be switching to GSU pretty soon if Fredo keep this up πŸ˜’
                                "Out of clutter find simplicity,
                                from discord find harmony,
                                In the middle of difficulty lies opportunity"
                                Albert Einstein
                                • shuraS
                                  shura
                                  Omg, we are drowning in pleasant anticipation!
                                    Rainie
                                    Hi all,
                                    where we can download this very helpful plugin!!! Thanks!!!
                                      @rainie said:
                                      Hi all,
                                      When it is released. This was just a teaser. πŸ˜‰
                                      • soloS
                                        Fredo strikes again!!
                                        Looking forward to another true Gem.
                                          DIEGO-RODRIGUEZ
                                          fredo, great plugins. thank you very much for their continued contributions to the user of sketchup
                                          two questions.
                                          floating panel interface, which uses programming language?
                                          you can use images *. png or other format for icons?
                                          when can download the first version of the plugins?
                                          • fredo6F
                                            It is written in pure Ruby and SU API (which makes it portable PC and Mac).
                                            Unfortunately, png cannot be used (the SU API is missing this functionality, but it would be a good idea to add it)
                                            Probably not before a month, except if I released only a subset.
                                            This is also why I need to have some sample geometry, beyond what I am doing test with, because I prefer to adapt the algorithm before the script is released)
