    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 353.9k Views 71 Watching
    • TIGT Online
      @plot-paris said:
      @thomthom said:
      Nice little tool.
      But all the messageboxes, can't they instead be made into a single UI.Inputbox ?
      I agree with thomthom - on both statements ๐Ÿ˜‰
      and I think he didn't mean to complain about the few seconds it takes to klick yes or no several times - he is just searching for perfection!
      and I think he is right in thinking, that having all these questions together in one popup window would make sense.
      I imagine all the options having a check-box to check/uncheck. settings for 'smoothing' or 'intersecting' will be saved throughout a SketchUp session. thus you don't have to deal with these questions again, when using the tool again.
      alongside the 'OK' button you would have an 'Update' button. like that you can for example reverse the path direction, then update to view the changes, then maybe change back again and update once more... this would not only make workflow even quicker, but add another level of control to the tool (because you can try different settings over and over again...)
      oh, and TIG - the tool is absolutely fantastic! ๐Ÿ˜
      I'm currently looking at updating several of my extrusion tools and putting them onto a toolbar and giving them web-dialogs were appropriate... so be patient ๐Ÿ‘ฟ ๐Ÿค“ ๐Ÿ˜‰
      • JClementsJ Offline
        JClements
        Maybe Chris Fullmer will allow you to put "Bender" on the same toolbar. It would be a good fit. ๐Ÿ˜Ž
        J
        • CarrozzaC Offline
          Carrozza
          Hi TIG and all, today I spent some quality time trying to achieve the result of this procedure with Extrude Edges by Rails plugin: http://www.youtube.com/watch?v=SUYN_Uqzvec.
          http://img18.imageshack.us/img18/9016/capturew.gif
          Any idea if and how is possible to produce this kind of result?
          Thanks in advance for the plugin and any help.
          • plot-parisP Offline
            plot-paris
            wow, sounds exciting. I will be as patient as I can manage ๐ŸŽ‰
            ๐Ÿ˜„
            (@Gaieus**: see, with a Wave I would have been able to place this comment inline, where it belongs, instead of having to quote to make clear which post I am referring to...)**
            • TIGT Online
              As you found vanillas FollowMe isn't going to make a Fillet that touches the Leg and Arm properly...
              Here is away of doing it with careful pre-planning, Groups, Copy/Paste-in-Place, Intersect and EEbyRails etc - however the Fillet that's made is very poly-intensive... BUT it is accurate to suit the facets of the cylinders... depends what you want - for detailed work OK but for massing just leave out the fillets as you'll barely see them! EEbtRailsFilletWeldForm.pngEEbtRailsFilletWeldForm.skp
              • CarrozzaC Offline
                Carrozza
                Hi TIG, thanks for your help. There's a problem with the fillet created this way, though: it doesn't revolve correctly around the "arm". See picture, taken from your kind example: on one side the arc points inward, on the other side points outward.
                http://img704.imageshack.us/img704/942/capturem.gif
                  blajnov
                  With the plug "Round Corner" by Fredo, you can do the welding seam.
                  • TIGT Online
                    You are right !
                    If you make it in 90 degree bits it's better...
                    BUT it should be like that - I'll look at the cause...
                    Perhaps the Fredo Rounded Option is the best ... see below ...
                    Blajnov - exactly did you do that I can't reproduce it ??? ๐Ÿ˜•
                      d12dozr
                      Top segment of horizontal pipe has to line up with a segment on the vertical pipe...look closely at his hidden geometry ๐Ÿค“
                      http://goo.gl/f7ooYh
                      • CarrozzaC Offline
                        Carrozza
                        Mamma mia, this is a great learning experience!
                        Thank you very much Blajinov and TIG for your help, is much appreciated! โ˜€
                          blajnov
                          I enclose a file with scenes of action
                          • TIGT Online
                            I see now... โ˜€
                            So to recap: DON'T use EEbyRails for making Fillets between Rounded Legs and Arms etc - instead USE Fredo's 'Round Corners' - it's quicker and produces better results !
                            Blajnov - it might be best if you edit / retitled your SKP without reference to EEbyR, to avoid confusion ๐Ÿ˜„
                            • TIGT Online
                              Here's a way to make a Multi-Railed Mesh with EEbyRails by making sub-meshes and combining them...EEbyRailsMultiRailSteps.pngEEbyRailsMultiRailSteps.skp
                                Rip Tanion
                                Awesome plugin! Thanks!
                                Three attached curvesround_corner.pnground_corner.skp
                                • TIGT Online
                                  I don't understand you diagram.
                                  You can already do this ?
                                  Are you wanting some sort of 2-face FollowMe ? Just use the faces edges [welded into a curve] as your Rails ?
                                  With EEbyRv2 [that is about to be launched] you will be able to choose the Profile, Rail1 and Rail2 and then a 'Melding-Profile' that fixes the end form too - is that what you want ? It will allow a definite start and end profile location form to be predefined...
                                  โ“
                                  • H Offline
                                    hsjzyangbin
                                    Hi,TIG,I have a idea that <extrude edges by rails> adds a path like this,thanks
                                    next:I wish it could be add rotate and scale function
                                    • H Offline
                                      hsjzyangbin
                                      โ“
                                      Yes,it could be "2-face +2-path+FollowMe" ๐Ÿ˜
                                      I also do not have this plug-in, I use the LATHE. RB command generates images shown, as you said, the first path to the same, choose the second Rails as a control Rails
                                      "lathe" you can see it http://www.sketchupbbs.com/thread-40382-1-1.html
                                      • charly2008C Offline
                                        charly2008
                                        • TIGT Online
                                          โ“
                                          I too have a lathe.rb that is somewhat similar...
                                          • H Offline
                                            hsjzyangbin
                                            ๅธŒๆœ›ๆˆ‘็š„ๆ่ฎฎๅฏนไฝ ็š„ๆ’ไปถๆœ‰็”จ๏ผŒ่ฐข่ฐข๏ผ
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 17 / 20
