    [Plugin] Component Dropper
    49 Posts 21 Posters 55.8k Views 21 Watching
    • soloS Offline
      swopper.rb?
      • X Offline
        xrok1
        very punny Solo. but i like it!
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          Unfortunately 'dropper' in English is usually taken as something to do with 'dropping' - i.e. it is 'something that 'makes drops' [drops = either some actual or potential physical movements downwards, or small globules of liquid] or makes things 'drop' [i.e. to move downwards] - long before it clicks that it is meant as 'eye-dropper' [something that makes **eye-**drops - i.e. globules of liquid that fall into the eye from a rubber-bulb activated pipette - commonly called an 'eye-dropper']...
          So I recommend that you either rename it 'eye-dropper' or 'matcher' or 'swapper/swopper' or something else that doesn't sound like it's to do with things being made to fall downwards - the older tool 'Drop' moves selected components downwards so 'Dropper' sounds like it'll do something similar !!! ... ๐Ÿ˜’
          PS: it's a great idea otherwise ๐Ÿ˜„
            Swopper it is!
            Well, that is - you got until my next update to name this ... thingy-ma-jiggy.
            • utilerU Offline
              utiler
              cool, Thomas, D/L and having a play!!!
              Just Curious...
                What happend about the old component? Killed?
                  Yes, the instance is slaughtered.
                    d12dozr
                    ๐Ÿ˜ฎ ๐Ÿคฃ Thanks for a good laugh Thomthom!
                    http://goo.gl/f7ooYh
                    • bagateloB Offline
                      bagatelo
                      Great ThomThom. I had already thought previously about a plugin that made this.
                      For the name given to this script I thought that it was this plugin:
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=20233&p=223396#p223396
                      ๐Ÿ˜ž
                        Thx for the precision ๐Ÿ˜‰
                        http://www.monsieurpoulet.com/fichiers/7848/produits/4985/max_tir_au_pigeons.jpg
                        • H Offline
                          hsjzyangbin
                          very funny
                            arjunmax09
                            cool plugin thomthom... don't take a cookie .... you deserve a cake man... ๐Ÿ˜„chocolate-cake-oh-1727433-x.jpg
                            PS... i've eaten one piece out of it... hehe ๐Ÿ˜†
                            when you fail at something....you haven't really failed...you've found one way the thing will not work out
                            • U Offline
                              unclex
                              use it.... for what ?????
                                No chance to see Component Dropper multiple?
                                That will be very cool! โ˜€
                                1. Make a selection containing groups and components in a certain order (or automatically randomly with a general selection). (Doesn't matter if it contains more, it'll be ignored.)
                                2. Activate the tool
                                3. Pick another group**"s"** or component**"s"** instance in a certain order (or automatically randomly with a general selection) to replace your selection.
                                  in a certain order
                                  In which order?
                                    certain order
                                    In the order of the one by one clic selection
                                    Ps about the plug itself first post
                                    Does it possible to keep the original size of the component and not an adapted size?
                                    ( a simple past replace in place)
                                      No. But I've wanted this myself. So added to todo list.
                                      • EdsonE Offline
                                        Edson
                                        Comp Dropper never got renamed to Comp Swopper, right?
                                        edson mahfuz, architect| porto alegre โ€ข brasil
                                        http://www.mahfuz.arq.br
                                        • EdsonE Offline
                                          Edson
                                          thomas,
                                          correct me if I am wrong. the way this plugin improves on the regular method (choosing a number of components in the model and replacing by another by right-clicking on this 2nd one in the components dialog and choosing "replace selected") is because it can also perform the same act on groups whereas the native method works only on components.
                                            It also tries to preserve the component instance's size.
                                            • 1 / 3
