    Rendering workshop - Whisky Glass
    71 Posts 19 Posters 18.2k Views 19 Watching
    • Al HartA Offline
      Al Hart
      @solo said:
      Al, here are the correct IOR values:
      Ice: 1.310
      Whiskey: 1.352
      Heavy glass: 1.650
      I gave these settings a shot. I also rotated the glass so that some of the ice was seen directly. The ice looks pretty good.
      Al Hart
      IRender nXt from Render Plus
      • honoluludesktopH Offline
        honoluludesktop
        Solo, How did you know that? Do you just remember, or do you have a spread sheet of successful settings?
        • Al HartA Offline
          Al Hart
          I was wondering that too. To get numbers that precise, he must have a measuring device where he passes light through a material and sees how distorted it gets.
          http://www.v-med.net/images/RefTopKer_350.gif
          Al Hart
            Lots of lists available. Just search for IOR or Index Of Refraction. Here's one: http://www.robinwood.com/Catalog/Technical/Gen3DTuts/Gen3DPages/RefractionIndexList.html
            • soloS Offline
              Nice list Thomthom, I have this ratty looking, frayed notebook that I write stuff in as I learn it, most of the time I cannot find where I wrote anything and have to use Google to relearn it. 😉
              Scratch that...I'm a genius!!
                museummaker
                I ended up on that same site-- its very interesting.
                Anyone know of a similar table for reflectivity?
                  You mean for Fresnel material? Think you use the same tables...
                  For instance, the list includes non-transparent material, such as metals. (note - I'm a bit unsure here - but it's what I do and it seem to look ok...)
                  http://interactagram.com/physics/optics/refraction/
                  http://www.texloc.com/closet/cl_refractiveindex.html
                  • Al HartA Offline
                    Al Hart
                    I guess I have a lot to learn about IOR.
                    What are the refraction indices for metals used for?
                    Metals
                    Aluminum 1.39
                    Copper 2.43
                    Gold 0.47
                    Mylar 1.65
                    Nickel 1.08
                    Platinum 2.33
                    Al Hart
                    • Al HartA Offline
                      Al Hart
                      I suspect he is looking for amount of reflection, sharpness, etc. for solid materials
                      And perhaps for additional reflection for transparent materials
                      Al Hart
                        Still struggling on this one 😠
                        Not happy with the WhiskEy but i'll keep at it
                        • Al HartA Offline
                          Al Hart
                          Not happy with the Whiskey but i'll keep at it
                          Much better than the first rendering. Nice ice this time.
                          Did you change the color of the Whiskey?
                          Try pouring it put and refilling the glass. 😉
                          Al Hart
                            Didn't change anything?
                            Must be my choice of 'Glass' for the Whiskey, but i'll keep with till i get good feedback
                              Another thing: how is the glass modelled?
                              Was doing some test over at the ASGVis forum, playing around with caustics. Learned that when rendering glass with liquids, the liquid inside the glass also needs to be a "solid", with the surfaces between the liquid and the glass slightly offset (to avoid z-fighting).
                                I've used them in the reflection layers with fresnel maps. (...not quite sure if this is correct though..)
                                  Well, it probably depends on the software. AFAIK Majid once made a nice description of this (that was Kerkythea) where he said that when there is the liquid, you use that material insteadof the glass material. Face orientation is very important of course (and even more of course, I am not even sure what I am talking about and whether I remember correctly)
                                    @thom
                                    I'll try that later, thanks for the tip
                                    @gaieus
                                    have you tried this out on Twilight? When you mention material rather liquid, which material in particular?
                                    @the world
                                    aaaaaaaaarrrrrrrgggggghhhhhhhhh!
                                      @gaieus
                                      Not yet. Will do...
                                      Well, the liquid material that is insidethe glass.
                                        Found my thread about glass+liquid+caustic at the ASGVis forum: http://forum.asgvis.com/index.php?topic=6135.0
                                          Now this is too much light obviously... Another one (also with a bit more interesting setup, too 😉 ) is cooking ATM.
                                          Well, the "other one" - now the cigar box could be a bit lighter but I leave it like that.
                                          ![17 passes "Easy10 Interior+" (unbiased progressive) in Twilight in a bit less than 30 minutes - original 800x600 then some noise reduction and downsample to 640x480](/uploads/imported_attachments/90u9_WhiskyGlass3.jpg "17 passes "Easy10 Interior+" (unbiased progressive) in Twilight in a bit less than 30 minutes - original 800x600 then some noise reduction and downsample to 640x480")
                                          • Al HartA Offline
                                            Al Hart
                                            This Workshop is a good chance to study lighting and distortion.
                                            Your ice does not seem to distort the whiskey. Did you place any refraction on the ice itself?
                                            Al Hart
                                            • 1 / 4
