    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • soloS Offline
      This looks interesting....
      Thanks mate.
        rickgraham
        Umm my dialog box for furmaker is blank. ❓
        Rick
          @solo said:
          :shock:
          Thanks mate.
          Render comp?? πŸ˜„
          • X Offline
            xrok1
            @thomthom said:
            @xrok1 said:
            8-) this is greaaaat!
            Nice patch. Is that just one plain colour for the grass?
            ground cover>Vegetation_Grass1
            • jeff hammondJ Offline
              Rick
              [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
              same here..
              no fur for osx 😐
                Ben Ritter
                Quite fun to play around with. Thank you so much.
                Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
                Ben
                  rickgraham
                  Rick
                  [attachment=0:aem2yrs3]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:aem2yrs3]
                  same here..
                  no fur for osx 😐
                  Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
                  Rick
                  • X Offline
                    xrok1
                    would be nice to be able to pre-select the material though. i had to paint the branches green and then back to brown after.
                      SU Reviewer
                      Great Plugin! I'm in the process of reviewing it for my site. But I keep running into an issue, whenever I select my settings and then click the "Fur" button it creates the fur on the wrong side of the face. Always facing down. Is there a way to fix this?
                      Thanks for your efforts!
                      Living Einstein's dream through SketchUp.
                      "Imagination is a preview of life's coming attractions" - Albert Einstein
                      Joe Simhon ~ SketchUp Plugin Reviews
                      • soloS Offline
                        Make sure your face is orientated correctly.
                          tak2hata
                          Hi, Jeff and rick.
                          I update Fur_en.rb
                          The WebDialog has problem in Mac OSX.
                          So I put another menu for the correspondence of this problem.
                          The menu named "fur!(MAC)".
                          Using InputBox Dialog.
                          How in this?
                          by TAK2HATA
                            Very nice site. I've not seen it before. New?
                            • daleD Offline
                              dale
                              Yes, Wow thanks for this. I got a feeling some real interesting things will happen with this plugin.
                              • X Offline
                                xrok1
                                how can we access the component instance option? also did you consider the color preselect or a don't copy material option?
                                also if it would remember settings from 1 usage to the next would be great. a drop down with saved presets would be even better. 😳
                                  rickgraham
                                  @tak2hata said:
                                  Hi, Jeff and rick.
                                  I update Fur_en.rb
                                  How in this?
                                  Works great now, many thanks!
                                  If I can make one little suggestion - I'm not sure if the PC guys are the same or not, but when the dialog box comes up, it is right in the middle of the screen and I have to move it each time. Is there a way to have come in some place other than center? And I would love to see documentation of what the various controls do.
                                  Again, thanks for the great plugin.
                                  Rick
                                  • X Offline
                                    xrok1
                                    i knew i should have popped that before it got out of hand! 😲
                                    who would have ever imagined fur for SU?????????????????????????????
                                      rickgraham
                                      @rickgraham said:
                                      @tak2hata said:
                                      Hi, Jeff and rick.
                                      I update Fur_en.rb
                                      How in this?
                                      I cannot tell what the intended difference between the 1 - Linear and 2- Arch are. By the way, the Mac only shows 1,2,3,4 - I saw another persons screen shot which showed me what they were for.
                                      Rick
                                        @tak2hata said:
                                        Hi, Jeff and rick.
                                        I update Fur_en.rb
                                        How in this?
                                        yep, we're growing some fur now πŸ˜„
                                        thanks!
                                        • soloS Offline
                                          Was just a matter of time until someone posted hairy balls. πŸ’š
                                          • X Offline
                                            xrok1
                                            i can hear all the script writers now
                                            "Why the fook didn't i think of that? πŸ˜• , its so fookin simple too! 😲"
                                            awsome, simply awsome! πŸ˜„
                                            • 32
                                            • 33
                                            • 2 / 33
