    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 791.2k Views 175 Watching
      dedmin
      πŸ‘ πŸ‘
        charrr
        cool tool πŸ‘
          Here's the latest version
          http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          It has a new tool added 'ExtrudeEdgesByLoft'...
          [instructions here http://forums.sketchucation.com/viewtopic.php?p=231016#p231016]
          • ken28875K Offline
            ken28875
            @tig said:
            Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            Awesome, TIG! Your plugins are so useful to me that I use them at work everyday!
            Thank you, Sir. πŸ‘ πŸ‘
            Follow Your Dreams.
              Ben Ritter
              TIG, Thank you so much for all your newest releases. I appreciate your generosity in sharing.
                Here's ANOTHER update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                Fixes a reported glitch on the EEbyLathe tool that messed it up completing - orient etc...
                  chloesdad
                  TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
                    Here's another update [3rd of the day!]
                    In this one the FR lingvo file has been updated by Didier Bur...
                    I knew that Extrude Edges by Loft == Extruder des arΓͺtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
                    But Extruder des arΓͺtes par profilage entre courbes is not half as snappy ??? πŸ˜‰
                    The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
                    Anyway whatever fits is best...
                    πŸ˜„
                    Enjoy...
                      Better is "Tendre une surface entre 2 courbes" and more poetic πŸ˜‰
                      (tensile structure) a loft between 2 curves
                      • teufT Offline
                        teuf
                        I'm agree πŸ˜‰
                        What a good tool, TIG. Simple and efficient. Many thanks πŸ‘
                          Shall I leave you FRench purists to ponder ?
                          It's easy enough for you to edit your own FR lingvo files to say whatever you like - just open with Notepad and do a Find/Replace on the offending phrase and insert what you prefer...
                          your
                          or
                          Maillage entre courbes snappier
                          or
                          Courbes vers maillage ???
                          It's your language, so say it how you like...
                          Even EN-US users can even reword what their English version says, so
                          could be edited to
                          Loft a Mesh using Selected Curves
                          which is perhaps a more accurate name, but personally I am now 'stuck' with the EEby... epithet for these tools. πŸ˜’
                            Don't worry! At the end that is the best! πŸ˜‰
                              Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              A glitch in EEbyLoft's mesh-making when some curves had particular combinations of segment-count, and face-orientation reporting is fixed/improved...
                              ES lingvo updated by Diego-Rodriguez.
                                Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                EEbyRails and EEbyRailsByFace: Erasure of original curves glitch fixed.
                                EEbyFace: Variable renamed to avoid clash with EEbyRailsByFace.
                                EEbyLoft: Chinese lingvo file added by Hebeijianke.
                                  driven
                                  fantastic, yet again... and it works even on my Mac...
                                  so a question about spacing of interconnects.
                                  can they be set equal, i.e. distance between lines A and B = x equally spaced new lines?
                                    Because it's a 'bezier' curve that joins the curves the segments are not evenly spaced: however, some have asked if the 'segments per section' could be set individually - I am thinking about that... πŸ€“
                                    • ayan13A Offline
                                      ayan13
                                      I have no words to say!!!Great man!!!!You make our life better!!!!:)
                                      • ken28875K Offline
                                        ken28875
                                        I second that! πŸ˜‰
                                        Follow Your Dreams.
                                          Rip Tanion
                                          I find "Edges by Rails" to be by far my favorite of the set. I find it has the most predictable and satisfactory results.
                                            Hi TIG,
                                            Do you think that you could add the date to the topic title when you update them? I find myself checking it daily to see if you've updated the toolset.
                                            With the frequency that you bang out revisions it's hard to keep up with you 😲
                                            Just a thought
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 31
                                            • 32
                                            • 26 / 32
