    [Plugin] Component Dropper
    49 Posts 21 Posters 54.9k Views 21 Watching
    • X Offline
      xrok1
      good then, its just that when i first spotted this thread i was thinking of smartdrop at intersection and wondered what else could be done? drop is drop. ๐Ÿ˜• ๐Ÿ˜†
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
      • soloS Offline
        swopper.rb?
        • X Offline
          xrok1
          very punny Solo. but i like it!
            Unfortunately 'dropper' in English is usually taken as something to do with 'dropping' - i.e. it is 'something that 'makes drops' [drops = either some actual or potential physical movements downwards, or small globules of liquid] or makes things 'drop' [i.e. to move downwards] - long before it clicks that it is meant as 'eye-dropper' [something that makes **eye-**drops - i.e. globules of liquid that fall into the eye from a rubber-bulb activated pipette - commonly called an 'eye-dropper']...
            So I recommend that you either rename it 'eye-dropper' or 'matcher' or 'swapper/swopper' or something else that doesn't sound like it's to do with things being made to fall downwards - the older tool 'Drop' moves selected components downwards so 'Dropper' sounds like it'll do something similar !!! ... ๐Ÿ˜’
            PS: it's a great idea otherwise ๐Ÿ˜„
              Swopper it is!
              Well, that is - you got until my next update to name this ... thingy-ma-jiggy.
              • utilerU Offline
                utiler
                cool, Thomas, D/L and having a play!!!
                Just Curious...
                  What happend about the old component? Killed?
                    Yes, the instance is slaughtered.
                      d12dozr
                      ๐Ÿ˜ฎ ๐Ÿคฃ Thanks for a good laugh Thomthom!
                      http://goo.gl/f7ooYh
                      • bagateloB Offline
                        bagatelo
                        Great ThomThom. I had already thought previously about a plugin that made this.
                        For the name given to this script I thought that it was this plugin:
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=20233&p=223396#p223396
                        ๐Ÿ˜ž
                          Thx for the precision ๐Ÿ˜‰
                          http://www.monsieurpoulet.com/fichiers/7848/produits/4985/max_tir_au_pigeons.jpg
                          • H Offline
                            hsjzyangbin
                            very funny
                              arjunmax09
                              cool plugin thomthom... don't take a cookie .... you deserve a cake man... ๐Ÿ˜„chocolate-cake-oh-1727433-x.jpg
                              PS... i've eaten one piece out of it... hehe ๐Ÿ˜†
                              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                              • U Offline
                                unclex
                                use it.... for what ?????
                                  No chance to see Component Dropper multiple?
                                  That will be very cool! โ˜€
                                  1. Make a selection containing groups and components in a certain order (or automatically randomly with a general selection). (Doesn't matter if it contains more, it'll be ignored.)
                                  2. Activate the tool
                                  3. Pick another group**"s"** or component**"s"** instance in a certain order (or automatically randomly with a general selection) to replace your selection.
                                    in a certain order
                                    In which order?
                                      certain order
                                      In the order of the one by one clic selection
                                      Ps about the plug itself first post
                                      Does it possible to keep the original size of the component and not an adapted size?
                                      ( a simple past replace in place)
                                        No. But I've wanted this myself. So added to todo list.
                                        • EdsonE Offline
                                          Edson
                                          Comp Dropper never got renamed to Comp Swopper, right?
                                          edson mahfuz, architect| porto alegre โ€ข brasil
                                          http://www.mahfuz.arq.br
                                          • EdsonE Offline
                                            Edson
                                            thomas,
                                            correct me if I am wrong. the way this plugin improves on the regular method (choosing a number of components in the model and replacing by another by right-clicking on this 2nd one in the components dialog and choosing "replace selected") is because it can also perform the same act on groups whereas the native method works only on components.
                                            • 1 / 3
