    Rendering workshop - Whisky Glass
    71 Posts 19 Posters 19.3k Views 19 Watching
    • Al HartA
      Al Hart
      @thomthom said:
      @honoluludesktop said:
      Solo, How did you know that? Do you just remember, or do you have a spread sheet of successful settings?
      Lots of lists available. Just search for IOR or Index Of Refraction. Here's one: http://www.robinwood.com/Catalog/Technical/Gen3DTuts/Gen3DPages/RefractionIndexList.html
      I guess I have a lot to learn about IOR.
      What are the refraction indices for metals used for?
      Metals
      Aluminum 1.39
      Copper 2.43
      Gold 0.47
      Mylar 1.65
      Nickel 1.08
      Platinum 2.33
      Al Hart
      IRender nXt from Render Plus
      • Al HartA
        Al Hart
        I ended up on that same site-- its very interesting.
        Anyone know of a similar table for reflectivity?
        I suspect he is looking for amount of reflection, sharpness, etc. for solid materials
        And perhaps for additional reflection for transparent materials
        Al Hart
          Still struggling on this one 😠
          Not happy with the WhiskEy but i'll keep at it
          • Al HartA
            Al Hart
            Not happy with the Whiskey but i'll keep at it
            Much better than the first rendering. Nice ice this time.
            Did you change the color of the Whiskey?
            Try pouring it put and refilling the glass. 😉
            Al Hart
              Didn't change anything?
              Must be my choice of 'Glass' for the Whiskey, but i'll keep with till i get good feedback
                Another thing: how is the glass modelled?
                Was doing some test over at the ASGVis forum, playing around with caustics. Learned that when rendering glass with liquids, the liquid inside the glass also needs to be a "solid", with the surfaces between the liquid and the glass slightly offset (to avoid z-fighting).
                  I've used them in the reflection layers with fresnel maps. (...not quite sure if this is correct though..)
                  • GaieusG
                    Well, it probably depends on the software. AFAIK Majid once made a nice description of this (that was Kerkythea) where he said that when there is the liquid, you use that material insteadof the glass material. Face orientation is very important of course (and even more of course, I am not even sure what I am talking about and whether I remember correctly)
                      @thom
                      I'll try that later, thanks for the tip
                      @gaieus
                      have you tried this out on Twilight? When you mention material rather liquid, which material in particular?
                      @the world
                      aaaaaaaaarrrrrrrgggggghhhhhhhhh!
                      • GaieusG
                        @gaieus
                        Not yet. Will do...
                        Well, the liquid material that is insidethe glass.
                          Found my thread about glass+liquid+caustic at the ASGVis forum: http://forum.asgvis.com/index.php?topic=6135.0
                          • GaieusG
                            Now this is too much light obviously... Another one (also with a bit more interesting setup, too 😉 ) is cooking ATM.
                            Well, the "other one" - now the cigar box could be a bit lighter but I leave it like that.
                            ![17 passes "Easy10 Interior+" (unbiased progressive) in Twilight in a bit less than 30 minutes - original 800x600 then some noise reduction and downsample to 640x480](/uploads/imported_attachments/90u9_WhiskyGlass3.jpg "17 passes "Easy10 Interior+" (unbiased progressive) in Twilight in a bit less than 30 minutes - original 800x600 then some noise reduction and downsample to 640x480")
                            • Al HartA
                              Al Hart
                              This Workshop is a good chance to study lighting and distortion.
                              Your ice does not seem to distort the whiskey. Did you place any refraction on the ice itself?
                              Al Hart
                              • GaieusG
                                Well, to me it seems it does distort it - the "whisky-line" is different through the ice cube than on its sides.
                                Yes, I used a physically correctly built Kerkythea library material.
                                • Al HartA
                                  Al Hart
                                  I guess I do see a little distortion, but not as much as in this rendering by modelhead
                                  Al Hart
                                  • soloS
                                    • GaieusG
                                      Well, I have to say that I have never really seen such colourful ice cubes even in whisky.
                                      When I made a prelim render (just to see where the lights are going), I also had something similar though.
                                        @gaieus
                                        care to share settings and materials used?
                                        Great render btw 👍
                                        • GaieusG
                                          I'll try to find them (some of them were Kerkythea libraries so aren't just as easy as to upload the file and it brings all the settings with it).
                                          So Ice cube > Kerkythea library > Translucent > Ice cube.
                                          Glass > Kerkythea library > Translucent > Glass-Crown K7 (whatever it is 😒 )
                                          For the whisky, I started from some SSS material and set the following
                                          Alpha: 30.000
                                          IOR 1.700
                                          Shininess: 128.000
                                          SSS density: 1.000 (maybe it means no SSS at all? I am totally lost when it comes to such details).
                                          Now beside the sun (that I tuned down to 3.000), there is also a spotlight "behind" the glass and pointing through the glass. This always helps "emphasize" caustics (you need a lot of light for that) and way above, there is also a point light (set just to 0.1 strength) to give a little "global illumination" to the whole scene. Somehow like this:
                                          • GaieusG
                                            Okay, so here is another one with a different ice material (a very slightly frosted one with fresnel procedural - which I have to confess, I don't know what will do to it).
                                            • 2 / 4
