    Rendering workshop - Whisky Glass
    71 Posts 19 Posters 19.3k Views 19 Watching
      Another thing: how is the glass modelled?
      Was doing some test over at the ASGVis forum, playing around with caustics. Learned that when rendering glass with liquids, the liquid inside the glass also needs to be a "solid", with the surfaces between the liquid and the glass slightly offset (to avoid z-fighting).
        @al hart said:
        What are the refraction indices for metals used for?
        I've used them in the reflection layers with fresnel maps. (...not quite sure if this is correct though..)
        • GaieusG
          Well, it probably depends on the software. AFAIK Majid once made a nice description of this (that was Kerkythea) where he said that when there is the liquid, you use that material insteadof the glass material. Face orientation is very important of course (and even more of course, I am not even sure what I am talking about and whether I remember correctly)
            @thom
            I'll try that later, thanks for the tip
            @gaieus
            have you tried this out on Twilight? When you mention material rather liquid, which material in particular?
            @the world
            aaaaaaaaarrrrrrrgggggghhhhhhhhh!
            • GaieusG
              @gaieus
              Not yet. Will do...
              Well, the liquid material that is insidethe glass.
                Found my thread about glass+liquid+caustic at the ASGVis forum: http://forum.asgvis.com/index.php?topic=6135.0
                • GaieusG
                  Now this is too much light obviously... Another one (also with a bit more interesting setup, too 😉 ) is cooking ATM.
                  Well, the "other one" - now the cigar box could be a bit lighter but I leave it like that.
                  ![17 passes "Easy10 Interior+" (unbiased progressive) in Twilight in a bit less than 30 minutes - original 800x600 then some noise reduction and downsample to 640x480](/uploads/imported_attachments/90u9_WhiskyGlass3.jpg "17 passes "Easy10 Interior+" (unbiased progressive) in Twilight in a bit less than 30 minutes - original 800x600 then some noise reduction and downsample to 640x480")
                  • Al HartA
                    Al Hart
                    This Workshop is a good chance to study lighting and distortion.
                    Your ice does not seem to distort the whiskey. Did you place any refraction on the ice itself?
                    Al Hart
                    IRender nXt from Render Plus
                    • GaieusG
                      Well, to me it seems it does distort it - the "whisky-line" is different through the ice cube than on its sides.
                      Yes, I used a physically correctly built Kerkythea library material.
                      • Al HartA
                        Al Hart
                        I guess I do see a little distortion, but not as much as in this rendering by modelhead
                        Al Hart
                        • soloS
                          • GaieusG
                            Well, I have to say that I have never really seen such colourful ice cubes even in whisky.
                            When I made a prelim render (just to see where the lights are going), I also had something similar though.
                              @gaieus
                              care to share settings and materials used?
                              Great render btw 👍
                              • GaieusG
                                I'll try to find them (some of them were Kerkythea libraries so aren't just as easy as to upload the file and it brings all the settings with it).
                                So Ice cube > Kerkythea library > Translucent > Ice cube.
                                Glass > Kerkythea library > Translucent > Glass-Crown K7 (whatever it is 😒 )
                                For the whisky, I started from some SSS material and set the following
                                Alpha: 30.000
                                IOR 1.700
                                Shininess: 128.000
                                SSS density: 1.000 (maybe it means no SSS at all? I am totally lost when it comes to such details).
                                Now beside the sun (that I tuned down to 3.000), there is also a spotlight "behind" the glass and pointing through the glass. This always helps "emphasize" caustics (you need a lot of light for that) and way above, there is also a point light (set just to 0.1 strength) to give a little "global illumination" to the whole scene. Somehow like this:
                                • GaieusG
                                  Okay, so here is another one with a different ice material (a very slightly frosted one with fresnel procedural - which I have to confess, I don't know what will do to it).
                                  • Al HartA
                                    Al Hart
                                    Much better ice, though, don't you think.
                                    Fresnel has to do with reflections at the very edge of the ice.
                                    If you have time, (isn't it either very early or very late in your part of the world) - (It is 1:30 in the afternoon here in Colorado), why don't you zoom in on just the ice cube, and make two renderings - one with Fresnel on and one with it off.
                                    (Some rendering people just know what these thing do. I find I have to try them out, compare the result, and see what I like best.)
                                    (Also, I knew so little about Fresnel a couple of months ago when we added his reflection properties to our renderer that I had to look up on the web how to pronounce his name properly.)
                                    When referring to the scientist the proper pronunciation of Fresnel is " Fray-nel' "; it was his name after all. When referring to the lens the pronunciation 'frez-nel' is accepted. Like many foreign words the pronunciation has become westernized.
                                    Al Hart
                                    • Al HartA
                                      Al Hart
                                      @solo said:
                                      :shock:
                                      I was trying to place a fly in the ice yesterday, but SketchUp crashed on me, and I didn't get back to it.
                                      http://sketchup.google.com/3dwarehouse/download?mid=86954808ef0d9ade859e000cdbd98252&rtyp=st&ctyp=other&ts=1202487120000
                                      I was expecting to see some inventive changes to the model - such as turning the ice into a flaming item.
                                      Al Hart
                                        drfabinex
                                        This was my third or fourth try with Twilight.
                                        Picture is a little small and grainy which is a testament to my impatience 😳 but I think it looks pretty good. I AM having a problem with the reflection on the top of the whiskey, as you can see, no opacity. I changed the reflection color to match the whiskey. If anybody has any thoughts i'd love to hear them.
                                        The pic is a little blown admittedly. I had all sorts of troubles setting up lights so I tried this render with just the standard sun settings, no lights.
                                        In Sketchup I edited the material of the glass and ice to 15 opacity and and made their color white. I also lightened the whiskey color.
                                        In Twilight I used the Water template for the whiskey and ice and the realistic glass (common) for the glass.
                                        I set the IOR values to the ones given in this thread, (thanks guys, I had no idea you could find those values!)
                                        Rendered for 2h (200 passes i think) on the INTERIOR+ setting.
                                        I appreciate this alot, threads like these are invaluable to this rendering noob
                                        Twilight render. 2h (200 passes) interior+
                                        • Al HartA
                                          Al Hart
                                          @drfabinex said:
                                          I appreciate this a lot, threads like these are invaluable to this rendering noob
                                          Thanks.
                                          I have sometimes been criticized for posting these Rendering Workshops. But I think it important to remember that there are beginners who would love to try their hand at some "simple" rendering techniques, and receive advice from the more experienced users.
                                          Even people who delve into transparency and IOR rarely take the time to try some different settings. For example, Solo posted some IOR values to use. (Thanks Solo - I am not being critical). But there might me some other interesting things to try as well - different IOR values and/or reflection values.
                                          Al Hart
                                          • N
                                            notareal
                                            A glass with liquid is a tricy target to solve for many rendering applications. A modelling quide for Kerkythea users: http://www.kerkythea.net/phpBB2/files/dielectrice_glass_modeling_normals_echo2web_129.jpg (you can find this and more tutorials at the KT forums)
                                            I used a HDR studio with this render. A small mesh emitter is used on the right side of the glass. There is no post pro. I did let it render over night, so no idea for a good enough render time.
                                            Kerkythea Echo 2008.  Metropolis light transport (BPT). Rendertime 7 hours <a class=@i7 920." title="Kerkythea Echo 2008. Metropolis light transport (BPT). Rendertime 7 hours @i7 920." class="img-markdown img-fluid" />
                                            • 2 / 4
