    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      A curve will 'face' if all of its vertices are coplanar and it is looped [or at least connected to other edges so there are on open ends].
      Draw over one of its edges and it should face.
      If not try drawing a diagonal line across where the face should be - this can force a face - you should be able to erase the temporary line afterwards and the face should stay behind.
      If not there are 'face-making' scripts - search for 'makefaces'....
        DIEGO-RODRIGUEZ
        hi fredo.
        could you fix this little mistake?
        thank you very much
        Error: #<NameError: undefined local variable or method preserve' for BZ__Segmentor:Module> D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/BZ__Segmentor.rb:128:in calculate'
        D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/BZ__Segmentor.rb:57:in bz_compute_curve' D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:1995:in call'
        D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:1995:in call_compute_curve' D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:2063:in conversion_curve'
        D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:2323:in compute_contextual_menu' D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:2323:in call'
          Diego
          In the latest version of the file - that's download-able from the first post in this topic - the 'preserve' variable is 'commented out' with # ...
          C:\Program Files\Google\Google SketchUp 7\Plugins\BZ_Dir_13\BZ__Segmentor.rb should have the word 'preserve' in it only twice [lines 86 and 128] - both times the line starts with a # to stop it loading...
          Do you have the right version ?
          If not, get it or add the two # yourself ?
            DIEGO-RODRIGUEZ
            TIG thanks.
            now it works perfect.
            • fredo6F
              Thanks TIG for your help.
              For info, the preserve variable is to have an option to keep the original control points, but for whatever reason I forgot to finish the code.
              • H
                hsjzyangbin
                Hope to improve the function :control point along z axis
                maybe add "ctrl" key to control XY plan or z plan
                • fredo6F
                  Do you mean you can do it or you wish to do it.
                  Planar lock is supported in creation mode.
                  Axis lock is also supported in Edition mode for th moving the control points.
                  This is explained in the doc, using Ctrl and Arrows
                  In a next version, I'll try to make something more explicit and straightforward however.
                  • H
                    hsjzyangbin
                    I used Bonzai3d to do it .
                    thanks a lot
                    hsjzyangbin
                    • H
                      hsjzyangbin
                      wish to have a visual interface control nodes of the function like YAD
                      here is an example:
                      best regards
                        Daniel S
                        here is an example:
                        About visual interface control nodes... Something like this is possible? (Like most 2d Vector software)
                        "A quadratic Bézier curve has a start and an end point (blue dots) and just one control point (red dot) while a cubic Bézier curve uses two control points."
                        404 Not Found
                        (www.caffeineowl.com)
                        Daniel S
                        • H
                          hsjzyangbin
                          @daniel s said:
                          here is an example:
                          [attachment=1:21zf7cs5]<!-- ia1 -->simulation.gif<!-- ia1 -->[/attachment:21zf7cs5]
                          [attachment=2:21zf7cs5]<!-- ia2 -->bezier.png<!-- ia2 -->[/attachment:21zf7cs5]
                          404 Not Found
                          Daniel S
                          maybe some difference:
                          visual interface control number of nodes
                          [flash=][attachment=0:21zf7cs5]<!-- ia0 -->2010-03-18_0456.swf<!-- ia0 -->[/attachment:21zf7cs5][/flash]
                          thank you
                          2010-03-18_0456.swf
                          • T
                            thanhsjc
                            thank you very much
                            • K
                              kyyu
                              Hi Fredo6,
                              First of all, thank you very much for this wonderful plugin! 😄 I would like to report a small bug with the "Convert to Catmull Spline" feature. One of the segments is always left out of the conversion.
                              -Kwok
                              • fredo6F
                                @kyyu said:
                                Hi Fredo6,
                                -Kwok
                                You need to explictly close the loop, by hitting the Key F9 (or via contextual menu).
                                • K
                                  kyyu
                                  @kyyu said:
                                  Hi Fredo6,
                                  -Kwok
                                  Thanks, that worked perfectly!
                                  -Kwok
                                    Slimdog
                                    Hi guys I have just downloaded the most recent version. BezierSpline%201.
                                    I have put LibTraductor.rb, BZ_Dir_13, and bezierspline.rb into the plugins folder on my MAC. When I open sketchup I get this error:
                                    Error Loading File #extrusionToolbar.rb
                                    no such file to load -- deBabelizer.rbError Loading File 2D#.rb
                                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByEdges.rb
                                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByFaces.rb
                                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByLathe.rb
                                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByRails.rb
                                    no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByVector.rb
                                    any ideas guys???
                                    Cheers
                                    Steve
                                      That's messages related to TIG's tools. you're missing one of his dependant files deBabelizer.rb.
                                        Since you must have downloaded both my 2DTools and ExtrusionTools I wonder where you put deBabelizer.rb that comes with both of them ?
                                        Anyway... here's another copy to save you having to find it - put it into the Plugins folder and restart SUp - that error should then be gone...deBabelizer.rb
                                          Slimdog
                                          Yes you guys are correct. My bad. I thought it out when I was loading Bezierspline.
                                          Thanks for the responses.
                                          S
                                            Morphing_24
                                            Hi fredo
                                            I work on a mac and I have a really big problem here.
                                            I dont know how can I view the cadfather toolbar on sketchup, I can only see the standard one and I installed all the files in the correct places bezierspline.rb, LibTraductor.rb and BZ_DIR_13 subfolder. I don't even see the option "convert to" when I right click on a bezier line , I need to use the polyline segmentor and courbette. I tried everything...reinstalling sketchup, also removing all the plugins I have from the Library/AplicationSupport/Google Sketchup 7/Sketchup/ plugins folder,but guest what, I still see all the toolbars working perfectly even though the plugin folder is empty.
                                            However, when I work on windows I have no problems, I install the latest bezierspline and it works perfect.... what am I doing wrong?
                                            • 22
                                            • 23
                                            • 5 / 23
