    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
    • TIGT Online
      Here's ANOTHER update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      Fixes a reported glitch on the EEbyLathe tool that messed it up completing - orient etc...
        chloesdad
        TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
        • TIGT Online
          Here's another update [3rd of the day!]
          In this one the FR lingvo file has been updated by Didier Bur...
          I knew that Extrude Edges by Loft == Extruder des arรชtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
          But Extruder des arรชtes par profilage entre courbes is not half as snappy ??? ๐Ÿ˜‰
          The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
          Anyway whatever fits is best...
          ๐Ÿ˜„
          Enjoy...
            Better is "Tendre une surface entre 2 courbes" and more poetic ๐Ÿ˜‰
            (tensile structure) a loft between 2 curves
            • teufT Offline
              teuf
              I'm agree ๐Ÿ˜‰
              What a good tool, TIG. Simple and efficient. Many thanks ๐Ÿ‘
              • TIGT Online
                Shall I leave you FRench purists to ponder ?
                It's easy enough for you to edit your own FR lingvo files to say whatever you like - just open with Notepad and do a Find/Replace on the offending phrase and insert what you prefer...
                your
                or
                Maillage entre courbes snappier
                or
                Courbes vers maillage ???
                It's your language, so say it how you like...
                Even EN-US users can even reword what their English version says, so
                could be edited to
                Loft a Mesh using Selected Curves
                which is perhaps a more accurate name, but personally I am now 'stuck' with the EEby... epithet for these tools. ๐Ÿ˜’
                  Don't worry! At the end that is the best! ๐Ÿ˜‰
                  • TIGT Online
                    Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    A glitch in EEbyLoft's mesh-making when some curves had particular combinations of segment-count, and face-orientation reporting is fixed/improved...
                    ES lingvo updated by Diego-Rodriguez.
                    • TIGT Online
                      Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                      EEbyRails and EEbyRailsByFace: Erasure of original curves glitch fixed.
                      EEbyFace: Variable renamed to avoid clash with EEbyRailsByFace.
                      EEbyLoft: Chinese lingvo file added by Hebeijianke.
                        driven
                        fantastic, yet again... and it works even on my Mac...
                        so a question about spacing of interconnects.
                        can they be set equal, i.e. distance between lines A and B = x equally spaced new lines?
                        • TIGT Online
                          Because it's a 'bezier' curve that joins the curves the segments are not evenly spaced: however, some have asked if the 'segments per section' could be set individually - I am thinking about that... ๐Ÿค“
                          • ayan13A Offline
                            ayan13
                            I have no words to say!!!Great man!!!!You make our life better!!!!:)
                            • ken28875K Offline
                              ken28875
                              I second that! ๐Ÿ˜‰
                              Follow Your Dreams.
                                Rip Tanion
                                I find "Edges by Rails" to be by far my favorite of the set. I find it has the most predictable and satisfactory results.
                                  Hi TIG,
                                  Do you think that you could add the date to the topic title when you update them? I find myself checking it daily to see if you've updated the toolset.
                                  With the frequency that you bang out revisions it's hard to keep up with you ๐Ÿ˜ฒ
                                  Just a thought
                                  • TIGT Online
                                    The zip has the date as its name e.g. extrudeTools_20100312.zip and I do add an announcement to say it's changed and a link back to the base page, and I do add announcements to the individual tools' page too - linking back to their base pages, which in turn link back to the zipped set's base page. I stopped adding the update's date or version rference to the threads title because I kept forgetting to change it when I updated the zip ! ๐Ÿ˜’ By putting the date in the zip's name I avoid that error...
                                    So the answer to your request is... 'No' ๐Ÿ˜ฎ ๐Ÿ˜‰
                                      I suppose i was being a little unreasonable ๐Ÿ˜ฒ
                                      Must organize myself a bit better ๐Ÿ˜‰
                                      • TIGT Online
                                        Here is an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                        Several of the files had a potential [but very rare] glitch in calling sub-methods - it has now been fixed.
                                        The very few users who reported these problems should try this update and see if they now have a fully working set...
                                        Feedback please. ๐Ÿ˜•
                                        • TIGT Online
                                          Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                          EEbyLathe has been changed - see its updated help thread for full details...
                                          It now has dynamic angle and segment [45 or 9s] entry in the VCB and a 'ghost display' of what it'll make OR if you enter 0 as the angle you can pick two points to set the rotation angle, with <Alt> to toggle <>180 degrees and <Shift> to toggle c/clockwise...
                                          The affected 'lingvo' files will be updated shortly...
                                          • ken28875K Offline
                                            ken28875
                                            Great! Thank you, Sir. ๐Ÿ‘
                                            Follow Your Dreams.
                                            • 31
                                            • 32
                                            • 5 / 32
