    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • X Offline
      xrok1
      thats pretty sweet! thank you. 😍
      • EarthMoverE Offline
        EarthMover
        Nice render results...great job with the UI!
        I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
        Content Creator at Skapeup
          Suggestions:
          Make the type box and Option box.
          I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
          • X Offline
            xrok1
            😎 this is greaaaat!
              @xrok1 said:
              8-) this is greaaaat!
              Nice patch. Is that just one plain colour for the grass?
              • soloS Offline
                This looks interesting....
                Thanks mate.
                  rickgraham
                  Umm my dialog box for furmaker is blank. ❓
                  Rick
                    @solo said:
                    :shock:
                    Thanks mate.
                    Render comp?? πŸ˜„
                    • X Offline
                      xrok1
                      ground cover>Vegetation_Grass1
                      • jeff hammondJ Offline
                        Rick
                        [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
                        same here..
                        no fur for osx 😐
                          Ben Ritter
                          Quite fun to play around with. Thank you so much.
                          Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
                          Ben
                            rickgraham
                            Rick
                            [attachment=0:aem2yrs3]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:aem2yrs3]
                            same here..
                            no fur for osx 😐
                            Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
                            Rick
                            • X Offline
                              xrok1
                              would be nice to be able to pre-select the material though. i had to paint the branches green and then back to brown after.
                                SU Reviewer
                                Great Plugin! I'm in the process of reviewing it for my site. But I keep running into an issue, whenever I select my settings and then click the "Fur" button it creates the fur on the wrong side of the face. Always facing down. Is there a way to fix this?
                                Thanks for your efforts!
                                Living Einstein's dream through SketchUp.
                                "Imagination is a preview of life's coming attractions" - Albert Einstein
                                Joe Simhon ~ SketchUp Plugin Reviews
                                • soloS Offline
                                  Make sure your face is orientated correctly.
                                    tak2hata
                                    Hi, Jeff and rick.
                                    I update Fur_en.rb
                                    The WebDialog has problem in Mac OSX.
                                    So I put another menu for the correspondence of this problem.
                                    The menu named "fur!(MAC)".
                                    Using InputBox Dialog.
                                    How in this?
                                    by TAK2HATA
                                      Very nice site. I've not seen it before. New?
                                      • daleD Offline
                                        dale
                                        Yes, Wow thanks for this. I got a feeling some real interesting things will happen with this plugin.
                                        • X Offline
                                          xrok1
                                          how can we access the component instance option? also did you consider the color preselect or a don't copy material option?
                                          also if it would remember settings from 1 usage to the next would be great. a drop down with saved presets would be even better. 😳
                                            rickgraham
                                            @tak2hata said:
                                            Hi, Jeff and rick.
                                            I update Fur_en.rb
                                            How in this?
                                            Works great now, many thanks!
                                            If I can make one little suggestion - I'm not sure if the PC guys are the same or not, but when the dialog box comes up, it is right in the middle of the screen and I have to move it each time. Is there a way to have come in some place other than center? And I would love to see documentation of what the various controls do.
                                            Again, thanks for the great plugin.
                                            Rick
                                            • 32
                                            • 33
                                            • 3 / 33
