    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      EEbyRailsToLattice has been updated with the latest version of 'offset.rb' and trapped to rescue its 'fails', also some glitches with display of selected curves etc is fixed...
      πŸ€“
        I have reissued a new version again today http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        The single change is a temporarily fixed offset.rb [awaiting its author's input, RickW ]...
        After I updated from offset.rb v1 to v2.1 in my zipped set earlier today, I discovered that it had then broken RickW's own Windowizer4.rb πŸ˜’ .
        None of this affects my tools - they only need the Face::offset() method !
        In this tweaked version I have included the older Array::offset() AND the newer Array::offsetPoints() methods found in offset.rb v1 AND v2.1 respectively; and so it should now work with Windowizer4.rb and also any tools that might rely on the newer version...
        πŸ˜•
          Here's another version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          An updated FR lingvo for EEbyRailsToLattice - a compilation of Pilou and Didier's suggestions/corrections
          [note that "accents" are not used in text within the inputbox dialogs to avoid problems...]
          Thanks...
            doy
            thumbs up....this is hot...thanks a lot for sharing
              Here is today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
              EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
              πŸ€“
                Here is an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
                  Works fine now πŸ‘
                  • G
                    gavvy
                    😲 TO Tig ,I can't say anymore πŸ‘
                      Here is an updated set.
                      EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
                      Reverse the order of picking the rails to swap the diagonals' direction.
                      Make two diagonal groups overlaid to get a 'diamond mesh' etc...
                      The lingvo files have be updated to match.
                        Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
                        • W
                          watkins
                          Dear TIG,
                          Does one still need offset.rb? I notice that it is missing from the zipped folder.
                          Regards,
                          Bob
                            Bob
                            No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
                            You can use any version of offset.rb you want - it is no longer needed by my tools... πŸ˜„
                            • L
                              leixing
                              Thanks TIG.
                              great work
                              • W
                                watkins
                                Dear TIG,
                                I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
                                Thanks,
                                Bob
                                • W
                                  watkins
                                  Dear TIG,
                                  Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
                                  Regards,
                                  Bob
                                    Here's an updated zipped set - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                    All of the EEbyRailsToLattice and EEbyEdges lingvo files have been updated [incorrect/missing strings fixed], their ES versions were also updated by Defisto.
                                    • K
                                      Keksschredder
                                      Outstanding Tools. Thanks for the good work Tig.
                                        dolphin
                                        <<Pontugues>>
                                        Por favor.
                                        NΓ£o encontro o link para baixar o ExtrudeTools. Onde estΓ‘?
                                        <<English>>
                                        Please.
                                        I can not find the link to download the ExtrudeTools. Where is it?
                                        • GaieusG
                                          Hi Dolphin (and welcome to SCF).
                                          Plugins are usually attached to the bottom line of the very first post in the topic.
                                            It's here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                            The clue is in the 'note' πŸ˜‰Capture.PNG or there are links in any of my posts announcing an update...Capture1.PNG
                                            • 31
                                            • 32
                                            • 7 / 32
