    [Plugin] Component Dropper
    49 Posts 21 Posters 57.5k Views 21 Watching
    • X
      xrok1
      very punny Solo. but i like it!
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        Unfortunately 'dropper' in English is usually taken as something to do with 'dropping' - i.e. it is 'something that 'makes drops' [drops = either some actual or potential physical movements downwards, or small globules of liquid] or makes things 'drop' [i.e. to move downwards] - long before it clicks that it is meant as 'eye-dropper' [something that makes **eye-**drops - i.e. globules of liquid that fall into the eye from a rubber-bulb activated pipette - commonly called an 'eye-dropper']...
        So I recommend that you either rename it 'eye-dropper' or 'matcher' or 'swapper/swopper' or something else that doesn't sound like it's to do with things being made to fall downwards - the older tool 'Drop' moves selected components downwards so 'Dropper' sounds like it'll do something similar !!! ... ๐Ÿ˜’
        PS: it's a great idea otherwise ๐Ÿ˜„
          Swopper it is!
          Well, that is - you got until my next update to name this ... thingy-ma-jiggy.
          • utilerU
            utiler
            cool, Thomas, D/L and having a play!!!
            Just Curious...
              What happend about the old component? Killed?
                Yes, the instance is slaughtered.
                  d12dozr
                  ๐Ÿ˜ฎ ๐Ÿคฃ Thanks for a good laugh Thomthom!
                  http://goo.gl/f7ooYh
                  • bagateloB
                    bagatelo
                    Great ThomThom. I had already thought previously about a plugin that made this.
                    For the name given to this script I thought that it was this plugin:
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=20233&p=223396#p223396
                    ๐Ÿ˜ž
                      Thx for the precision ๐Ÿ˜‰
                      http://www.monsieurpoulet.com/fichiers/7848/produits/4985/max_tir_au_pigeons.jpg
                      • H
                        hsjzyangbin
                        very funny
                          arjunmax09
                          cool plugin thomthom... don't take a cookie .... you deserve a cake man... ๐Ÿ˜„chocolate-cake-oh-1727433-x.jpg
                          PS... i've eaten one piece out of it... hehe ๐Ÿ˜†
                          when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          • U
                            unclex
                            use it.... for what ?????
                              No chance to see Component Dropper multiple?
                              That will be very cool! โ˜€
                              1. Make a selection containing groups and components in a certain order (or automatically randomly with a general selection). (Doesn't matter if it contains more, it'll be ignored.)
                              2. Activate the tool
                              3. Pick another group**"s"** or component**"s"** instance in a certain order (or automatically randomly with a general selection) to replace your selection.
                                in a certain order
                                In which order?
                                  certain order
                                  In the order of the one by one clic selection
                                  Ps about the plug itself first post
                                  Does it possible to keep the original size of the component and not an adapted size?
                                  ( a simple past replace in place)
                                    No. But I've wanted this myself. So added to todo list.
                                    • EdsonE
                                      Edson
                                      Comp Dropper never got renamed to Comp Swopper, right?
                                      edson mahfuz, architect| porto alegre โ€ข brasil
                                      http://www.mahfuz.arq.br
                                      • EdsonE
                                        Edson
                                        thomas,
                                        correct me if I am wrong. the way this plugin improves on the regular method (choosing a number of components in the model and replacing by another by right-clicking on this 2nd one in the components dialog and choosing "replace selected") is because it can also perform the same act on groups whereas the native method works only on components.
                                          It also tries to preserve the component instance's size.
                                          • V
                                            victor hugo
                                            Is there something like the dropgc but to be undropped?
                                            reason for this is when I work on placing light fixtures on a reflected ceiling, I will have those placed on the floor plan then "undrop" so they will attach to the ceiling?
                                            is there something like it out there to do this?.
                                            Thanks.
                                            • 1 / 3
