    1.5k Posts 471 Posters 3.3m Views 470 Watching
      Unlikely to result in faces <1mm ?
        I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments πŸ˜„ )
        • ken28875K Offline
          ken28875
          What do you mean, TIG?
          Thanks,
          _KN
          Follow Your Dreams.
          • brookefoxB Offline
            brookefox
            My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
            S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
            Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
            ~ Brooke
              If a 'followme' type tool makes faces with dims <~1mm it will cause failures - a limitation of OpenGL ?
              I thought you might be making the equivalent of a 'followme' around a tight curve that made these small facets and crashed - but maybe not ?
              Can you successfully make the equivalent rounded/chamfer using the FollowMe tool 'raw' ?
              • ken28875K Offline
                ken28875
                Hi TIG,
                I don't have any problems with the Follow-me tool.
                Sketchup crashes only when I use RoundCorner. 😒
                Thanks,
                _KN
                Follow Your Dreams.
                • fredo6F Offline
                  @ken28875 said:
                  Hi TIG,
                  Thanks,
                  _KN
                  Ken,
                  Could you post or send me the model, so that I can have a look at whatcrashes.
                  I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
                  • fredo6F Offline
                    Normally the persistence is done for each individual tool, including the custom saving by the icons A, B, C, D
                    I am not clear of what is the bad visual effect. Coul you post a picture or the model.
                    • ken28875K Offline
                      ken28875
                      Ken,
                      Hi Fredo,
                      I just sent you a private message. Unfortunately I could not attach the file. It's bigger than the allowed size of 4mb.
                      Thanks,
                      _KN
                      Follow Your Dreams.
                        brookefox
                        Sorry, I missed that and will investigate further. Thank you.
                        Its only very slightly 'bad'. My understanding is worse, though, and that is what I was wanting to improve.
                        ~ Brooke
                          Are the edges Smooth by any chance?
                            brookefox
                            Well, obviously, I mean, well, er....
                            I thought I had checked that but obviously my methodology was seriously flawed.
                            Thanks, t.
                            ~ Brooke
                              Cris999
                              Hello
                              Is there another place to download this plugin?
                              I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
                              Thank You, Cris999
                                The 2.1c zip is fine I just re-downloaded it to test... Try again.
                                  Cris999
                                  I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
                                  Thank You
                                  • fredo6F Offline
                                    Thank You
                                    Which unzip program do you use?
                                      Cris999
                                      First: I tried to selfextract the file.
                                      Second: it was 7-Zip
                                      Third: WinAce
                                      Forth: I used a online unzipper service
                                      Fifth: I sent the file to somebody, asking him to unzip
                                      Sixth: I downloaded from another PC and tried unsuccessfully to unzip
                                      Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
                                      Thank You, Cris999
                                      • fredo6F Offline
                                        Third: WinAce
                                        Thank You, Cris999
                                        Maybe you should try to download WinZip (this is what I use to zip the files).
                                        In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
                                        • X Offline
                                          xrok1
                                          i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. πŸ˜„
                                            blair
                                            Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
                                            • 11
                                            • 12
                                            • 73
                                            • 74
                                            • 10 / 74
