    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
    • W
      watkins
      Dear TIG,
      Does one still need offset.rb? I notice that it is missing from the zipped folder.
      Regards,
      Bob
        Bob
        No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
        You can use any version of offset.rb you want - it is no longer needed by my tools... 😄
        • L
          leixing
          Thanks TIG.
          great work
          • W
            watkins
            Dear TIG,
            I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
            Thanks,
            Bob
            • W
              watkins
              Dear TIG,
              Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
              Regards,
              Bob
                Here's an updated zipped set - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                All of the EEbyRailsToLattice and EEbyEdges lingvo files have been updated [incorrect/missing strings fixed], their ES versions were also updated by Defisto.
                • K
                  Keksschredder
                  Outstanding Tools. Thanks for the good work Tig.
                    dolphin
                    <<Pontugues>>
                    Por favor.
                    Não encontro o link para baixar o ExtrudeTools. Onde está?
                    <<English>>
                    Please.
                    I can not find the link to download the ExtrudeTools. Where is it?
                    • GaieusG
                      Hi Dolphin (and welcome to SCF).
                      Plugins are usually attached to the bottom line of the very first post in the topic.
                        It's here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        The clue is in the 'note' 😉Capture.PNG or there are links in any of my posts announcing an update...Capture1.PNG
                          Daniel S
                          The clue is in the 'note' 😉[attachment=2:2pbi3eqh]<!-- ia2 -->Capture.PNG<!-- ia2 -->[/attachment:2pbi3eqh] or there are links in any of my posts announcing an update...[attachment=1:2pbi3eqh]<!-- ia1 -->Capture1.PNG<!-- ia1 -->[/attachment:2pbi3eqh]
                          Hi TIG
                          Great Idea!!! What about if you click in the image and that makes a direct download of the plugin?
                          Something like:
                          CLICK on the image for download!!
                          [attachment=0:2pbi3eqh]<!-- ia0 -->Screenshot_1.jpg<!-- ia0 -->[/attachment:2pbi3eqh]
                          The code I Use:
                          [url=http://forums.sketchucation.com/download/file.php?id=48174][attachment=0]Screenshot_1.jpg[/attachment][/url]
                          Daniel S
                            I'd prefer the users read the post... then download... although I know a lot will scroll past everything anyway but if the image were to link to the download they'd even have no need to do that - you'd be amazed how many PMs we scripters get about problems with installing the files, simply because most new users never read the notes and open a zip file and then drag'n'drop everything into their Plugins folder; when these days a lot of stuff goes into sub-folders to try and keep things a little 'ordered'...
                            • L
                              liangljz
                              i am looking for it. thank you
                              • T
                                toldo39
                                thnx
                                  stefx
                                  Hi TIG,
                                  the plugin set is amazing!
                                  I would like to know if there is a chance to create the extrude-edge-by-rails but for faces, something like "extrude faces by rails".
                                    I didn't make a separate EEby.. tool since you can do it relatively easily with EEbyRails as in this exampleCapture.PNG
                                      stefx
                                      Thank you TIG.
                                      I have tried but:
                                      1: i create my face with all the edges welded
                                      2. i select the profile as curve
                                      3. i select the 2 rails
                                      4. i select the melding-prfile curve
                                      1. Sketchup crashes!
                                      I am thinking to split the face-curve in two parts.
                                      Stef.
                                        Can you post an example skp ?
                                          stefx
                                          Here it is!
                                          basically it is roof design, you could find the profile of the roof and 2 rails.
                                          The two rails don't touch the profile.
                                          So I welded the whole profile, I welded the 2 rails but when I try to use the plugin everything crashes!
                                          I have tried to split the profile in more parts, and it looks like working.
                                          Stef.
                                          roof test.skp
                                            It can only be done after the model is 'fixed'.
                                            The roof profile is not quite coplanar [try to add a face to it - you can't !] so it adds all sorts of additional problems... with geometry flying off into space etc etc...
                                            Complex 3D curves will work as Profiles but especially looped ones with slight discrepancies can be problematical !
                                            To fix it select the roof profile curve and use EEbyVector on it to make a small temporary roof-bit [ extruded away from the 'rails' but in line with the first edge].
                                            Now draw a large vertical rectangle that intersects the whole of this new roof-bit.
                                            Select that rectangle and right-click > intersect > with model.
                                            Erase the unwanted bits of the rectangle and keep just the faced roof profile.
                                            Erase the temporary roof-bit too.
                                            You know have a coplanar roof profile.
                                            Select the edges of it and weld them into one curve.
                                            Move it near to the rails but not touching them, so it doesn't 'split'.
                                            Check that the rails have the same number of edges - if not group them draw over them with lines and erase the originals then when they have the same number of edges [select and use entity info] weld each set in turn into a curve.
                                            Now you can use EEbyRails...
                                            Select the Profile, then the Rails in turn and the Profile again as the melding-profile [in is 'assumed' at the other end of the rails as required].
                                            The mesh is made as expected...
                                            You need to add 'end-faces' by drawing over an edge at the ends... 🤓Capture.PNG
                                            • 31
                                            • 32
                                            • 8 / 32
