    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
      gavvy
      😲 TO Tig ,I can't say anymore πŸ‘
        Here is an updated set.
        EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
        Reverse the order of picking the rails to swap the diagonals' direction.
        Make two diagonal groups overlaid to get a 'diamond mesh' etc...
        The lingvo files have be updated to match.
        http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
          • W Offline
            watkins
            Dear TIG,
            Does one still need offset.rb? I notice that it is missing from the zipped folder.
            Regards,
            Bob
              Bob
              No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
              You can use any version of offset.rb you want - it is no longer needed by my tools... πŸ˜„
                leixing
                Thanks TIG.
                great work
                • W Offline
                  watkins
                  Dear TIG,
                  I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
                  Thanks,
                  Bob
                  • W Offline
                    watkins
                    Dear TIG,
                    Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
                    Regards,
                    Bob
                      Here's an updated zipped set - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                      All of the EEbyRailsToLattice and EEbyEdges lingvo files have been updated [incorrect/missing strings fixed], their ES versions were also updated by Defisto.
                        Keksschredder
                        Outstanding Tools. Thanks for the good work Tig.
                          dolphin
                          <<Pontugues>>
                          Por favor.
                          NΓ£o encontro o link para baixar o ExtrudeTools. Onde estΓ‘?
                          <<English>>
                          Please.
                          I can not find the link to download the ExtrudeTools. Where is it?
                            Hi Dolphin (and welcome to SCF).
                            Plugins are usually attached to the bottom line of the very first post in the topic.
                              It's here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              The clue is in the 'note' πŸ˜‰Capture.PNG or there are links in any of my posts announcing an update...Capture1.PNG
                                Daniel S
                                The clue is in the 'note' πŸ˜‰[attachment=2:2pbi3eqh]<!-- ia2 -->Capture.PNG<!-- ia2 -->[/attachment:2pbi3eqh] or there are links in any of my posts announcing an update...[attachment=1:2pbi3eqh]<!-- ia1 -->Capture1.PNG<!-- ia1 -->[/attachment:2pbi3eqh]
                                Hi TIG
                                Great Idea!!! What about if you click in the image and that makes a direct download of the plugin?
                                Something like:
                                CLICK on the image for download!!
                                [attachment=0:2pbi3eqh]<!-- ia0 -->Screenshot_1.jpg<!-- ia0 -->[/attachment:2pbi3eqh]
                                The code I Use:
                                [url=http://forums.sketchucation.com/download/file.php?id=48174][attachment=0]Screenshot_1.jpg[/attachment][/url]
                                Daniel S
                                  I'd prefer the users read the post... then download... although I know a lot will scroll past everything anyway but if the image were to link to the download they'd even have no need to do that - you'd be amazed how many PMs we scripters get about problems with installing the files, simply because most new users never read the notes and open a zip file and then drag'n'drop everything into their Plugins folder; when these days a lot of stuff goes into sub-folders to try and keep things a little 'ordered'...
                                    liangljz
                                    i am looking for it. thank you
                                      toldo39
                                      thnx
                                        stefx
                                        Hi TIG,
                                        the plugin set is amazing!
                                        I would like to know if there is a chance to create the extrude-edge-by-rails but for faces, something like "extrude faces by rails".
                                          I didn't make a separate EEby.. tool since you can do it relatively easily with EEbyRails as in this exampleCapture.PNG
                                            stefx
                                            Thank you TIG.
                                            I have tried but:
                                            1: i create my face with all the edges welded
                                            2. i select the profile as curve
                                            3. i select the 2 rails
                                            4. i select the melding-prfile curve
                                            1. Sketchup crashes!
                                            I am thinking to split the face-curve in two parts.
                                            Stef.
                                            • 31
                                            • 32
                                            • 8 / 32
