    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
    • ken28875K Offline
      ken28875
      @tig said:
      Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      It has a new tool added 'ExtrudeEdgesByLoft'...
      Awesome, TIG! Your plugins are so useful to me that I use them at work everyday!
      Thank you, Sir. ๐Ÿ‘ ๐Ÿ‘
      Follow Your Dreams.
        Ben Ritter
        TIG, Thank you so much for all your newest releases. I appreciate your generosity in sharing.
        • TIGT Online
          Here's ANOTHER update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          Fixes a reported glitch on the EEbyLathe tool that messed it up completing - orient etc...
            chloesdad
            TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
            • TIGT Online
              Here's another update [3rd of the day!]
              In this one the FR lingvo file has been updated by Didier Bur...
              I knew that Extrude Edges by Loft == Extruder des arรชtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
              But Extruder des arรชtes par profilage entre courbes is not half as snappy ??? ๐Ÿ˜‰
              The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
              Anyway whatever fits is best...
              ๐Ÿ˜„
              Enjoy...
                Better is "Tendre une surface entre 2 courbes" and more poetic ๐Ÿ˜‰
                (tensile structure) a loft between 2 curves
                • teufT Offline
                  teuf
                  I'm agree ๐Ÿ˜‰
                  What a good tool, TIG. Simple and efficient. Many thanks ๐Ÿ‘
                  • TIGT Online
                    Shall I leave you FRench purists to ponder ?
                    It's easy enough for you to edit your own FR lingvo files to say whatever you like - just open with Notepad and do a Find/Replace on the offending phrase and insert what you prefer...
                    your
                    or
                    Maillage entre courbes snappier
                    or
                    Courbes vers maillage ???
                    It's your language, so say it how you like...
                    Even EN-US users can even reword what their English version says, so
                    could be edited to
                    Loft a Mesh using Selected Curves
                    which is perhaps a more accurate name, but personally I am now 'stuck' with the EEby... epithet for these tools. ๐Ÿ˜’
                      Don't worry! At the end that is the best! ๐Ÿ˜‰
                      • TIGT Online
                        Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        A glitch in EEbyLoft's mesh-making when some curves had particular combinations of segment-count, and face-orientation reporting is fixed/improved...
                        ES lingvo updated by Diego-Rodriguez.
                        • TIGT Online
                          Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          EEbyRails and EEbyRailsByFace: Erasure of original curves glitch fixed.
                          EEbyFace: Variable renamed to avoid clash with EEbyRailsByFace.
                          EEbyLoft: Chinese lingvo file added by Hebeijianke.
                            driven
                            fantastic, yet again... and it works even on my Mac...
                            so a question about spacing of interconnects.
                            can they be set equal, i.e. distance between lines A and B = x equally spaced new lines?
                            • TIGT Online
                              Because it's a 'bezier' curve that joins the curves the segments are not evenly spaced: however, some have asked if the 'segments per section' could be set individually - I am thinking about that... ๐Ÿค“
                              • ayan13A Offline
                                ayan13
                                I have no words to say!!!Great man!!!!You make our life better!!!!:)
                                • ken28875K Offline
                                  ken28875
                                  I second that! ๐Ÿ˜‰
                                  Follow Your Dreams.
                                    Rip Tanion
                                    I find "Edges by Rails" to be by far my favorite of the set. I find it has the most predictable and satisfactory results.
                                      Hi TIG,
                                      Do you think that you could add the date to the topic title when you update them? I find myself checking it daily to see if you've updated the toolset.
                                      With the frequency that you bang out revisions it's hard to keep up with you ๐Ÿ˜ฒ
                                      Just a thought
                                      • TIGT Online
                                        The zip has the date as its name e.g. extrudeTools_20100312.zip and I do add an announcement to say it's changed and a link back to the base page, and I do add announcements to the individual tools' page too - linking back to their base pages, which in turn link back to the zipped set's base page. I stopped adding the update's date or version rference to the threads title because I kept forgetting to change it when I updated the zip ! ๐Ÿ˜’ By putting the date in the zip's name I avoid that error...
                                        So the answer to your request is... 'No' ๐Ÿ˜ฎ ๐Ÿ˜‰
                                          I suppose i was being a little unreasonable ๐Ÿ˜ฒ
                                          Must organize myself a bit better ๐Ÿ˜‰
                                          • TIGT Online
                                            Here is an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                            Several of the files had a potential [but very rare] glitch in calling sub-methods - it has now been fixed.
                                            The very few users who reported these problems should try this update and see if they now have a fully working set...
                                            Feedback please. ๐Ÿ˜•
                                            • 31
                                            • 32
                                            • 5 / 32
