    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 424.8k Views 71 Watching
    • CarrozzaC
      Carrozza
      Hi TIG, thanks for your help. There's a problem with the fillet created this way, though: it doesn't revolve correctly around the "arm". See picture, taken from your kind example: on one side the arc points inward, on the other side points outward.
      http://img704.imageshack.us/img704/942/capturem.gif
      • B
        blajnov
        With the plug "Round Corner" by Fredo, you can do the welding seam.
          You are right !
          If you make it in 90 degree bits it's better...
          BUT it should be like that - I'll look at the cause...
          Perhaps the Fredo Rounded Option is the best ... see below ...
          Blajnov - exactly did you do that I can't reproduce it ??? 😕
            d12dozr
            Top segment of horizontal pipe has to line up with a segment on the vertical pipe...look closely at his hidden geometry 🤓
            http://goo.gl/f7ooYh
            • CarrozzaC
              Carrozza
              Mamma mia, this is a great learning experience!
              Thank you very much Blajinov and TIG for your help, is much appreciated! ☀
              • B
                blajnov
                I enclose a file with scenes of action
                RailsFilletWeldForm.skp
                  I see now... ☀
                  So to recap: DON'T use EEbyRails for making Fillets between Rounded Legs and Arms etc - instead USE Fredo's 'Round Corners' - it's quicker and produces better results !
                  Blajnov - it might be best if you edit / retitled your SKP without reference to EEbyR, to avoid confusion 😄
                    Here's a way to make a Multi-Railed Mesh with EEbyRails by making sub-meshes and combining them...EEbyRailsMultiRailSteps.pngEEbyRailsMultiRailSteps.skp
                      Rip Tanion
                      Awesome plugin! Thanks!
                      Three attached curvesround_corner.pnground_corner.skp
                        I don't understand you diagram.
                        You can already do this ?
                        Are you wanting some sort of 2-face FollowMe ? Just use the faces edges [welded into a curve] as your Rails ?
                        With EEbyRv2 [that is about to be launched] you will be able to choose the Profile, Rail1 and Rail2 and then a 'Melding-Profile' that fixes the end form too - is that what you want ? It will allow a definite start and end profile location form to be predefined...
                        • H
                          hsjzyangbin
                          Hi,TIG,I have a idea that <extrude edges by rails> adds a path like this,thanks
                          next:I wish it could be add rotate and scale function
                          • H
                            hsjzyangbin
                            Yes,it could be "2-face +2-path+FollowMe" 😍
                            I also do not have this plug-in, I use the LATHE. RB command generates images shown, as you said, the first path to the same, choose the second Rails as a control Rails
                            "lathe" you can see it http://www.sketchupbbs.com/thread-40382-1-1.html
                            • charly2008C
                              charly2008
                                I too have a lathe.rb that is somewhat similar...
                                • H
                                  hsjzyangbin
                                  希望我的提议对你的插件有用,谢谢!
                                    @hsjzyangbin said:
                                    希望我的提议对你的插件有用,谢谢!
                                    Your proposal for my plug-in very useful, thank you!
                                    • david_hD
                                      david_h
                                      very fun indeed. Is there a toolbar? I get the command in my Plugins Tab, but Is there an onscreen toolbar as well?
                                        No Toolbar yet OR webdialog BUT it's on the list - trying to get v2 and segmentation right first...
                                          http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                                          Here's v2 - now allows a final 'melding-profile' if desired and facets minimized...
                                            Here's some examples of EEbyRails v2ExtrudeEdgesByRailsV2Examples.pngExtrudeEdgesByRailsV2Examples.skp
                                            • 19
                                            • 20
                                            • 7 / 20
