    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      The picked curves/faces etc are now highlighted and 'color-coded' [this depends on the tool***]
      Typically they are:
      Profile[Face] =Cyan
      Rail/Rail1 = Magenta
      Rail2 = DarkVioletRed
      MeldingProfile[Face] = DarkCyan
      OtherFace = Orange
      ***See each Tools notes...
        Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        EEbyRailsByFace has been fixed - glitches with curve selection and color-coding locations.
          Here's the latest update - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          The Tooltips etc are now properly deBabelized into other languages...
          • U
            unclex
            Update Again……
            Wonderful things
            • H
              hsjzyangbin
              Thank you
                dedmin
                Is there a way to organize plugins into sub-menus?
                  A bit off topic, but yes.
                  See 'organizer' available on Smustard and also my earlier ideas drifting around where you could create your sub-menus in an early loading ruby [#.rb] and add your scripts to any one by giving them one of its global variables e.g. $submenu1 for the menu rather than "Plugins"...
                  I use it to group my plugins as
                  Construction[Guide] Tools
                  2D Tools
                  3D Shape Tools - Simple
                  3D Shape Tools - Complex
                  2D Manipulation Tools
                  3D Manipulation Tools
                  Camera/Image Tools
                  Text/Dims Tools
                  Terrain Tools
                  Other Tools
                  $submenu0 to $submenu9...
                    dedmin
                    • C
                      charrr
                      cool tool 👍
                        Here's the latest version
                        404 Not Found
                        (forums.sketchucation.com)
                        It has a new tool added 'ExtrudeEdgesByLoft'...
                        [instructions here http://forums.sketchucation.com/viewtopic.php?p=231016#p231016]
                        • ken28875K
                          ken28875
                          @tig said:
                          Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          Awesome, TIG! Your plugins are so useful to me that I use them at work everyday!
                          Thank you, Sir. 👍 👍
                          Follow Your Dreams.
                          • B
                            Ben Ritter
                            TIG, Thank you so much for all your newest releases. I appreciate your generosity in sharing.
                              Here's ANOTHER update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              Fixes a reported glitch on the EEbyLathe tool that messed it up completing - orient etc...
                              • C
                                chloesdad
                                TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
                                  Here's another update [3rd of the day!]
                                  In this one the FR lingvo file has been updated by Didier Bur...
                                  I knew that Extrude Edges by Loft == Extruder des arêtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
                                  But Extruder des arêtes par profilage entre courbes is not half as snappy ??? 😉
                                  The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
                                  Anyway whatever fits is best...
                                  Enjoy...
                                    Better is "Tendre une surface entre 2 courbes" and more poetic 😉
                                    (tensile structure) a loft between 2 curves
                                    • teufT
                                      teuf
                                      I'm agree 😉
                                      What a good tool, TIG. Simple and efficient. Many thanks 👍
                                        Shall I leave you FRench purists to ponder ?
                                        It's easy enough for you to edit your own FR lingvo files to say whatever you like - just open with Notepad and do a Find/Replace on the offending phrase and insert what you prefer...
                                        your
                                        or
                                        Maillage entre courbes snappier
                                        or
                                        Courbes vers maillage ???
                                        It's your language, so say it how you like...
                                        Even EN-US users can even reword what their English version says, so
                                        could be edited to
                                        Loft a Mesh using Selected Curves
                                        which is perhaps a more accurate name, but personally I am now 'stuck' with the EEby... epithet for these tools. 😒
                                          Don't worry! At the end that is the best! 😉
                                            Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                            A glitch in EEbyLoft's mesh-making when some curves had particular combinations of segment-count, and face-orientation reporting is fixed/improved...
                                            ES lingvo updated by Diego-Rodriguez.
                                            • 31
                                            • 32
                                            • 5 / 32
