    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 424.8k Views 71 Watching
      Here's an example of making a 'nose-cone' with EEbyRails...NoseConeEEbyRails.pngNoseConeEEbyRails.skp
      • CarrozzaC
        Carrozza
        WOW!
        • plot-parisP
          plot-paris
          @thomthom said:
          Nice little tool.
          But all the messageboxes, can't they instead be made into a single UI.Inputbox ?
          I agree with thomthom - on both statements πŸ˜‰
          and I think he didn't mean to complain about the few seconds it takes to klick yes or no several times - he is just searching for perfection!
          and I think he is right in thinking, that having all these questions together in one popup window would make sense.
          I imagine all the options having a check-box to check/uncheck. settings for 'smoothing' or 'intersecting' will be saved throughout a SketchUp session. thus you don't have to deal with these questions again, when using the tool again.
          alongside the 'OK' button you would have an 'Update' button. like that you can for example reverse the path direction, then update to view the changes, then maybe change back again and update once more... this would not only make workflow even quicker, but add another level of control to the tool (because you can try different settings over and over again...)
          oh, and TIG - the tool is absolutely fantastic! 😍
            @plot-paris said:
            @thomthom said:
            Nice little tool.
            I'm currently looking at updating several of my extrusion tools and putting them onto a toolbar and giving them web-dialogs were appropriate... so be patient πŸ‘Ώ πŸ€“ πŸ˜‰
            • JClementsJ
              JClements
              Maybe Chris Fullmer will allow you to put "Bender" on the same toolbar. It would be a good fit. 😎
              J
              • CarrozzaC
                Carrozza
                Hi TIG and all, today I spent some quality time trying to achieve the result of this procedure with Extrude Edges by Rails plugin: http://www.youtube.com/watch?v=SUYN_Uqzvec.
                http://img18.imageshack.us/img18/9016/capturew.gif
                Any idea if and how is possible to produce this kind of result?
                Thanks in advance for the plugin and any help.
                • plot-parisP
                  plot-paris
                  wow, sounds exciting. I will be as patient as I can manage πŸŽ‰
                  πŸ˜„
                  (@Gaieus**: see, with a Wave I would have been able to place this comment inline, where it belongs, instead of having to quote to make clear which post I am referring to...)**
                    As you found vanillas FollowMe isn't going to make a Fillet that touches the Leg and Arm properly...
                    Here is away of doing it with careful pre-planning, Groups, Copy/Paste-in-Place, Intersect and EEbyRails etc - however the Fillet that's made is very poly-intensive... BUT it is accurate to suit the facets of the cylinders... depends what you want - for detailed work OK but for massing just leave out the fillets as you'll barely see them! EEbtRailsFilletWeldForm.pngEEbtRailsFilletWeldForm.skp
                    • CarrozzaC
                      Carrozza
                      Hi TIG, thanks for your help. There's a problem with the fillet created this way, though: it doesn't revolve correctly around the "arm". See picture, taken from your kind example: on one side the arc points inward, on the other side points outward.
                      http://img704.imageshack.us/img704/942/capturem.gif
                      • B
                        blajnov
                        With the plug "Round Corner" by Fredo, you can do the welding seam.
                          You are right !
                          If you make it in 90 degree bits it's better...
                          BUT it should be like that - I'll look at the cause...
                          Perhaps the Fredo Rounded Option is the best ... see below ...
                          Blajnov - exactly did you do that I can't reproduce it ??? πŸ˜•
                            d12dozr
                            Top segment of horizontal pipe has to line up with a segment on the vertical pipe...look closely at his hidden geometry πŸ€“
                            http://goo.gl/f7ooYh
                            • CarrozzaC
                              Carrozza
                              Mamma mia, this is a great learning experience!
                              Thank you very much Blajinov and TIG for your help, is much appreciated! β˜€
                              • B
                                blajnov
                                I enclose a file with scenes of action
                                  I see now... β˜€
                                  So to recap: DON'T use EEbyRails for making Fillets between Rounded Legs and Arms etc - instead USE Fredo's 'Round Corners' - it's quicker and produces better results !
                                  Blajnov - it might be best if you edit / retitled your SKP without reference to EEbyR, to avoid confusion πŸ˜„
                                    Here's a way to make a Multi-Railed Mesh with EEbyRails by making sub-meshes and combining them...EEbyRailsMultiRailSteps.pngEEbyRailsMultiRailSteps.skp
                                      Rip Tanion
                                      Awesome plugin! Thanks!
                                      Three attached curvesround_corner.pnground_corner.skp
                                        I don't understand you diagram.
                                        You can already do this ?
                                        Are you wanting some sort of 2-face FollowMe ? Just use the faces edges [welded into a curve] as your Rails ?
                                        With EEbyRv2 [that is about to be launched] you will be able to choose the Profile, Rail1 and Rail2 and then a 'Melding-Profile' that fixes the end form too - is that what you want ? It will allow a definite start and end profile location form to be predefined...
                                        • H
                                          hsjzyangbin
                                          Hi,TIG,I have a idea that <extrude edges by rails> adds a path like this,thanks
                                          next:I wish it could be add rotate and scale function
                                          • H
                                            hsjzyangbin
                                            Yes,it could be "2-face +2-path+FollowMe" 😍
                                            I also do not have this plug-in, I use the LATHE. RB command generates images shown, as you said, the first path to the same, choose the second Rails as a control Rails
                                            "lathe" you can see it http://www.sketchupbbs.com/thread-40382-1-1.html
                                            • 19
                                            • 20
                                            • 6 / 20
