    [Plugin] Component Dropper
    49 Posts 21 Posters 56.9k Views 21 Watching
    • utilerU Offline
      utiler
      cool, Thomas, D/L and having a play!!!
      Just Curious...
        What happend about the old component? Killed?
          Yes, the instance is slaughtered.
            d12dozr
            ๐Ÿ˜ฎ ๐Ÿคฃ Thanks for a good laugh Thomthom!
            http://goo.gl/f7ooYh
            • bagateloB Offline
              bagatelo
              Great ThomThom. I had already thought previously about a plugin that made this.
              For the name given to this script I thought that it was this plugin:
              http://forums.sketchucation.com/viewtopic.php?f=323&t=20233&p=223396#p223396
              ๐Ÿ˜ž
                Thx for the precision ๐Ÿ˜‰
                http://www.monsieurpoulet.com/fichiers/7848/produits/4985/max_tir_au_pigeons.jpg
                • H Offline
                  hsjzyangbin
                  very funny
                    arjunmax09
                    cool plugin thomthom... don't take a cookie .... you deserve a cake man... ๐Ÿ˜„chocolate-cake-oh-1727433-x.jpg
                    PS... i've eaten one piece out of it... hehe ๐Ÿ˜†
                    when you fail at something....you haven't really failed...you've found one way the thing will not work out
                    • U Offline
                      unclex
                      use it.... for what ?????
                        No chance to see Component Dropper multiple?
                        That will be very cool! โ˜€
                        1. Make a selection containing groups and components in a certain order (or automatically randomly with a general selection). (Doesn't matter if it contains more, it'll be ignored.)
                        2. Activate the tool
                        3. Pick another group**"s"** or component**"s"** instance in a certain order (or automatically randomly with a general selection) to replace your selection.
                          in a certain order
                          In which order?
                            certain order
                            In the order of the one by one clic selection
                            Ps about the plug itself first post
                            Does it possible to keep the original size of the component and not an adapted size?
                            ( a simple past replace in place)
                              No. But I've wanted this myself. So added to todo list.
                              • EdsonE Offline
                                Edson
                                Comp Dropper never got renamed to Comp Swopper, right?
                                edson mahfuz, architect| porto alegre โ€ข brasil
                                http://www.mahfuz.arq.br
                                • EdsonE Offline
                                  Edson
                                  thomas,
                                  correct me if I am wrong. the way this plugin improves on the regular method (choosing a number of components in the model and replacing by another by right-clicking on this 2nd one in the components dialog and choosing "replace selected") is because it can also perform the same act on groups whereas the native method works only on components.
                                    It also tries to preserve the component instance's size.
                                    • V Offline
                                      victor hugo
                                      Is there something like the dropgc but to be undropped?
                                      reason for this is when I work on placing light fixtures on a reflected ceiling, I will have those placed on the floor plan then "undrop" so they will attach to the ceiling?
                                      is there something like it out there to do this?.
                                      Thanks.
                                        I have made in the past a sort of Undrop
                                        Not sure it's that you want ?
                                        You have also Eclate Deplace By Cplassay and me ๐Ÿ˜‰
                                        But if your lights are not Group or component that will be impossible!
                                        • V Offline
                                          victor hugo
                                          It is just the opposite of the DropGC...select compoment then undrop so instead of going down it will go up and hit the ceiling.
                                          I have those as component/group.
                                          I'll look at your links and see if it work for me.
                                          Thanks for replying.
                                          • Y Offline
                                            Yucon
                                            Hi Tom,
                                            I am trying to use your plugin and it almost works great but the boxes are jumping away from the original position. Is that a problem for sketchup 2013 maybe?
                                            See here some screenshots http://puu.sh/6g5M2.jpg and http://puu.sh/6g5Nx.jpg. I tried it on several models.
                                            Hope you can help me.
                                            • 2 / 3
