    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 424.8k Views 71 Watching
      @carrozza said:
      Hi TIG and all, today I spent some quality time trying to achieve the result of this procedure with Extrude Edges by Rails plugin: http://www.youtube.com/watch?v=SUYN_Uqzvec.
      http://img18.imageshack.us/img18/9016/capturew.gif
      Any idea if and how is possible to produce this kind of result?
      Thanks in advance for the plugin and any help.
      As you found vanillas FollowMe isn't going to make a Fillet that touches the Leg and Arm properly...
      Here is away of doing it with careful pre-planning, Groups, Copy/Paste-in-Place, Intersect and EEbyRails etc - however the Fillet that's made is very poly-intensive... BUT it is accurate to suit the facets of the cylinders... depends what you want - for detailed work OK but for massing just leave out the fillets as you'll barely see them! EEbtRailsFilletWeldForm.pngEEbtRailsFilletWeldForm.skp
      • CarrozzaC
        Carrozza
        Hi TIG, thanks for your help. There's a problem with the fillet created this way, though: it doesn't revolve correctly around the "arm". See picture, taken from your kind example: on one side the arc points inward, on the other side points outward.
        http://img704.imageshack.us/img704/942/capturem.gif
        • B
          blajnov
          With the plug "Round Corner" by Fredo, you can do the welding seam.
            You are right !
            If you make it in 90 degree bits it's better...
            BUT it should be like that - I'll look at the cause...
            Perhaps the Fredo Rounded Option is the best ... see below ...
            Blajnov - exactly did you do that I can't reproduce it ??? 😕
              d12dozr
              Top segment of horizontal pipe has to line up with a segment on the vertical pipe...look closely at his hidden geometry 🤓
              http://goo.gl/f7ooYh
              • CarrozzaC
                Carrozza
                Mamma mia, this is a great learning experience!
                Thank you very much Blajinov and TIG for your help, is much appreciated! ☀
                • B
                  blajnov
                  I enclose a file with scenes of action
                    I see now... ☀
                    So to recap: DON'T use EEbyRails for making Fillets between Rounded Legs and Arms etc - instead USE Fredo's 'Round Corners' - it's quicker and produces better results !
                    Blajnov - it might be best if you edit / retitled your SKP without reference to EEbyR, to avoid confusion 😄
                      Here's a way to make a Multi-Railed Mesh with EEbyRails by making sub-meshes and combining them...EEbyRailsMultiRailSteps.pngEEbyRailsMultiRailSteps.skp
                        Rip Tanion
                        Awesome plugin! Thanks!
                        Three attached curvesround_corner.pnground_corner.skp
                          I don't understand you diagram.
                          You can already do this ?
                          Are you wanting some sort of 2-face FollowMe ? Just use the faces edges [welded into a curve] as your Rails ?
                          With EEbyRv2 [that is about to be launched] you will be able to choose the Profile, Rail1 and Rail2 and then a 'Melding-Profile' that fixes the end form too - is that what you want ? It will allow a definite start and end profile location form to be predefined...
                          • H
                            hsjzyangbin
                            Hi,TIG,I have a idea that <extrude edges by rails> adds a path like this,thanks
                            next:I wish it could be add rotate and scale function
                            • H
                              hsjzyangbin
                              Yes,it could be "2-face +2-path+FollowMe" 😍
                              I also do not have this plug-in, I use the LATHE. RB command generates images shown, as you said, the first path to the same, choose the second Rails as a control Rails
                              "lathe" you can see it http://www.sketchupbbs.com/thread-40382-1-1.html
                              • charly2008C
                                charly2008
                                  I too have a lathe.rb that is somewhat similar...
                                  • H
                                    hsjzyangbin
                                    希望我的提议对你的插件有用,谢谢!
                                      @hsjzyangbin said:
                                      希望我的提议对你的插件有用,谢谢!
                                      Your proposal for my plug-in very useful, thank you!
                                      • david_hD
                                        david_h
                                        very fun indeed. Is there a toolbar? I get the command in my Plugins Tab, but Is there an onscreen toolbar as well?
                                          No Toolbar yet OR webdialog BUT it's on the list - trying to get v2 and segmentation right first...
                                            http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                                            Here's v2 - now allows a final 'melding-profile' if desired and facets minimized...
                                            • 19
                                            • 20
                                            • 7 / 20
