    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • Bob JamesB Offline
      Bob James
      Right click on the line and then click on "Convert to"
        rv1974
        @Bob 👍
        • fredo6F Offline
          [New version 1.3 - 22 Dec 09]
          This upgrade allows to convert any sequence of segments to a Polyline or Spline (before, in version 1.21, you needed first to create a curve)
          I also added an extension for Dog-bone and T-Bone corners
          See main post at http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&hilit=plugin#p100509
          • plot-parisP Offline
            plot-paris
            wow, thats fantastic, Fredo! just yesterday I went through welding dozens of curves, just to polyline-divide them afterwards. now that would be sooo much faster! what a great christmas present! THANK YOU 😍
            and I see you've implemented some of the visual stuff of the 'round corner' plugin as well (like the green cursor when in edit mode). I like it a lot!
            I've got one question though, that I wanted to ask you for quite some time now:
            when I transform a polyline (or now just a series of linesegments 😉 ) into a Polyline Arc Corners, sometimes the distribution of vertexes is a bit strange, showing some corner with very high polygon detail, leaving others almost unrounded... is there a way to influence that? like to tell the plugin to distribute the vertexes evenly per corner?
            • fredo6F Offline
              [attachment=0:28204xm3]<!-- ia0 -->bz_round_corner-problem01.jpg<!-- ia0 -->[/attachment:28204xm3]
              The number of vertices for the rounding is based on the Precision parameter given on a Full Circle basis. So for Precision = 24s, you'll get 24 points for 360°. Depending on the arc angle of the rounding, you'll get less or more points.
              Is that the explanation or do you see another issue or bug?
              • CadFatherC Offline
                CadFather
                Thank you Fredo, it runs very well.. conversion is awesome!
                updated icons if needed
                IMAGES_CadFather.zip
                • simon le bonS Offline
                  simon le bon
                  So Version 1.3 is out
                  Always better and handy and complete. I add my single vibrant gratefulness to the vast number who have already given to you.
                  So don't need to Weld anymore 👍
                  DogBone added I have to look that!
                  Also I've found a great interest and developments to use yourBZ__Animation (divider for flight path) in conjonction with Chris Fullmer's Component Stringer
                  and also whith Shape Bender from the same to produce an arithmetic(?) segmented curve with it as your BZ__Animation is actually!! "limited to straight lines" 😉 😉
                  Bien Amicalement, Simon.
                    DIEGO-RODRIGUEZ
                    hi fredo.
                    a question.
                    • how they work, the inferences. when I'm editing the nodes of a polyline?
                      maybe. have an orthogonal way and a way to free movement, pressing ctrl
                    • can add a tool that enables you to select multiple nodes in order to move them?
                    • You can add, to draw a polyline (polyline insulation and polyline Zigzag)?
                    http://img690.imageshack.us/img690/1589/sinttulo1qq.jpg
                    • Plugins could be added to the libraries fredo? would be good to be able to translate and cuztomizar toolbar
                    greetings and thanks for your exelentes plugins. and her willingness to help
                      magpie
                      It's a tremendous tool for enriching sketchup, must now pay careful attention to all the subtle variations in the toolset...Thankyou fredo!
                      • fredo6F Offline
                        New version 1.3b - 31 Jan 10.
                        It fixes a bug in Segmentor and reconsolidates all sub-plugins recently introduced or changed.
                        One tip, before I forgot. When you wish to give more precision to a curve without redrawing it (for instance an Arc or Circle curve), you can use "Convert to Catmull". With a precision of 3s, you introduce an median point for each segment. With Precision = 4s, you introduce two median points, etc.... Try on a circle of 24 segments and make it a circle of 96 segments.
                          peter.b.nz
                          I am going round in circles! How do I download the bezierspline v1.3b plug in please. i keep clicking on the title but nothing is happening ...
                          • mitcorbM Offline
                            mitcorb
                            Go to the first page of this post. Mouse over the target file. Right click. Select Save Link As.. Make sure that the window that pops up shows the file name and be sure that file type is Zip file. Save to destination, say desktop, or Google Sketchup Plugin subfolder. I prefer desktop so that it gets me out of suspense. Then I cut or copy to the plugin folder. Then it is a matter of unzipping the folder in place in the plugins.
                            Also, be aware that you need the latest version of LibFredo, a helper file for the plugin. Do the same thing to download this one.
                            Hope this helps.
                            mitcorb
                              DIEGO-RODRIGUEZ
                              hi fredo.
                              a query.
                              in this plugin, the inferences do not work correctly.
                              in the first segment, generally work well (inferences, color axis)
                              the second segment, with some work tools and other tools do not work.
                              in the third segment, inferences generally do not work or the color of the axes.
                              and does not block the inference to press the shift key
                              that's normal? or is an error in my computer?
                              if not normal, it might solve?
                              Thank you very much
                              • fredo6F Offline
                                @diego-rodriguez said:
                                hi fredo.
                                a query.
                                Thank you very much
                                This plugin needs a serious refresh (this was my first one), in particular for the inference management, tangent positioining and some other additional features.
                                So your computer is innocent!
                                Fred
                                  tulacong
                                  thank you 😍
                                    mm5949
                                    hi fredo.
                                    a query.
                                    Thank you very much
                                    Fred
                                    So, should I download v1.3b, or should I wait for v.1.3c?
                                    If so, where can I find the download? I would like to try it.
                                    Thanks for your good work, 😄
                                    Mel
                                      jcoulter1890
                                      This tool looks amazing bit how do i actualy download it. Is there a link any1 can give me?
                                      • mitcorbM Offline
                                        mitcorb
                                        @jcoulter:
                                        "Go to the first page of this post. Mouse over the target file. Right click. Select Save Link As.. Make sure that the window that pops up shows the file name and be sure that file type is Zip file. Save to destination, say desktop, or Google Sketchup Plugin subfolder. I prefer desktop so that it gets me out of suspense. Then I cut or copy to the plugin folder. Then it is a matter of unzipping the folder in place in the plugins.
                                        Hope this helps.
                                        mitcorb
                                          agrazdi
                                          Whenever i try to use the Courbette comand the program always closes.
                                          Is it a Bug ?
                                          agrazdi
                                          • V Offline
                                            vrrroom
                                            I (also) have the problem that only half the toolbar is displayed. The same within the top menu.
                                            http://dl.dropbox.com/u/2399172/bezier1.png
                                            http://dl.dropbox.com/u/2399172/bezier2.png
                                            It was working fine the first few days after adding the plugin bundle. But today it was like this. I tried disable/enable, uninstall/install (with starting SketchUp in between), updated to the lastest version 3b. Same problem in SketchUp 6 and 7.
                                            I really need the Cubic Curve tool for tracing a complicated bent line for work with a tight deadline. Anybody knows what to do?
                                            • 22
                                            • 23
                                            • 4 / 23
