    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
      • W
        watkins
        Dear TIG,
        Does one still need offset.rb? I notice that it is missing from the zipped folder.
        Regards,
        Bob
          Bob
          No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
          You can use any version of offset.rb you want - it is no longer needed by my tools... 😄
          • L
            leixing
            Thanks TIG.
            great work
            • W
              watkins
              Dear TIG,
              I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
              Thanks,
              Bob
              • W
                watkins
                Dear TIG,
                Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
                Regards,
                Bob
                  Here's an updated zipped set - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  All of the EEbyRailsToLattice and EEbyEdges lingvo files have been updated [incorrect/missing strings fixed], their ES versions were also updated by Defisto.
                  • K
                    Keksschredder
                    Outstanding Tools. Thanks for the good work Tig.
                      dolphin
                      <<Pontugues>>
                      Por favor.
                      Não encontro o link para baixar o ExtrudeTools. Onde está?
                      <<English>>
                      Please.
                      I can not find the link to download the ExtrudeTools. Where is it?
                      • GaieusG
                        Hi Dolphin (and welcome to SCF).
                        Plugins are usually attached to the bottom line of the very first post in the topic.
                          It's here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          The clue is in the 'note' 😉Capture.PNG or there are links in any of my posts announcing an update...Capture1.PNG
                            Daniel S
                            The clue is in the 'note' 😉[attachment=2:2pbi3eqh]<!-- ia2 -->Capture.PNG<!-- ia2 -->[/attachment:2pbi3eqh] or there are links in any of my posts announcing an update...[attachment=1:2pbi3eqh]<!-- ia1 -->Capture1.PNG<!-- ia1 -->[/attachment:2pbi3eqh]
                            Hi TIG
                            Great Idea!!! What about if you click in the image and that makes a direct download of the plugin?
                            Something like:
                            CLICK on the image for download!!
                            [attachment=0:2pbi3eqh]<!-- ia0 -->Screenshot_1.jpg<!-- ia0 -->[/attachment:2pbi3eqh]
                            The code I Use:
                            [url=http://forums.sketchucation.com/download/file.php?id=48174][attachment=0]Screenshot_1.jpg[/attachment][/url]
                            Daniel S
                              I'd prefer the users read the post... then download... although I know a lot will scroll past everything anyway but if the image were to link to the download they'd even have no need to do that - you'd be amazed how many PMs we scripters get about problems with installing the files, simply because most new users never read the notes and open a zip file and then drag'n'drop everything into their Plugins folder; when these days a lot of stuff goes into sub-folders to try and keep things a little 'ordered'...
                              • L
                                liangljz
                                i am looking for it. thank you
                                • T
                                  toldo39
                                  thnx
                                    stefx
                                    Hi TIG,
                                    the plugin set is amazing!
                                    I would like to know if there is a chance to create the extrude-edge-by-rails but for faces, something like "extrude faces by rails".
                                      I didn't make a separate EEby.. tool since you can do it relatively easily with EEbyRails as in this exampleCapture.PNG
                                        stefx
                                        Thank you TIG.
                                        I have tried but:
                                        1: i create my face with all the edges welded
                                        2. i select the profile as curve
                                        3. i select the 2 rails
                                        4. i select the melding-prfile curve
                                        1. Sketchup crashes!
                                        I am thinking to split the face-curve in two parts.
                                        Stef.
                                          Can you post an example skp ?
                                            stefx
                                            Here it is!
                                            basically it is roof design, you could find the profile of the roof and 2 rails.
                                            The two rails don't touch the profile.
                                            So I welded the whole profile, I welded the 2 rails but when I try to use the plugin everything crashes!
                                            I have tried to split the profile in more parts, and it looks like working.
                                            Stef.
                                            roof test.skp
                                            • 31
                                            • 32
                                            • 8 / 32
