    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      Yea - creating geometry slows down as more entities are in the context you add to - I've noticed that myself.
      But would it be faster to make each grass strand to be a ComponentInstance of a single ComponentDefinition? That way one can easily edit the grass afterwards as well.
        tak2hata
        It is nice idea !
        I will examine it.
        I think that time hangs for a moment to change this plugin.
        thanks.
        by TAK2HATA
          meak
          cool plugin
          thanks, thanks,thanks.
          +1 componentinstance! πŸ’š
          • EarthMoverE Offline
            EarthMover
            Nice! Autograss for sketchup!
            Thomthom, is there is a simple code fix that we could implement to have the blades made as component instances, or does that involve some rewriting?
            Content Creator at Skapeup
              Dunno - haven't looked at the code.
              • X Offline
                xrok1
                thats pretty sweet! thank you. 😍
                  EarthMover
                  Nice render results...great job with the UI!
                  I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
                    Suggestions:
                    Make the type box and Option box.
                    I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
                    • X Offline
                      xrok1
                      😎 this is greaaaat!
                        @xrok1 said:
                        8-) this is greaaaat!
                        Nice patch. Is that just one plain colour for the grass?
                        • soloS Offline
                          This looks interesting....
                          Thanks mate.
                            rickgraham
                            Umm my dialog box for furmaker is blank. ❓
                            Rick
                              @solo said:
                              :shock:
                              Thanks mate.
                              Render comp?? πŸ˜„
                              • X Offline
                                xrok1
                                ground cover>Vegetation_Grass1
                                • jeff hammondJ Offline
                                  Rick
                                  [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
                                  same here..
                                  no fur for osx 😐
                                    Ben Ritter
                                    Quite fun to play around with. Thank you so much.
                                    Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
                                    Ben
                                      rickgraham
                                      Rick
                                      [attachment=0:aem2yrs3]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:aem2yrs3]
                                      same here..
                                      no fur for osx 😐
                                      Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
                                      Rick
                                      • X Offline
                                        xrok1
                                        would be nice to be able to pre-select the material though. i had to paint the branches green and then back to brown after.
                                          SU Reviewer
                                          Great Plugin! I'm in the process of reviewing it for my site. But I keep running into an issue, whenever I select my settings and then click the "Fur" button it creates the fur on the wrong side of the face. Always facing down. Is there a way to fix this?
                                          Thanks for your efforts!
                                          Living Einstein's dream through SketchUp.
                                          "Imagination is a preview of life's coming attractions" - Albert Einstein
                                          Joe Simhon ~ SketchUp Plugin Reviews
                                          • soloS Offline
                                            Make sure your face is orientated correctly.
                                            • 32
                                            • 33
                                            • 1 / 33
