    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
    • W Offline
      watkins
      Dear TIG,
      You appear to be using version 1.0 of offset.rb. There is a later version, V2.1 (see the attached). Is it okay to use the later version with your scripts?
      Regards,
      Bob
      offset.rb
      • TIGT Online
        @watkins said:
        Dear TIG,
        Regards,
        Bob
        Don't know how I'm still using that old one !
        Finger on the pulse, and all that.... πŸ˜’
        Anyway... it doesn't matter, v1 or v2.1 both work fine when I've tested...
        I'll package the new version with any future updates...
        Meanwhile, if users already have the newer version then I recommend that they don't overwrite it with the older zipped one until the zipped update catches up...
        Sorry for any confusion...
        • TIGT Online
          Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          EEbyRailsToLattice has been updated with the latest version of 'offset.rb' and trapped to rescue its 'fails', also some glitches with display of selected curves etc is fixed...
          πŸ€“
          • TIGT Online
            I have reissued a new version again today http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            The single change is a temporarily fixed offset.rb [awaiting its author's input, RickW ]...
            After I updated from offset.rb v1 to v2.1 in my zipped set earlier today, I discovered that it had then broken RickW's own Windowizer4.rb πŸ˜’ .
            None of this affects my tools - they only need the Face::offset() method !
            In this tweaked version I have included the older Array::offset() AND the newer Array::offsetPoints() methods found in offset.rb v1 AND v2.1 respectively; and so it should now work with Windowizer4.rb and also any tools that might rely on the newer version...
            πŸ˜•
            • TIGT Online
              Here's another version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
              An updated FR lingvo for EEbyRailsToLattice - a compilation of Pilou and Didier's suggestions/corrections
              [note that "accents" are not used in text within the inputbox dialogs to avoid problems...]
              Thanks...
                doy
                thumbs up....this is hot...thanks a lot for sharing
                • TIGT Online
                  Here is today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
                  πŸ€“
                  • TIGT Online
                    Here is an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
                      Works fine now πŸ‘
                        gavvy
                        😲 TO Tig ,I can't say anymore πŸ‘
                        • TIGT Online
                          Here is an updated set.
                          EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
                          Reverse the order of picking the rails to swap the diagonals' direction.
                          Make two diagonal groups overlaid to get a 'diamond mesh' etc...
                          The lingvo files have be updated to match.
                          • TIGT Online
                            Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                            EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
                            • W Offline
                              watkins
                              Dear TIG,
                              Does one still need offset.rb? I notice that it is missing from the zipped folder.
                              Regards,
                              Bob
                              • TIGT Online
                                Bob
                                No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
                                You can use any version of offset.rb you want - it is no longer needed by my tools... πŸ˜„
                                  leixing
                                  Thanks TIG.
                                  great work
                                  • W Offline
                                    watkins
                                    Dear TIG,
                                    I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
                                    Thanks,
                                    Bob
                                    • W Offline
                                      watkins
                                      Dear TIG,
                                      Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
                                      Regards,
                                      Bob
                                      • TIGT Online
                                        Here's an updated zipped set - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                        All of the EEbyRailsToLattice and EEbyEdges lingvo files have been updated [incorrect/missing strings fixed], their ES versions were also updated by Defisto.
                                          Keksschredder
                                          Outstanding Tools. Thanks for the good work Tig.
                                            dolphin
                                            <<Pontugues>>
                                            Por favor.
                                            NΓ£o encontro o link para baixar o ExtrudeTools. Onde estΓ‘?
                                            <<English>>
                                            Please.
                                            I can not find the link to download the ExtrudeTools. Where is it?
                                            • 31
                                            • 32
                                            • 7 / 32
