    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • EarthMoverE Offline
      EarthMover
      Nice render results...great job with the UI!
      I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
      Content Creator at Skapeup
        Suggestions:
        Make the type box and Option box.
        I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
        • X Offline
          xrok1
          😎 this is greaaaat!
            @xrok1 said:
            8-) this is greaaaat!
            Nice patch. Is that just one plain colour for the grass?
            • soloS Offline
              This looks interesting....
              Thanks mate.
                rickgraham
                Umm my dialog box for furmaker is blank. ❓
                Rick
                  @solo said:
                  :shock:
                  Thanks mate.
                  Render comp?? πŸ˜„
                  • X Offline
                    xrok1
                    ground cover>Vegetation_Grass1
                    • jeff hammondJ Offline
                      Rick
                      [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
                      same here..
                      no fur for osx 😐
                        Ben Ritter
                        Quite fun to play around with. Thank you so much.
                        Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
                        Ben
                          rickgraham
                          Rick
                          [attachment=0:aem2yrs3]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:aem2yrs3]
                          same here..
                          no fur for osx 😐
                          Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
                          Rick
                          • X Offline
                            xrok1
                            would be nice to be able to pre-select the material though. i had to paint the branches green and then back to brown after.
                              SU Reviewer
                              Great Plugin! I'm in the process of reviewing it for my site. But I keep running into an issue, whenever I select my settings and then click the "Fur" button it creates the fur on the wrong side of the face. Always facing down. Is there a way to fix this?
                              Thanks for your efforts!
                              Living Einstein's dream through SketchUp.
                              "Imagination is a preview of life's coming attractions" - Albert Einstein
                              Joe Simhon ~ SketchUp Plugin Reviews
                              • soloS Offline
                                Make sure your face is orientated correctly.
                                  tak2hata
                                  Hi, Jeff and rick.
                                  I update Fur_en.rb
                                  The WebDialog has problem in Mac OSX.
                                  So I put another menu for the correspondence of this problem.
                                  The menu named "fur!(MAC)".
                                  Using InputBox Dialog.
                                  How in this?
                                  by TAK2HATA
                                    Very nice site. I've not seen it before. New?
                                    • daleD Offline
                                      dale
                                      Yes, Wow thanks for this. I got a feeling some real interesting things will happen with this plugin.
                                      • X Offline
                                        xrok1
                                        how can we access the component instance option? also did you consider the color preselect or a don't copy material option?
                                        also if it would remember settings from 1 usage to the next would be great. a drop down with saved presets would be even better. 😳
                                          rickgraham
                                          @tak2hata said:
                                          Hi, Jeff and rick.
                                          I update Fur_en.rb
                                          How in this?
                                          Works great now, many thanks!
                                          If I can make one little suggestion - I'm not sure if the PC guys are the same or not, but when the dialog box comes up, it is right in the middle of the screen and I have to move it each time. Is there a way to have come in some place other than center? And I would love to see documentation of what the various controls do.
                                          Again, thanks for the great plugin.
                                          Rick
                                          • X Offline
                                            xrok1
                                            i knew i should have popped that before it got out of hand! 😲
                                            who would have ever imagined fur for SU?????????????????????????????
                                            • 32
                                            • 33
                                            • 1 / 33
