    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      Ayashi
      Excellent plugin! Thank you dude!
      • mitcorbM Offline
        mitcorb
        Thanks, Fredo:
        I had a glance at this link and it looks very informative.
        • fredo6F Offline
          I discovered a remarkable tutorial on BezierSpline written by Scott Onstottfrom AECBytes at http://www.aecbytes.com/tipsandtricks/2009/issue42-sketchup.html. It will drive you with a step-by-step tour of the plugin, with all types of curves (much better than what I could do).
          • O Offline
            oblin77
            Hello Fredo06
            Where I can find and download your plugin BezierSpline v1.21 ?
            thank you
            Best regards
            olivier de france
            • soloS Offline
              Try the first page.
              • plot-parisP Offline
                plot-paris
                don't know if that behavior is specific to my machinde. but when I have drawn a curve, then go into edit mode, press Ctrl to unlock allow curve points to be moved outside the initial drawing plane and then press the up arrow to lock it to a vertical direction, my cursor doesn't stick to the point anymore. meaning, that when I move up my cursor only by a tiny bit, the curve point shoots up vertically a lot faster, and in very wide increments too.
                if that is the general behavior of the plugin, would it be possible to change it, so that the point still sticks to the position of the curser (only the vertical position of course. to make things easier, a dotted horizontal line could be connecting the curve point and the curser).
                any ideas if thats possible?
                • fredo6F Offline
                  I understand and I had myself questions about this behavior which may not seem very natural. Let's say 2 things about it:
                  1. The Vertex Edit mode is actually working for perfroming one move per click. So in your case, you would need to move first in the 3D, then release the mouse, switch to Vertical mode by Arrow and Click to move the point vertically. I agree that I should use the modifier keys as successive steps of Input. I'll probably do that in a further release.
                  2. Bezierspline was my very first script and I did not that much of the SU API. My plan would be to introduce stickiness and inferences, a little bit in the spirit of Tools on Surface.
                    plot-paris
                    I am really looking forward to this, Fredo.
                      misteriosodude
                      Amazing, excellent -- very useful plugin, thanks!
                        rv1974
                        How could I make 'polyline segmentor' command work? I simply can't find it. 😕
                        • Bob JamesB Offline
                          Bob James
                          Right click on the line and then click on "Convert to"
                            rv1974
                            @Bob 👍
                            • fredo6F Offline
                              [New version 1.3 - 22 Dec 09]
                              This upgrade allows to convert any sequence of segments to a Polyline or Spline (before, in version 1.21, you needed first to create a curve)
                              I also added an extension for Dog-bone and T-Bone corners
                              See main post at http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&hilit=plugin#p100509
                                plot-paris
                                wow, thats fantastic, Fredo! just yesterday I went through welding dozens of curves, just to polyline-divide them afterwards. now that would be sooo much faster! what a great christmas present! THANK YOU 😍
                                and I see you've implemented some of the visual stuff of the 'round corner' plugin as well (like the green cursor when in edit mode). I like it a lot!
                                I've got one question though, that I wanted to ask you for quite some time now:
                                when I transform a polyline (or now just a series of linesegments 😉 ) into a Polyline Arc Corners, sometimes the distribution of vertexes is a bit strange, showing some corner with very high polygon detail, leaving others almost unrounded... is there a way to influence that? like to tell the plugin to distribute the vertexes evenly per corner?
                                • fredo6F Offline
                                  [attachment=0:28204xm3]<!-- ia0 -->bz_round_corner-problem01.jpg<!-- ia0 -->[/attachment:28204xm3]
                                  The number of vertices for the rounding is based on the Precision parameter given on a Full Circle basis. So for Precision = 24s, you'll get 24 points for 360°. Depending on the arc angle of the rounding, you'll get less or more points.
                                  Is that the explanation or do you see another issue or bug?
                                  • CadFatherC Offline
                                    CadFather
                                    Thank you Fredo, it runs very well.. conversion is awesome!
                                    updated icons if needed
                                    IMAGES_CadFather.zip
                                    • simon le bonS Offline
                                      simon le bon
                                      So Version 1.3 is out
                                      Always better and handy and complete. I add my single vibrant gratefulness to the vast number who have already given to you.
                                      So don't need to Weld anymore 👍
                                      DogBone added I have to look that!
                                      Also I've found a great interest and developments to use yourBZ__Animation (divider for flight path) in conjonction with Chris Fullmer's Component Stringer
                                      and also whith Shape Bender from the same to produce an arithmetic(?) segmented curve with it as your BZ__Animation is actually!! "limited to straight lines" 😉 😉
                                      Bien Amicalement, Simon.
                                        DIEGO-RODRIGUEZ
                                        hi fredo.
                                        a question.
                                        • how they work, the inferences. when I'm editing the nodes of a polyline?
                                          maybe. have an orthogonal way and a way to free movement, pressing ctrl
                                        • can add a tool that enables you to select multiple nodes in order to move them?
                                        • You can add, to draw a polyline (polyline insulation and polyline Zigzag)?
                                        http://img690.imageshack.us/img690/1589/sinttulo1qq.jpg
                                        • Plugins could be added to the libraries fredo? would be good to be able to translate and cuztomizar toolbar
                                        greetings and thanks for your exelentes plugins. and her willingness to help
                                          magpie
                                          It's a tremendous tool for enriching sketchup, must now pay careful attention to all the subtle variations in the toolset...Thankyou fredo!
                                          • fredo6F Offline
                                            New version 1.3b - 31 Jan 10.
                                            It fixes a bug in Segmentor and reconsolidates all sub-plugins recently introduced or changed.
                                            One tip, before I forgot. When you wish to give more precision to a curve without redrawing it (for instance an Arc or Circle curve), you can use "Convert to Catmull". With a precision of 3s, you introduce an median point for each segment. With Precision = 4s, you introduce two median points, etc.... Try on a circle of 24 segments and make it a circle of 96 segments.
                                            • 22
                                            • 23
                                            • 3 / 23
