    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • H Offline
      hsjzyangbin
      wish to have a visual interface control nodes of the function like YAD
      here is an example:
      best regards
        Daniel S
        here is an example:
        About visual interface control nodes... Something like this is possible? (Like most 2d Vector software)
        "A quadratic Bézier curve has a start and an end point (blue dots) and just one control point (red dot) while a cubic Bézier curve uses two control points."
        404 Not Found
        (www.caffeineowl.com)
        Daniel S
        • H Offline
          hsjzyangbin
          @daniel s said:
          here is an example:
          [attachment=1:21zf7cs5]<!-- ia1 -->simulation.gif<!-- ia1 -->[/attachment:21zf7cs5]
          [attachment=2:21zf7cs5]<!-- ia2 -->bezier.png<!-- ia2 -->[/attachment:21zf7cs5]
          404 Not Found
          Daniel S
          maybe some difference:
          visual interface control number of nodes
          [flash=][attachment=0:21zf7cs5]<!-- ia0 -->2010-03-18_0456.swf<!-- ia0 -->[/attachment:21zf7cs5][/flash]
          thank you
          2010-03-18_0456.swf
            thanhsjc
            thank you very much
              kyyu
              Hi Fredo6,
              First of all, thank you very much for this wonderful plugin! 😄 I would like to report a small bug with the "Convert to Catmull Spline" feature. One of the segments is always left out of the conversion.
              -Kwok
              • fredo6F Offline
                @kyyu said:
                Hi Fredo6,
                -Kwok
                You need to explictly close the loop, by hitting the Key F9 (or via contextual menu).
                  kyyu
                  @kyyu said:
                  Hi Fredo6,
                  -Kwok
                  Thanks, that worked perfectly!
                  -Kwok
                    Slimdog
                    Hi guys I have just downloaded the most recent version. BezierSpline%201.
                    I have put LibTraductor.rb, BZ_Dir_13, and bezierspline.rb into the plugins folder on my MAC. When I open sketchup I get this error:
                    Error Loading File #extrusionToolbar.rb
                    no such file to load -- deBabelizer.rbError Loading File 2D#.rb
                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByEdges.rb
                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByFaces.rb
                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByLathe.rb
                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByRails.rb
                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByVector.rb
                    any ideas guys???
                    Cheers
                    Steve
                      That's messages related to TIG's tools. you're missing one of his dependant files deBabelizer.rb.
                        Since you must have downloaded both my 2DTools and ExtrusionTools I wonder where you put deBabelizer.rb that comes with both of them ?
                        Anyway... here's another copy to save you having to find it - put it into the Plugins folder and restart SUp - that error should then be gone...deBabelizer.rb
                          Slimdog
                          Yes you guys are correct. My bad. I thought it out when I was loading Bezierspline.
                          Thanks for the responses.
                          S
                            Morphing_24
                            Hi fredo
                            I work on a mac and I have a really big problem here.
                            I dont know how can I view the cadfather toolbar on sketchup, I can only see the standard one and I installed all the files in the correct places bezierspline.rb, LibTraductor.rb and BZ_DIR_13 subfolder. I don't even see the option "convert to" when I right click on a bezier line , I need to use the polyline segmentor and courbette. I tried everything...reinstalling sketchup, also removing all the plugins I have from the Library/AplicationSupport/Google Sketchup 7/Sketchup/ plugins folder,but guest what, I still see all the toolbars working perfectly even though the plugin folder is empty.
                            However, when I work on windows I have no problems, I install the latest bezierspline and it works perfect.... what am I doing wrong?
                            • I Offline
                              inasia
                              Many Thanks Fredo,
                              Much appreciated, for your Plugin.
                              Thank you again
                              have a good day
                              cheers
                              inasia
                              • fredo6F Offline
                                @morphing_24 said:
                                Hi fredo
                                If the Library/AplicationSupport/Google Sketchup 7/Sketchup/ plugins folder is empty and you still have BezierSpline working, then you may have something left in the other plugin folder which is under /user/....
                                Otherwise, maybe some Mac users could help you to troubleshoot, as I don't have a Mac at hand.
                                • fredo6F Offline
                                  Thank you so much for this fantastic plugin Fredo6. Is there a way to tweak the snap? I'm a little heavy handed with the mouse - it's very easy for the cursor to fall off the line, or to move a line segment instead of a point when editing polylines.
                                  The script relies on the regular Sketchup inferences. So if there is a way to tweak it, then it should be valid for BezierSpline too.
                                    kurma
                                    Thanks for the quick reply Fredo6. It's not in any options that I can see. Perhaps it's something a Ruby script can do. But a cursory search for such a script lead nowhere.
                                      kurma
                                      Thank you so much for this fantastic plugin Fredo6. Is there a way to tweak the snap? I'm a little heavy handed with the mouse - it's very easy for the cursor to fall off the line, or to move a line segment instead of a point when editing.
                                      • X Offline
                                        xyzt
                                        Mac user here...
                                        The CadFather tools disappeared, I had them working, but after installing the spheretool.rb it they when missing...
                                          sus4
                                          Dominant XYZ with available?
                                            Bump! New version available... http://forums.sketchucation.com/viewtopic.php?p=100509#p100509
                                            • 22
                                            • 23
                                            • 5 / 23
