    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.0k Views 175 Watching
      Here is today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
      πŸ€“
        Here is an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
          Works fine now πŸ‘
            gavvy
            😲 TO Tig ,I can't say anymore πŸ‘
              Here is an updated set.
              EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
              Reverse the order of picking the rails to swap the diagonals' direction.
              Make two diagonal groups overlaid to get a 'diamond mesh' etc...
              The lingvo files have be updated to match.
                Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
                • W Offline
                  watkins
                  Dear TIG,
                  Does one still need offset.rb? I notice that it is missing from the zipped folder.
                  Regards,
                  Bob
                    Bob
                    No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
                    You can use any version of offset.rb you want - it is no longer needed by my tools... πŸ˜„
                      leixing
                      Thanks TIG.
                      great work
                      • W Offline
                        watkins
                        Dear TIG,
                        I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
                        Thanks,
                        Bob
                        • W Offline
                          watkins
                          Dear TIG,
                          Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
                          Regards,
                          Bob
                            Here's an updated zipped set - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                            All of the EEbyRailsToLattice and EEbyEdges lingvo files have been updated [incorrect/missing strings fixed], their ES versions were also updated by Defisto.
                              Keksschredder
                              Outstanding Tools. Thanks for the good work Tig.
                                dolphin
                                <<Pontugues>>
                                Por favor.
                                NΓ£o encontro o link para baixar o ExtrudeTools. Onde estΓ‘?
                                <<English>>
                                Please.
                                I can not find the link to download the ExtrudeTools. Where is it?
                                  Hi Dolphin (and welcome to SCF).
                                  Plugins are usually attached to the bottom line of the very first post in the topic.
                                    It's here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                    The clue is in the 'note' πŸ˜‰Capture.PNG or there are links in any of my posts announcing an update...Capture1.PNG
                                      Daniel S
                                      The clue is in the 'note' πŸ˜‰[attachment=2:2pbi3eqh]<!-- ia2 -->Capture.PNG<!-- ia2 -->[/attachment:2pbi3eqh] or there are links in any of my posts announcing an update...[attachment=1:2pbi3eqh]<!-- ia1 -->Capture1.PNG<!-- ia1 -->[/attachment:2pbi3eqh]
                                      Hi TIG
                                      Great Idea!!! What about if you click in the image and that makes a direct download of the plugin?
                                      Something like:
                                      CLICK on the image for download!!
                                      [attachment=0:2pbi3eqh]<!-- ia0 -->Screenshot_1.jpg<!-- ia0 -->[/attachment:2pbi3eqh]
                                      The code I Use:
                                      [url=http://forums.sketchucation.com/download/file.php?id=48174][attachment=0]Screenshot_1.jpg[/attachment][/url]
                                      Daniel S
                                        I'd prefer the users read the post... then download... although I know a lot will scroll past everything anyway but if the image were to link to the download they'd even have no need to do that - you'd be amazed how many PMs we scripters get about problems with installing the files, simply because most new users never read the notes and open a zip file and then drag'n'drop everything into their Plugins folder; when these days a lot of stuff goes into sub-folders to try and keep things a little 'ordered'...
                                          liangljz
                                          i am looking for it. thank you
                                            toldo39
                                            thnx
                                            • 31
                                            • 32
                                            • 6 / 32
