    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 929.7k Views 175 Watching
    • U Offline
      unclex
      Update Againโ€ฆโ€ฆ
      Wonderful things
      • H Offline
        hsjzyangbin
        Thank you
          dedmin
          Is there a way to organize plugins into sub-menus?
            A bit off topic, but yes.
            See 'organizer' available on Smustard and also my earlier ideas drifting around where you could create your sub-menus in an early loading ruby [#.rb] and add your scripts to any one by giving them one of its global variables e.g. $submenu1 for the menu rather than "Plugins"...
            I use it to group my plugins as
            Construction[Guide] Tools
            2D Tools
            3D Shape Tools - Simple
            3D Shape Tools - Complex
            2D Manipulation Tools
            3D Manipulation Tools
            Camera/Image Tools
            Text/Dims Tools
            Terrain Tools
            Other Tools
            $submenu0 to $submenu9...
              dedmin
              ๐Ÿ‘ ๐Ÿ‘
                charrr
                cool tool ๐Ÿ‘
                  Here's the latest version
                  http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  It has a new tool added 'ExtrudeEdgesByLoft'...
                  [instructions here http://forums.sketchucation.com/viewtopic.php?p=231016#p231016]
                  • ken28875K Offline
                    ken28875
                    @tig said:
                    Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    Awesome, TIG! Your plugins are so useful to me that I use them at work everyday!
                    Thank you, Sir. ๐Ÿ‘ ๐Ÿ‘
                    Follow Your Dreams.
                      Ben Ritter
                      TIG, Thank you so much for all your newest releases. I appreciate your generosity in sharing.
                        Here's ANOTHER update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        Fixes a reported glitch on the EEbyLathe tool that messed it up completing - orient etc...
                          chloesdad
                          TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
                            Here's another update [3rd of the day!]
                            In this one the FR lingvo file has been updated by Didier Bur...
                            I knew that Extrude Edges by Loft == Extruder des arรชtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
                            But Extruder des arรชtes par profilage entre courbes is not half as snappy ??? ๐Ÿ˜‰
                            The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
                            Anyway whatever fits is best...
                            ๐Ÿ˜„
                            Enjoy...
                              Better is "Tendre une surface entre 2 courbes" and more poetic ๐Ÿ˜‰
                              (tensile structure) a loft between 2 curves
                              • teufT Offline
                                teuf
                                I'm agree ๐Ÿ˜‰
                                What a good tool, TIG. Simple and efficient. Many thanks ๐Ÿ‘
                                  Shall I leave you FRench purists to ponder ?
                                  It's easy enough for you to edit your own FR lingvo files to say whatever you like - just open with Notepad and do a Find/Replace on the offending phrase and insert what you prefer...
                                  your
                                  or
                                  Maillage entre courbes snappier
                                  or
                                  Courbes vers maillage ???
                                  It's your language, so say it how you like...
                                  Even EN-US users can even reword what their English version says, so
                                  could be edited to
                                  Loft a Mesh using Selected Curves
                                  which is perhaps a more accurate name, but personally I am now 'stuck' with the EEby... epithet for these tools. ๐Ÿ˜’
                                    Don't worry! At the end that is the best! ๐Ÿ˜‰
                                      Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      A glitch in EEbyLoft's mesh-making when some curves had particular combinations of segment-count, and face-orientation reporting is fixed/improved...
                                      ES lingvo updated by Diego-Rodriguez.
                                        Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                        EEbyRails and EEbyRailsByFace: Erasure of original curves glitch fixed.
                                        EEbyFace: Variable renamed to avoid clash with EEbyRailsByFace.
                                        EEbyLoft: Chinese lingvo file added by Hebeijianke.
                                          driven
                                          fantastic, yet again... and it works even on my Mac...
                                          so a question about spacing of interconnects.
                                          can they be set equal, i.e. distance between lines A and B = x equally spaced new lines?
                                            Because it's a 'bezier' curve that joins the curves the segments are not evenly spaced: however, some have asked if the 'segments per section' could be set individually - I am thinking about that... ๐Ÿค“
                                            • 31
                                            • 32
                                            • 5 / 32
