    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      Seems very cool! β˜€
        Hey! Welcome to SCF.
        Very nice plugin.
        Got a couple of comments:
        It does not create the grass in the active context. If I open a group or component and select faces it does not add the grass to that group. By design?
        Why are there so many Groups generated? To cut down generation time? Just find it a bit odd that a patch will have grass in multiple locations:
        As for the grass - would it be an idea to make each grass straw a component, and then use scaled and skewed instances of that strand?
          tak2hata
          Thank you for using this plugin.
          Sorry, I will change to create in the active context
          Yes.
          Creating Too Much Polygon is very slow.
          And to use code "entities.fill_from_mesh" must need blank Group.
          This Plugin executes each selected faces.
          Creating Group each new 800 polygons.
          so it parts.
          by TAK2HATA
            Yea - creating geometry slows down as more entities are in the context you add to - I've noticed that myself.
            But would it be faster to make each grass strand to be a ComponentInstance of a single ComponentDefinition? That way one can easily edit the grass afterwards as well.
              tak2hata
              It is nice idea !
              I will examine it.
              I think that time hangs for a moment to change this plugin.
              thanks.
              by TAK2HATA
                meak
                cool plugin
                thanks, thanks,thanks.
                +1 componentinstance! πŸ’š
                • EarthMoverE Offline
                  EarthMover
                  Nice! Autograss for sketchup!
                  Thomthom, is there is a simple code fix that we could implement to have the blades made as component instances, or does that involve some rewriting?
                  Content Creator at Skapeup
                    Dunno - haven't looked at the code.
                    • X Offline
                      xrok1
                      thats pretty sweet! thank you. 😍
                        EarthMover
                        Nice render results...great job with the UI!
                        I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
                          Suggestions:
                          Make the type box and Option box.
                          I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
                          • X Offline
                            xrok1
                            😎 this is greaaaat!
                              @xrok1 said:
                              8-) this is greaaaat!
                              Nice patch. Is that just one plain colour for the grass?
                              • soloS Offline
                                This looks interesting....
                                Thanks mate.
                                  rickgraham
                                  Umm my dialog box for furmaker is blank. ❓
                                  Rick
                                    @solo said:
                                    :shock:
                                    Thanks mate.
                                    Render comp?? πŸ˜„
                                    • X Offline
                                      xrok1
                                      ground cover>Vegetation_Grass1
                                      • jeff hammondJ Offline
                                        Rick
                                        [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
                                        same here..
                                        no fur for osx 😐
                                          Ben Ritter
                                          Quite fun to play around with. Thank you so much.
                                          Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
                                          Ben
                                            rickgraham
                                            Rick
                                            [attachment=0:aem2yrs3]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:aem2yrs3]
                                            same here..
                                            no fur for osx 😐
                                            Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
                                            Rick
                                            • 32
                                            • 33
                                            • 1 / 33
