    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      @solo said:
      :shock:
      This looks interesting....
      Thanks mate.
      Render comp?? ๐Ÿ˜„
      • X Offline
        xrok1
        @thomthom said:
        @xrok1 said:
        8-) this is greaaaat!
        Nice patch. Is that just one plain colour for the grass?
        ground cover>Vegetation_Grass1
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • jeff hammondJ Offline
          @rickgraham said:
          Umm my dialog box for furmaker is blank. โ“
          Rick
          [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
          same here..
          no fur for osx ๐Ÿ˜
            Ben Ritter
            Quite fun to play around with. Thank you so much.
            Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
            Ben
              rickgraham
              Rick
              [attachment=0:aem2yrs3]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:aem2yrs3]
              same here..
              no fur for osx ๐Ÿ˜
              Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
              Rick
              • X Offline
                xrok1
                would be nice to be able to pre-select the material though. i had to paint the branches green and then back to brown after.
                  SU Reviewer
                  Great Plugin! I'm in the process of reviewing it for my site. But I keep running into an issue, whenever I select my settings and then click the "Fur" button it creates the fur on the wrong side of the face. Always facing down. Is there a way to fix this?
                  Thanks for your efforts!
                  Living Einstein's dream through SketchUp.
                  "Imagination is a preview of life's coming attractions" - Albert Einstein
                  Joe Simhon ~ SketchUp Plugin Reviews
                  • soloS Offline
                    Make sure your face is orientated correctly.
                      tak2hata
                      Hi, Jeff and rick.
                      I update Fur_en.rb
                      The WebDialog has problem in Mac OSX.
                      So I put another menu for the correspondence of this problem.
                      The menu named "fur!(MAC)".
                      Using InputBox Dialog.
                      How in this?
                      by TAK2HATA
                        Very nice site. I've not seen it before. New?
                        • daleD Offline
                          dale
                          Yes, Wow thanks for this. I got a feeling some real interesting things will happen with this plugin.
                          • X Offline
                            xrok1
                            how can we access the component instance option? also did you consider the color preselect or a don't copy material option?
                            also if it would remember settings from 1 usage to the next would be great. a drop down with saved presets would be even better. ๐Ÿ˜ณ
                              rickgraham
                              @tak2hata said:
                              Hi, Jeff and rick.
                              I update Fur_en.rb
                              How in this?
                              Works great now, many thanks!
                              If I can make one little suggestion - I'm not sure if the PC guys are the same or not, but when the dialog box comes up, it is right in the middle of the screen and I have to move it each time. Is there a way to have come in some place other than center? And I would love to see documentation of what the various controls do.
                              Again, thanks for the great plugin.
                              Rick
                              • X Offline
                                xrok1
                                i knew i should have popped that before it got out of hand! ๐Ÿ˜ฒ
                                who would have ever imagined fur for SU?????????????????????????????
                                  rickgraham
                                  @rickgraham said:
                                  @tak2hata said:
                                  Hi, Jeff and rick.
                                  I update Fur_en.rb
                                  How in this?
                                  I cannot tell what the intended difference between the 1 - Linear and 2- Arch are. By the way, the Mac only shows 1,2,3,4 - I saw another persons screen shot which showed me what they were for.
                                  Rick
                                    @tak2hata said:
                                    Hi, Jeff and rick.
                                    I update Fur_en.rb
                                    How in this?
                                    yep, we're growing some fur now ๐Ÿ˜„
                                    thanks!
                                    • soloS Offline
                                      Was just a matter of time until someone posted hairy balls. ๐Ÿ’š
                                      • X Offline
                                        xrok1
                                        i can hear all the script writers now
                                        "Why the fook didn't i think of that? ๐Ÿ˜• , its so fookin simple too! ๐Ÿ˜ฒ"
                                        ๐Ÿคฃ
                                        awsome, simply awsome! ๐Ÿ˜„
                                          rickgraham
                                          ๐Ÿคฃ
                                          This is a banner day for me and SU.
                                          Rick
                                          • ken28875K Offline
                                            ken28875
                                            Wow...I am speechless...fur for Sketchup! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
                                            ๐Ÿ‘ ๐Ÿ‘
                                            _KN
                                            Follow Your Dreams.
                                            • 32
                                            • 33
                                            • 2 / 33
