    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
      Thanks for the reply. I think your suggestion of colours is the way to go. And will compliment the tool quite well. I see how it can't be applied to certain tools but still think it'll be well received
      • TIGT Online
        Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        The picked curves/faces etc are now highlighted and 'color-coded' [this depends on the tool***]
        Typically they are:
        Profile[Face] =Cyan
        Rail/Rail1 = Magenta
        Rail2 = DarkVioletRed
        MeldingProfile[Face] = DarkCyan
        OtherFace = Orange
        ***See each Tools notes...
        • TIGT Online
          Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          EEbyRailsByFace has been fixed - glitches with curve selection and color-coding locations.
          • TIGT Online
            Here's the latest update - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            The Tooltips etc are now properly deBabelized into other languages...
            • U Offline
              unclex
              Update Again……
              Wonderful things
              • H Offline
                hsjzyangbin
                Thank you
                  dedmin
                  Is there a way to organize plugins into sub-menus?
                  • TIGT Online
                    A bit off topic, but yes.
                    See 'organizer' available on Smustard and also my earlier ideas drifting around where you could create your sub-menus in an early loading ruby [#.rb] and add your scripts to any one by giving them one of its global variables e.g. $submenu1 for the menu rather than "Plugins"...
                    I use it to group my plugins as
                    Construction[Guide] Tools
                    2D Tools
                    3D Shape Tools - Simple
                    3D Shape Tools - Complex
                    2D Manipulation Tools
                    3D Manipulation Tools
                    Camera/Image Tools
                    Text/Dims Tools
                    Terrain Tools
                    Other Tools
                    $submenu0 to $submenu9...
                      dedmin
                        charrr
                        cool tool 👍
                        • TIGT Online
                          Here's the latest version
                          404 Not Found
                          (forums.sketchucation.com)
                          It has a new tool added 'ExtrudeEdgesByLoft'...
                          [instructions here http://forums.sketchucation.com/viewtopic.php?p=231016#p231016]
                          • ken28875K Offline
                            ken28875
                            @tig said:
                            Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                            Awesome, TIG! Your plugins are so useful to me that I use them at work everyday!
                            Thank you, Sir. 👍 👍
                            Follow Your Dreams.
                              Ben Ritter
                              TIG, Thank you so much for all your newest releases. I appreciate your generosity in sharing.
                              • TIGT Online
                                Here's ANOTHER update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                Fixes a reported glitch on the EEbyLathe tool that messed it up completing - orient etc...
                                  chloesdad
                                  TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
                                  • TIGT Online
                                    Here's another update [3rd of the day!]
                                    In this one the FR lingvo file has been updated by Didier Bur...
                                    I knew that Extrude Edges by Loft == Extruder des arêtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
                                    But Extruder des arêtes par profilage entre courbes is not half as snappy ??? 😉
                                    The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
                                    Anyway whatever fits is best...
                                    Enjoy...
                                      Better is "Tendre une surface entre 2 courbes" and more poetic 😉
                                      (tensile structure) a loft between 2 curves
                                      • teufT Offline
                                        teuf
                                        I'm agree 😉
                                        What a good tool, TIG. Simple and efficient. Many thanks 👍
                                        • TIGT Online
                                          Shall I leave you FRench purists to ponder ?
                                          It's easy enough for you to edit your own FR lingvo files to say whatever you like - just open with Notepad and do a Find/Replace on the offending phrase and insert what you prefer...
                                          your
                                          or
                                          Maillage entre courbes snappier
                                          or
                                          Courbes vers maillage ???
                                          It's your language, so say it how you like...
                                          Even EN-US users can even reword what their English version says, so
                                          could be edited to
                                          Loft a Mesh using Selected Curves
                                          which is perhaps a more accurate name, but personally I am now 'stuck' with the EEby... epithet for these tools. 😒
                                            Don't worry! At the end that is the best! 😉
                                            • 31
                                            • 32
                                            • 5 / 32
